ReTile iI :: Week iiI
Moderators: TheRealOne, EddyMataGallos
Postby origami_alligator » 2010.06.02 (01:39)
ReTile Challenge
OVERALL POINT ACCUMULATION
  1. 179 :: 363
  2. Brainstone :: 394
  3. ChrisE :: 407
  4. Erik-Player :: 386
  5. palemoon :: 377
  6. romaniac :: 413
  7. southpawPOWPOW :: 382
    --Eliminated Contestants--
    Week 1 - 91 points required to continue
  8. da_guru :: 88
  9. daikenkai :: 74
  10. el_devo :: 73
  11. Life247 :: 65
  12. lukesv :: 50
    Week 2 - 181 points to continue...
    Week 3 - 285 points to continue...
Judging...
Week 1 - 91 points needed to continue
ghoulash
brainstone
gameplay :: 8/30
replayability :: 6/20
aesthetics :: 8/10
comments :: I had a lot of trouble enjoying the bottom-right, which was where the majority of the gameplay purported to be.
total :: 22/60
palemoon
gameplay :: 23/30
replayability :: 16/20
aesthetics :: 4/10
comments :: Played beautifully despite a tough set. Aesthetically, I'm glad you didn't sacrifice gp for looks, so I tossed you some points.
total :: 43/60
Chris
gameplay :: 27/30
replayability :: 10/20
aesthetics :: 10/10
comments :: I like how you were able to throw out a stock awesome tileset even though it was a retile. You got an easy set but you did well regardless.
total :: 47/60
el_devo
gameplay :: 19/30
replayability :: 12/20
aesthetics :: 10/10
comments :: Similar to Chris, you made a great tileset that fit the atmosphere of the objects perfectly.
total :: 41/60
179
gameplay :: 21/30
aesthetics :: 3/10
comments :: I wasn't sure what to make of this. Lots of creativity and obvious thought in the design. (Pretty sure it's cheatable, as well.)
total :: 36/600
DDRave
gameplay :: 10/30
aesthetics :: 4/10
comments :: Incredibly disjointed map.
total :: 20/60
Life
gameplay :: 14/30
replayability :: 4/20
aesthetics :: 5/10
comments :: <flag> Fuck this, I'ma teleport myself around for a while, slap down some numbers and move onto the next one.
total :: 23/60
rema
gameplay :: 22/30
aesthetics :: 6/10
comments :: Easy enough objects, but you worked wonders with them.
total :: 44/60
da_guru
gameplay :: 17/30
aesthetics :: 5/10
comments :: However much you meant them to, tiles just don't fit the objects. Bit boring, too, but a tough set.
total :: 32/60
eevee
gameplay :: 15/30
replayability :: 8/20
aesthetics :: 4/10
comments :: Pathing didn't make any sense whatsoever, and the tiles were weird.
total :: 27/60
lukesv
gameplay :: 14/30
replayability :: 5/20
aesthetics :: 4/10
comments :: Dull but smooth for the most part. (What was up with the traps?) Contrived tileset and highly linear gameplay -- for an example of a non-contrived tileset, see Chris above. For an example of nonlinear gameplay, see palemoon above.
total :: 23/60
Sen
note :: I don't feel particularly able to judge this map because it played very oddly on my shitty computer.
gameplay :: 25/30
replayability :: 15/20
aesthetics :: 5/10
comments :: I loved racing past the chains and chimneying around the maze, but it probably plays quite differently on a real computer.
total :: 45/60
Erik
gameplay :: 16/30
aesthetics :: 4/10
comments :: Classic Erik mish-mash, but the laser room was incredibly repressive, which hurt you here.
total :: 35/60
southpaw
gameplay :: 26/30
replayability :: 13/20
aesthetics :: 4/10
comments :: Awesome middle room, cool slow-down finish, looked all right I guess. Talk more later, barely gonna make the damn time limitttttt.
total :: 43/60
southpawPOWPOW
brainstone---
http://nmaps.net/200824
-gameplay: 17/30
-replay value: 10/20
-aesthetics: 5/10
total: 32/60
comments: There was much more to this map than there seemed at first. I liked that part the best. Unfortunately I found it hard to move and travel within. If you had made this a bit more... flowy? I probably would have enjoyed it much more. As it stands, moving through it is just choppy for me.
