Metanet Bitesized :: LEVELS FINISHED! :D Playtesters needed!
Moderator: zoasBE
- Not actually an admin
I see trance hasn't given you his next 5 maps from the 80s collumn, so that makes 71 to go on your list, but on the list i'm keeping on IRC, it has 70 maps to go, here is what i have on the list '441/500 - 88.2% - 59 To Go - To Do http://pastebin.com/raw.php?i=LwWVgTWg', from 70 to 59 is these maps & the 5 of trances he hasn't put up here, i checked both lists, excluding these maps, you didn't miss a miss a map on the list from what i checked, anyway, i'm sure you can find it easy, unless you just miss-counted for the total maps done, anyway, this won't die again, it will get finished
EDIT
DW40 told me 56-4 was missing a trigger, fixed it
EDIT
You're very welcome.29403 wrote:
NachoCheese, trance, thanks a lot for finishing the 20s column! That's five columns down, five to go! Also, trance, there's some good work on the 80s column there! :)
I plan on giving what needs to get done in a single paste, but here's one more paste containing the last levels of the 80s column that needed to be done:Paradox-Dragon wrote:
http://pastebin.com/d8wM8tpA
Sig by Aidiera.
I have 167 speedrun Episode Top-20s and I'm 4th on the boards.
- Steam: What's Steam
I'm kinda confused, but I've updated the list. I'll update the full pack once you've finished your levels, and good luck with 83-0 and 84-4. Thanks.trance wrote:You're very welcome.29403 wrote:
It's very difficult, someone else should probably make a better version, but this is possible
EDIT
EDIT
98-4 is pretty bad, may need a bit of fixing down the bottom, the sides are both possible & easy, they just look difficult
EDIT
If any of these maps are too hard, then i'll fix them
I've had these done for a while. The final two levels for the 80s column, 83-3 and 84-0, are done.
Sig by Aidiera.
PD, 36-4 has no exit switch.
Here's the fixed one
EDIT
I just realised, my 35-2 in this post is actually 35-4, i'll fix that, so 35-2 still needs to be made
& here is another
EDIT
I think i edit these posts too much
I could of sworn I've posted the rest of the 80s column. Looks like I forgot, but here are the rest of them.
Sig by Aidiera.
Pack updated.
http://pastebin.com/h5P2W66K
http://pastebin.com/BFqVpiGZ
http://pastebin.com/djHMPXbj
As well as the ones that needed quality control (4-1 to 4-4).
http://pastebin.com/hMbBACsH
Sig by Aidiera.
EDIT
- NUMA Profile: http://nmaps.net/user/remote
29403 good job man. This is astounding.
I feel proud to have been a part of it.
thats right, im remote.
Whew... it was a tough project, spanning many metanet generations... but we're almost done! Perhaps once it's finished we'll get a bit more life in the community :DLimer wrote:WOAH, this is almost finished?!
Thanks for the huge bunch of levels, trance, PaD and Tunco. The levelset will be updated once we get to 500, ready for the playtesting stage.
Dox has 59-2 above me, but here are the other ten.
http://pastebin.com/n58dDihy
http://pastebin.com/76u1k2Wm
http://pastebin.com/0mjabw0u
Sig by Aidiera.
Here's my final map for this project. When it is completed, how are we going to playtest the levels?
Sig by Aidiera.
I believe this is finished now
Here are all the levels (or what i believe to be all the levels) with Capital Letters & a few more spelling/punctuation mistakes fixed, there are 2 35-2s because Tunc made it...
- Attachments
- userlevels.txt
- (698.11 KiB) Downloaded 343 times
Ignore the ()
30-0 - Could be a bit smaller ()
30-1 - Perfect
30-2 - Really odd ()
30-3 - Could be alot smaller ()
30-4 - A few tile & object adjustments needed to be more like the original
31-0 - Moved a few things around
31-1 - Could probably be smaller, but it is a perfect resize
31-2 - At first look, it looks odd, but it's a good scale from the original, just a few mines not in the right places or an extra mine
31-3 - Background art - Too small for the drones to be the same as the original
31-4 - Background art - I guess it works, although it would probably work better 1 or 2 tiles bigger
32-0 - It's nice?
32-1 - Background art - Too small for the drones to be the same as the original
32-2 - Background art - Okay
32-3 - Background art - I couldn't recognize what map this was, i thought it might be the one it is but i still had to check to make sure
32-4 - Background art - Too small
33-0 - Okay
33-1 - Background art - could probably change the 8 tiles to 1 or 6 tiles
33-2 - Background art - Too small
33-3 - Background art - Too small
33-4 - Background art - Too small
34-0 - Okay, could be smaller
34-1 - A few tile & object adjustments needed to be more like the original
34-2 - Looks odd but it's the same as the original
34-3 - Nice
34-4 - A few tile changes & double all the bounce blocks
35-0 - (I made this)
35-1 - Okay
35-2 - (Unknown)
35-3 - (I made this) You have to get the ending jump really close to the middle for the second exit
35-4 - (I made this)
36-0 - (I made this)
36-1 - Looks odd, could probably use a few tile & object adjustments
36-2 - (I made this) Easier than it looks
36-3 - Great
36-4 - (I made this)
37-0 - It works?
37-1 - Odd tiles to ajust for bitesize but it's great
37-2 - Great
37-3 - (I made this) Incredibly hard to bitesize
37-4 - (I made this)
38-0 - (I made this)
38-1 - (I made this) Annoying to bitesize, easier than it looks, even AGD
38-2 - (I made this) It may be too difficult
38-3 - (I made this)
38-4 - Difficult
39-0 - (I made this)
39-1 - (I made this)
39-2 - (I made this)
39-3 - Okay
39-4 - (I made this)
Sig by Aidiera.