palemoon---
http://nmaps.net/200829
-gameplay: 21/30
-replay value: 18/20
-aesthetics: 4/10
total: 43/60
comments: To begin, the rocket dodging in this is supreme. Like a burrito supreme from Taco Bell 15 years ago (because trying to stomach Taco Bell these days doesn't happen like it used to). I found it a bit lackluster in terms of looks but the tiles were scarce and complimentary to the gameplay. Replay value is almost perfect. This is one of those maps I could spend 20 minutes playing over and over again, even if I've already completed it 3 or 4 times.
ChrisE---
http://nmaps.net/200795
-gameplay: 24/30
-replay value: 12/20
-aesthetics: 9/10
total: 45/60
comments: A bit hard to move around in at times but the drone pathing and multiple routse in this shone through that. The lasers traveled and ran around so well and they always had some line of sight that would either kill you or freak you out enough to know they aren't playing around. Great map!
el_devo.---
http://nmaps.net/200838
-gameplay: 5/30
-replay value: 3/20
-aesthetics: 4/10
total: 12/60
comments: It may have just been your object set but I felt like you could have done more with the objects anyway. Gameplay was lackluster. There was a perfect design to build a gauntlet run with the gauss turret while the chaingun fired from below. Oh well.
179---
http://nmaps.net/200842
-gameplay: 20/30
-aesthetics: 4/10
total: 34/60
comments: HOLY FUCK LOOK WHAT YOU DONE. In other words I loved the map but it doesn't score very well when broken up into different sections. That it doesn't score very well is LAMESAUCE but it's the truth. :(
Daikenkai---
http://nmaps.net/200805
-gameplay: 13/30
-replay value: 8/20
-aesthetics: 6/10
total: 27/60
comments: It was really hectic at the bottom. In some ways I liked that but at times I felt that you could have blocked off that upper rocket from the mine section on the right, or had the floorguard stop a bit further away so that it was perilous to travel down there but not too difficult. The top could have used some work, like opening up the laser drone to that area.
Life247---
http://nmaps.net/200861
-gameplay: 10/30
-replay value: 4/20
-aesthetics: 3/10
total: 17/60
comments: It was... not very good. I feel like in some cases the object set has a lot to do with the map but considering how many tile combinations you can come up with there were probably a lot of ways you could have made this more fun. Like sparse tiles up top so that if you miss your footing you fall to your death or something.
romaniac---
http://nmaps.net/200875
-gameplay: 18/30
-replay value: 14/20
-aesthetics: 8/10
total: 40/60
comments: Great job! This map felt like it could fit in with the 50's column. I liked it a lot, you utilized this object set very well.
da_guru---
http://nmaps.net/200895
-gameplay: 13/30
-replay value: 6/20
-aesthetics: 7/10
total: 26
comments: Fun but not much substance.
maxxxon---
http://www.nmaps.net/200868
-gameplay: 18/30
-replay value: 9/20
-aesthetics: 7/10
total: 34/60
comments: I thought this map was fun. It and I clicked very well. Unfortunately it wasn't offering much beyond rocket dodging.
lukesv---
http://nmaps.net/200940
-gameplay: 4/30
-replay value: 0/20
-aesthetics: 2/10
total: 6/60
comments: I don't know. This map was just plain awful and unfortunately I think it was just the unlucky draw of a bad object set. Sorry dude.
Seneschal---
http://nmaps.net/200978
-gameplay: 7/30
-aesthetics: 9/10
total: 34/60
comments: TOTAL LAG. ESCHER-ESQUE TILES. CONSTANT CHAINGUNS. WONDERFUL.
Erik-Player---
http://www.nmaps.net/200992
-gameplay: 22/30
-replay value: 8/20
-aesthetics: 6/10
total: 36/60
comments: I loved the lower left area when I had to make multiple perpendicular jumps to get to the gold. That was fantastic. The laser was great at the beginning and then become too overbearing near the end. Great job allowing the player to squeeze through that area at the end near the door so that one doesn't have to go all the way around.
palemoon
brainstone // scrap metal tower
+ 16// 30pts = gameplay
+ 17// 20pts = replay
+ 7// 10pts = aesthetics
fantastic puzzley use of floorguards and tiles combined. i liked the replayable value
in this due to the map being a lot more complex than it looked. didn't like the
gameplay much in the bottom sections. The top with the floorguard is definitely the
highlight.
+ 40 // 60
Chris3 // Love Trangle
+ 20// 30pts = gameplay
+ 9// 20pts = replay
+ 9// 10pts = aesthetics
great use of cool looking tiles. they compliment lasers very well. i hated dying,
though. there was so much empty space starting over was a pain. nice map
+ 38// 60
el_devo // So Circular
+ 10// 30pts = gameplay
+ 2// 20pts = replay
+ 8// 10pts = aesthetics
so this had promise but it fell short. the section with the switch was boring without
any enemies and the chaingun was criminally leashed into that tiny bottom section
where it was basically toothless. tileset is that hip and trendy style today, though.
Also, there are no circles in So Circular.
+ 20// 60
OneSevenNine // whatever you do you do it for me
+ 25// 30pts = gameplay
+ 16// 20pts = replay
+ 6// 10pts = aesthetics
quick and dirty jumps keep the chainguns a major threat throughout the map. the jumps
were challenging and laid out so it didn't get tedious. the tileset is utilitarian,
but a few small details keep it from being boring. not even the unhinged doors in the
middle can bring down your score! nice!
47//60
Daikenkai // Denial of Service
+ 11// 30pts = gameplay
+ 10// 20pts = replay
the rockets ruined everything i ever tried to do, due (doo doo lol) to the bad
placement of most of the tiles. It was just awkwardly set up and it could have been
better
+ 27// 60
Life247 // Deadly Voo
+ 15// 30pts = gameplay
+ 5// 20pts = replay
+ 5// 10pts = aesthetics
this was a difficult set of objects seriously. Your attempts to make it cool with squeezes and stuff helped, like making poop shiny and gold-plated.
+ 25// 60
romaniac // Tsar Chasm
+ 15// 20pts = replay
coolio. really solid use of the objects here. uh
i am running out of things to say
+ 46// 60
da_guru // House of wax
+ 19// 30pts = gameplay
+ 3// 20pts = replay
Well this was cool but not replayable at all. good use of drones
+ 30// 60
maxson924 // #moa is not my map
+ 22// 30pts = gameplay
+ 11// 20pts = replay
this was not as bad as you made it seem. The gold and tiles worked well with the rockets.
+ 40// 60
lukesv // Romance in an Avalance
+ 1// 20pts = replay
well it was kind of neat but not very interesting and the tiles did not help the objects much
+ 21// 60
Seneschal // Minotaurtoise
this is wonderful. the tileset was great looking and the laggy chainguns still made the map frantic. nice job with a really hard object set!
+ 48// 60
Erik_Player // Wait, What Dream?
+ 21// 30pts = gameplay
Just an all-around solid map. Had great replay value. nice going!
+ 47// 60
rocket_thumped
[21:29] <~jerrod> 24/30
[21:30] <~jerrod> 12/20
[21:30] <~jerrod> 5/10
[21:30] <~jerrod> 41 southpaw^^^
[21:32] <~jerrod> 22/30
[21:32] <~jerrod> 10/20
[21:33] <~jerrod> 3/10
[21:33] <~jerrod> 35 palemoon^^^^^
southpaw
ChrisE---
http://nmaps.net/201204
-gameplay: 25/30
-replay value: 17/20
-aesthetics: 8/10
total: 50/60
comments: So the simplicity basically made this map. The careful dodges and fantastic jumping that you have to perform to even make any progress makes this map a gem to play. Fantastic use of the objects, ChrisE.
Seneschal---
http://nmaps.net/201233
-gameplay: 14/30
-aesthetics: 3/10
total: 31/60
comments: It was alright. I didn't appreciate the clunkiness of this map. There were about 3 or 4 things you could have done to make the gameplay less frustrating overall but they really brought down your score in that department. I feel like this map needs to be rushed because the double-chaingun aspect makes it extremely difficult to manage the top section unless both chainguns are still separated.
179---
http://nmaps.net/201272
-gameplay: 15/30
-replay value: 11/20
-aesthetics: 8/10
total: 34/60
comments: It seemed kind of bland. There wasn't much to the map IMO but I did love the gauss gauntlet at the top. The rest of it was just a simple map with not much flare to it.
PALEMOON---
http://nmaps.net/201304
-gameplay: 24/30
-aesthetics: 9/10
total: 51/60
comments: Really well done! The laser//rocket duo is impressive and works extremely well together. I like how you crafted the tiles to work with the lasers vision instead of limiting it to the top section. Great job this week, dude.
brainstone---
http://nmaps.net/201334
-gameplay: 30/30
-replay value: 15/20
-aesthetics: 8/10
total: 53/60
comments: I think the ultimate goal of any ReTile map is to make it seem like the objects were placed by yourself. I think you achieved this goal perfectly with this map.
romaniac---
http://nmaps.net/201424
-gameplay: 23/30
-aesthetics: 6/10
total: 41/60
comments: This was a little puzzle to me and that was very cool. The object set you got had some weird aspects to it (like the switches around the mines) and I think you could have morphed the tiles to make grabbing those a little more enjoyable but it was still enjoyable regardless.
eevee---
http://nmaps.net/201458
-gameplay: 12/30
-replay value: 13/20
-aesthetics: 5/10
total: 30/60
comments: I just found this map extremely frustrating to play. I constantly felt limited by the tiles rather than feeling like they were trying to help me. The top section with the rocket was wonderful and I wish you would have used that section as your theme for the tiles rather than the 5-tiles you ended up going with.
Erik-Player---
http://www.nmaps.net/201478
-gameplay: 26/30
-replay value: 16/20
-aesthetics: 6/10
total: 48/60
comments: If there was ever a map that I would define as a "maze", this would be it. I was constantly going down the wrong corridors and ending up at dead ends without even realizing it. Great use of objects, dude.
palemoon
i was super productive this morning fuuuuuuuuckyeah
chrisE // OverCover
+ 24//30pts = gameplay
+ 17//20pts = replay value (replayability)
+ 3//10pts = aesthetics
Good use of double chainguns. The map is also fun and easy to navigate but also
dangerous, making repeated plays very enjoyable. The tileset is great in the top
section, but the repeated use of the l shapes near the bottom is uninteresting and
could be something cooler, like the curvey curves at the top.
+ 43//60
origami_alligator // Untitled
+ 28//30pts = gameplay
+ 10//20pts = replay value (replayability)
+ 1//10pts = aesthetics
Awesome, awesome use of the objects here. The exit area was a clever use of a door
and the upper right had neat interactions. However, the map is long and not very
dynamic so you basically end up doing the same thing each time, hurting your replay
value. The tileset also exaggerates the wild placement of the objects and stuff,
making this map look dense and cluttered (and bad).
+ 39//60
Seneschal // Bicycle Kiss
+ 18//30pts = gameplay
+ 14//20pts = replay value (replayability)
+ 7//10pts = aesthetics
Lookin' pretty Guacamole here (good thing every surface isn't covered in mines and
gold with no other enemies). You lose gameplay points for stuffing the doors
and launchpads into those ever-popular honeycomb formations where they can't do
anything but look forlornly at the ninja passing by, knowing that they will never
have the warmth of a ninja's buff body passing through their inviting metal ingress.
the map was fun up until the two chainguns completely overpowered their area. :C
+ 39//60
OneSevenNine // whatever you do stay dizzy for me
+ 26//30pts = gameplay
+ 8//10pts = aesthetics
Really excellent gameplay is to be had in this. The floorguard tricks were neat and
the gauss turrets were ACCENTUATED (CAPS) with the nice usage of dark grey solid
surfaces a british gentleman would call "tiles"
the replay is meh, although there is some room for speedage and stuff what
+ 44//60
brainstone // Mass Complex
+ 23//30pts = gameplay
+ 13//20pts = replay value (replayability)
+ 6//10pts = aesthetics
this map is really long but the overall challenge is such that it doesn't get too
frustrating to continue. Multiple playthroughs are enjoyable due to that!
hooray
also the map has a pretty brainstone vibe to it while using the objects quite well.
+ 42//60
romaniac // Cold Candle
+ 27//30pts = gameplay
+ 15//20pts = replay value (replayability)
Well this is delightfully weird. Loved the blocks next to the oneways and the jumps for the switches are strange and varied with the laserbeamage. Overall just a very interesting map to play. nice!
+ 48//60
maxson924 // Covet
+ 22//30pts = gameplay
I love what you've done with the place, darling. The chaingun and assorted enemies were utilized well, and the mines (especially in the top section with the rocket) are used just great. I really dislike the 5 tile stripes, though. They look less than awesome and tend to get in the way and make me stumble whenever i want to do something cool.
+ 40//60
Erik_Player // Calm The Storm
+ 9//20pts = replay value (replayability)
some areas (liek with the rocket and the upper left) are just flat and boring compared to others. I like how it's all labyrinthine (awesome word) but some areas were just bleh- was that squeeze out to the rocket area really needed, it just got me killed on a seeker that was awkwardly right in my face when i finally got out D:
Nice use of a weird object set!
+ 39//60
rocket_thumped
southpaw - 10/30 6/20 5/10 = 21/60 (you are so much better than this. sorry ;-;)
Erik-Player - 20/30 10/20 4/10 = 34/60
PALEMOON - 18/30 10/20 10/10 = 38/60
brainstone - 23/30 9/20 5/10 = 37/60
romaniac - 17/30 14/20 3/10 = 34/60
MAXSON - 15/30 7/20 2/10 = 24/60
Seneschal - 16/30 8/20 3/10 = 27/60
179 - 20/30 10/20 3/10 = 33/60
ChrisE - 19/30 11/20 5/10 = 35/60
Skyline
PPPPA;E,MOON'S/ maP":
gameplay: 20/30 Interesting structure but it felt kinda sloppy. Plenty of corner jump opportunities!
replay value: 20/20 Lots of exploration.
aesthetics: 7/10 It had a nice glassy castle sun dial plant room look to it.
TOTAL: 47/60
SRowth~SpraWW!:
gameplay: 23/30 A little roomy and linear, interesting bottom switch, the drones seemed difficult to work with. You can make some good paths.
replay value: 15/20 Somewhat open. Nice flow.
aesthetics: 5/10 Sorta chaotic LIKE MY BEDROOM ONLY WITH TILES AND NOT CLOTHING AND BOOKS
TOTAL: 43/60
Week 4 - everyone moves on...
southpaw
ChrisE---
http://nmaps.net/201585
-gameplay: 12/30
-replay value: 8/20
-aesthetics: 6/10
total: 26/60
comments: Not brilliant, kinda messy, overall unfun. The tiles were nice but that was the majority of your aesthetics score.
PALEMOON---
http://nmaps.net/201724
-gameplay: 12/30
-aesthetics: 4/10
total: 30/60
comments: This was not a good map either. The objects and tiles seemed extremely random with little harmony. I noticed you tried to do a couple cool gameplay aspects through making the ninja navigate your tiles but it fell short of awesome and leaned towards lame.
romaniac---
http://nmaps.net/201759
-gameplay: 21/30
-aesthetics: 7/10
total: 43/60
comments: Really wonderful use of objects here. The gameplay mechanics were very crisp and seemed natural, as though you built this map with your own objects. Great job.
179---
http://nmaps.net/201761
-gameplay: 15/30
-aesthetics: 5/10
total: 30/60
comments: Not horrible but not great.
brainstone---
http://nmaps.net/201803
-gameplay: 24/30
-aesthetics: 7/10
total: 46/60
comments: I love all the little pieces of this map. It's like a small puzzle and the prize is having a lot of fun figuring it out.
Erik-Player---
http://www.nmaps.net/201821
-gameplay: 16/30
-replay value: 8/20
-aesthetics: 6/10
total: 30/60
comments: It was a nice try at a good map but I think what brought your score down for me was that everything was very spread apart and the map overall seemed a little rushed.
flag
Chris
total ::37/60
southpaw
total :: 43/60
palemoon
gameplay :: 12/30
aesthetics :: 4/10
comments :: I apologize for having any part in your set. :P
total :: 24/60
rema
gameplay :: 27/30
aesthetics :: 6/10
comments :: Striking map, I was drawn to the structure in the middle but the low-key tiles accentuated it well. Played like a dream, one of the nicest retiles I've played.
total :: 49/60
179
gameplay :: 14/30
aesthetics :: 3/10
comments :: Nothing good here to speak of. Drone room had charm, and the magic gauss, but the rest was monotonous.
total :: 25/60
brainstone
gameplay :: 20/30
replayability :: 14/20
aesthetics :: 9/10
comments :: Sweet map, you did exactly the right thing with the columnar tiles. The beginning is incredible.
total :: 43/60
Erik
gameplay :: 18/30
aesthetics :: 6/10
comments :: You got lucky objects, because the glitch added a lot of depth to an otherwise lackluster map. The bottom was intense.
total :: 38/60
Sen
Why didn't you submit a map. :<
palemoon
CHRISE REHASH CAVE
+29 || 30pts = gp: really fun bottom left good use of the mines and seeker
+19 || 20pts = rv: i want to play this over a lot something about it is enjoyable
+4 || 10pts = ae: looks like generic popular map with rough spikey sides and arsty mine placement #453
+52 || 60 this is a way good score
SOUTHPAW REFUSES TO NAME HIS STUFF
+26 || 30pts = gp: like some kind of puzzly thing with the drone it was neat but sometimes was hard to navigate
+18 || 20pts = rv: the gameplay invites multiple playthroughs but is not mean about it
+3 || 10pts = ae: this is not exactly the most pretty thing ever
+47 || 60 this map was fun
ROMANIAC BLACK WOOL
+24 || 30pts = gp: good use of thwumps. I did not really appreciate the rockets being on my ass in awkward ways all the time though.
+9 || 20pts = rv: i really did not want to play this more than a couple times
+6 || 10pts = ae: so you turned it into a radium/mahimahi map.
+39 || 60 good, but could be improved.
ONESEVENNINE WHATEVER YOU DO DON'T WAIT FOR ME
+28 || 30pts = gp: drones worked nicely yo
+11 || 20pts = rv: replayable i guess. I think this score should be out of 10 and ae out of 20 because yeah but whatever
+6 || 10pts = ae: looks slightly terrible, with the exception of Mississipi
+45 || 60 you did a good job with what you got
BRAINSTONE KHALITORIAL
+27 || 30pts = gp: engaging, interesting, fun to navigate
+14 || 20pts = rv: the rocket placement kills me a lot so i have to retry a lot :C
+8 || 10pts = ae: cool looking and stuff
+49 || 60 very nice!
ERIK-PLAYER THE WIND
+23 || 30pts = gp: bewildering usage of the door floors and the empty tunnels were kinda cool
+10 || 20pts = rv: at first it looks really replayable and explorable but then you realize you only go one way every time
+9 || 10pts = it certainly looks windy
42 || 60 i didn't really like this
jerrod
SOUTHPAW
G/14/30
R/6/20
A/3/10
T/23/60
PALEMOON
G/15/30
R/12/20
A/4/10
T/31/60
ROMANIAC
G/16/30
R/8/20
A/5/10
T/29/60
179
G/19/30
R/11/20
A/5/10
T/35/60
BRAINSTONE
G/15/30
R/9/20
A/6/10
T/30/60
ERIK-PLAYER
G/17/30
R/12/20
A/8/10
T/37/60
CHRISE
G/14/30
R/11/20
A/9/10
T/34/60
Losttortuga
Southpaw
gameplay: 14/30
replay: 15/20
aesthetics: 4/10
While the mines and tiles created that was mostly inhibiting and not really any fun to move in,
the whole structure created some interesting possibilites in routes and in general was set up well.
Several parts looked good, especially the upper open section juxtaposed on the lower sectiom,
the image didn't otherwise come across as very striking.
PALEMOON
gameplay: 21/30
replay: 11/20
aesthetics: 3/10
It was quite a bit of fun to explore around the map, each little section had its own charm that
makes the entire map work. However, each section gets less interesting the more you must pass through it,
and while certain parts look good on thier own, as a whole it's hard to appreciate the look.
Prizes
1st - Receives 1 featured map of my favourite ReTile map of theirs.
2nd, 3rd, 4th - Permanent custom title on NUMA
This contest will run from Monday thru Saturday, leaving Sunday for last-minute scoring and PM'ing of maps
Rules & Procedures:
- Contestants must PM me FIVE (5) MAPS of their own from NUMA. (retile maps are not allowed. the object set must have been partially made by you.)
- I will remove all the tiles from the map, leaving only objects. DO NOT REMOVE THE TILES YOURSELF.
- From there contestants will be given the objects of another participant's map. Here is where the fun begins.
- Contestants must then place an entirely brand new tileset upon the map, thus altering the original gameplay and aesthetics.
There are 3 rules to retiling:
  • You may not add, move or delete any objects
  • You may not change any objects (ie, no changing drone paths or adding Nreality code)
  • You may not "remove" objects by covering them up with tiles
- When a contestant feels their retiled map is finished they must post it in this thread by Saturday, 11:59:59pm Pacific Standard Time (-8 GMT). Anybody who does not submit their map on time will be eliminated from the contest. Posting to NUMA or using the [map] BBCode in a post will both be acceptable.
- This challenge will last 5 weeks. The first 4 weeks everyone will be pitted against each other. At the beginning of the 5th week only the top 4 will continue.
- Please tag all of your maps "retile".
-You may cover up objects HALFWAY with a tile.
Etiquette:
For purposes of etiquette and curiosity, I will give you the map number of the map you retiled, so that you can add a link in your description of the map and so that you can see how different your tileset and gameplay is from the original.
Arbiters
Arbiter is just a fancy name for judge. There will be 3 Arbiters +1 (the extra is so that Arbiters may participate as well) at my discretion, so do not post asking to be an Arbiter.
The following are Arbiters
  • southpawPOWPOW
  • PALEMOON
  • flag
  • +1 :
Scoring:
Scoring will be cumulative, meaning that however many points you earn for each week will be added to your score from each previous week.
Each judges score will be added together, so there are 180pts possible for each week.
Eliminations will happen, but it is possible to avoid elimination. If you score within at least 70% of the person with the highest cumulative score you continue on.
The final round is a free-for-all. All points previously accrued for the top 4 contestants will be wiped and whoever scores the highest for that round wins.
The Arbiters will score as follows:
+ 30pts = gameplay
+ 20pts = replay value (replayability)
+ 10pts = aesthetics
Contestants:
  1. southpawPOWPOW
  2. PALEMOON
  3. Erik-Player
  4. lukesv
  5. Life247
  6. Seneschal
  7. Brainstone
  8. da_guru
  9. eevee
  10. daikenkai
  11. Tunco
  12. ChrisE
  13. el_devo
  14. 179
  15. romaniac
  16. MattKestrel
  17. pending...
+ means I have received maps from these people.
- means I have NOT received maps from these people.
Postby Erik-Player » 2010.06.02 (02:44)
Thank you. My wait is finally over, sign me up!
Postby otters~1 » 2010.06.02 (03:52)
I'd rather be a judge than a contestant, but you were all "don't post asking to be a judge" and on #moa you're all "POWPOW" so I'm just gonna air my feelings for a little here.
Things suck.
Postby origami_alligator » 2010.06.02 (04:12)
PALEMOON and flag, to be an arbiter requires lots of discipline every Sunday to get your judging done. Don't worry though, the first and second week are the most demanding and after that we go until we only have 4 people left.
Anyway, I approve of you two being arbiters.
Erik-Player, I signed you up. :D
NUMA Profile: http://nmaps.net/user/lukesv
Postby lukesv » 2010.06.02 (04:16)
I would like to participate
Postby aids » 2010.06.02 (04:34)
Sign me up too. I'd judge but Sunday's are too busy for me. :(
Postby Seneschal » 2010.06.02 (07:33)
As the winner of TACIII, I am most definitely in.
NUMA Profile: http://nmaps.net/user/brainstone
Postby Brainstone » 2010.06.02 (11:37)
Sign me in.
NUMA Profile: http://www.nmaps.net/user/da_guru
Postby da_guru » 2010.06.02 (14:40)
Joining.
Postby Rose » 2010.06.02 (18:27)
I'm in.
Postby Tunco » 2010.06.02 (18:38)
I'm in too.
Postby 大見解 » 2010.06.02 (20:14)
I'll join
NUMA Profile: http://nmaps.net/user/ChrisE
Postby ChrisE » 2010.06.02 (20:48)
IN
Postby OneSevenNine » 2010.06.03 (04:32)
how could i not?
i mean, hell yeah. in.
:loud music:
Postby remm » 2010.06.03 (11:18)
ooh ooh sign me up for this.
Never done retiling before, so it'll be good fun.
peking^
Postby MattKestrel » 2010.06.03 (21:52)
Oooh, ooh! Sign me up if there's any space left.
Postby origami_alligator » 2010.06.04 (08:31)
I'm going to need maps from everyone who has signed up so far before we can start this thing. I'll send out a PM on Friday to all the contestants who have not given me their maps. If you have not messaged me your maps by Sunday you will not be participating.
Postby aids » 2010.06.04 (09:31)
Manus Australis wrote:I'm going to need maps from everyone who has signed up so far before we can start this thing. I'll send out a PM on Friday to all the contestants who have not given me their maps. If you have not messaged me your maps by Sunday you will not be participating.
Does it matter if they are delisted?
Postby origami_alligator » 2010.06.04 (16:15)
No, just so long as they are from your archive or a collaboration you did with someone else.
Postby 大見解 » 2010.06.08 (02:21)
monday...?
Postby origami_alligator » 2010.06.08 (21:41)
sorry for the delay, I've had some things to attend to IRL for the last couple days and have not had much time to get things situated for this contest. There is a lot of preparation I was hoping to get finished with on Sunday and, as I said, things came up and I wasn't able to get this contest figured out. A lot of the preparation has had to wait for everyone to sign up, also, so yeah.
Anyway, enough excuses, I'll get PM's sent out today and you will have until Saturday at Midnight to get your maps in. Remember to post them in this thread. DO NOT PM YOUR MAPS TO ME.
Postby 大見解 » 2010.06.09 (01:14)
Manus Australis wrote:- Contestants must PM me FIVE (5) MAPS of their own from NUMA. (retile maps are not allowed. the object set must have been partially made by you.)
Manus Australis wrote: DO NOT PM YOUR MAPS TO ME.
um????
Postby da_guru » 2010.06.09 (15:11)
um????
I guess he means not to pm the edited/finished/retiled maps, but post them in this thread.
However it's already Wednesday and only half of the week is a bit short to work out a tileset, which harmonises with the objects.
Maybe give us a whole week starting with the day when you will have sent the "tileless" maps to all participants?
Postby origami_alligator » 2010.06.09 (21:19)
um????
Honestly, it shouldn't take you more than 12 hours of time to come up with a tileset for a retile. My apologies for starting the week incredibly and horribly late, but if you're spending 12 hours entirely on one retile you're trying too hard. Sometimes the best retiles are horribly copy/pasted shapes and other times they are beautiful creations of things.
As for PM'ing your maps, that goes for the final product, the ReTile which you will be submitting to NUMA.
PM's are going out soon. Remember to read the rules and stay updated. A single mistake can get you eliminated.
Postby Brainstone » 2010.06.10 (17:18)
I`m confused. Is this the right thing I`m doing or should I have PMed you the link. I guess not. Here you are. Tad-daaah:
Return to “Highscores & Contests (Nv1.4)”
