I cant get into nmaps.net
Postby DAI_TOU_ZAI » 2013.06.10 (20:00)
It says "Great! How do I sign up?
NUMA's login system is integrated with the N highscore account system. In order to get an account on NUMA, download N, run it, click on 'configure', enter a username and password in the boxes provided, and click 'create new user'. You can then use that account to log into NUMA."
I tried to log in and i have the user name and password correct so why isn't it letting me log in to this nmaps website?
Postby zoasBE » 2013.06.11 (11:13)
From what I can remember, I think you should have received a confirmation/activation e-mail.
Try to log in as your username in N, then place the same password and the same e-mail address as in your N. Then check your e-mail inbox and make your first login from the activation e-mail received.
I hope it works.
Postby DAI_TOU_ZAI » 2013.06.12 (15:17)
zoasBE wrote:From what I can remember, I think you should have received a confirmation/activation e-mail.
I hope it works.
It didn't work, i dont get what im doing wrong... i also tried to change my password but it said password was wrong so i logged off and typed my password and user name and i got on it makes no sense because im typing in the right password and user name :\
Postby zoasBE » 2013.06.12 (16:38)
I hope it works.
Well,
I guess you're logged in N app rightly with your username and with your password right?
Then the problem persist in NUMA right? What's exactly that the site says to you when you try to log in with the same username and password that you has in your N app? The only apparent issue/mistake that I can thought off, is that maybe the first time you tried to log in (the time in where NUMA ask you for a validation e-mail adress) you typed an incorrect e-mail adress and NUNA sent the validation for that adress, so now you can't get the validation because it is in other email inbox that it is not yours. Try to repeat every correct step, and if the problem persists and you don't get your validation email I suggest to you to create a new user with a new password and a new email adress in your N app and then try to log in NUMA as with your new username.
Postby DAI_TOU_ZAI » 2013.06.12 (17:29)
[/quote]
Well,
Then the problem persist in NUMA right? What's exactly that the site says to you when you try to log in with the same username and password that you has in your N app? The only apparent issue/mistake that I can thought off, is that maybe the first time you tried to log in (the time in where NUMA ask you for a validation e-mail adress) you typed an incorrect e-mail adress and NUNA sent the validation for that adress, so now you can't get the validation because it is in other email inbox that it is not yours. Try to repeat every correct step, and if the problem persists and you don't get your validation email I suggest to you to create a new user with a new password and a new email adress in your N app and then try to log in NUMA as with your new username.[/quote]
Would i lose the maps i created? i want to get on NUMA to post them.
Postby zoasBE » 2013.06.12 (17:35)
DAI_TOU_ZAI wrote:Would i lose the maps i created? i want to get on NUMA to post them.
No, no, obvioulsy not. The maps you made are in the txt file or anywhere you saved them when you made them.
Well, wait, are you talking about N v2.0 or N v1.4?
Because if you are talking about 2.0, that's why you can't log in NUMA, I was talking every moment about v1.4.
Postby DAI_TOU_ZAI » 2013.06.12 (17:41)
Oh well i have N V2.0, so there is no fix for this than? that kind of sucks guess ill just have to wait until they update it
Postby EddyMataGallos » 2013.06.12 (17:53)
Lets solve this. NUMA works ONLY with N1.4 accounts, so if you wanna access it you know what to do. As for the maps, sorry but v2.0 and v1.4 use a completely diferent format and hence are not compatible, so its not only you but everybody "loses" their maps, in the sense that they need to create them again in v1.4 to submit them to NUMA. At the moment, M&R are working on a personal map database, lets call it NUMA v2.0, which will be stored on their server.
To your dissapointment, they will never be merged :/
Postby zoasBE » 2013.06.12 (18:05)
Yes, Eddy explained it pretty well since you clarified that you referred to N v2.0.
Is this true, Eddy? Something like NUMA, with the function to browse and comment and all that?
When they announced this? It's still on working right?
Postby 乳头的早餐谷物 » 2013.06.12 (18:07)
DAI_TOU_ZAI wrote:Oh well i have N V2.0, so there is no fix for this than? that kind of sucks guess ill just have to wait until they update it
Not going to happen. NUMA is for N 1.4 maps. N 2.0 has a different level format.
EddyMataGallos wrote:At the moment, M&R are working on a personal map database, lets call it NUMA v2.0, which will be stored on their server.
There's already a maps database built into 2.0. It mightn't be as good as NUMA but there's still a fair bit of functionality and unless you have some information that I don't, I don't think we can expect much more from M&R.
DAI_TOU_ZAI: get N 1.4 and make an account on there and then you can enjoy NUMA. It's served us well for eight years and community consensus is that it's better in most ways than 2.0 anyway. You can't post the maps you made in 2.0 on NUMA but you can submit them to 2.0's inbuilt database. You just click save and then publish and it's up there.
Postby DAI_TOU_ZAI » 2013.06.12 (18:15)
Thank you all for your help, sucks that i have to redo everything but ill get over it :D
Postby zoasBE » 2013.06.12 (18:18)
Agreed.
Vote oughts for president!
EDIT: DAI_TOU_ZAI, if you're going to switch to N v1.4, which I honestly think that it's far better than 2.0, I want to warn you that the editor is different. You must access to it by pressing '|' in the main menu. Also you have this: http://n.wikia.com/wiki/Mapmaking or other guides around the forums. good luck, and I hope to see you in NUMA soon!
Postby 乳头的早餐谷物 » 2013.06.12 (18:20)
zoasBE wrote:Vote oughts for president!
I already am president, and you don't get a vote!
Postby zoasBE » 2013.06.12 (18:24)
So sorry sir, when will the next elections? Remind me to vote please, I will be always by your side!
Postby 乳头的早餐谷物 » 2013.06.12 (18:25)
YOU DON'T GET TO VOTE
Postby EddyMataGallos » 2013.06.12 (18:44)
chiffℴnade wrote:There's already a maps database built into 2.0. It mightn't be as good as NUMA but there's still a fair bit of functionality and unless you have some information that I don't, I don't think we can expect much more from M&R.
Oh yeah, I was talking about an actual web interface, I believe they are working on a site.
zoasBE wrote:Is this true, Eddy? Something like NUMA, with the function to browse and comment and all that?
Yeah something like that. I don't quite remember, but that was basically the answer to "what are those map links suposed to be for?"
NUMA Profile: http://nmaps.net/user/Pixelwiz
Postby DraxoBox » 2013.06.12 (18:52)
Why not use the official site?
DON'T PHUCK WITH THE PHARAOH
Postby EddyMataGallos » 2013.06.12 (18:53)
Pixelwiz wrote: D_T_Z, maybe I can e-mail a copy of N 1.4 to you?
Yeah well, why not use the official site?
http://www.thewayoftheninja.org/n_v1pc.zip
Postby DAI_TOU_ZAI » 2013.06.12 (20:56)
zoasBE wrote:EDIT: DAI_TOU_ZAI, if you're going to switch to N v1.4, which I honestly think that it's far better than 2.0, I want to warn you that the editor is different. You must access to it by pressing '|' in the main menu. Also you have this: http://n.wikia.com/wiki/Mapmaking or other guides around the forums. good luck, and I hope to see you in NUMA soon!
Thanks, even though the editor is kind of confusing i don't think it will slow me down that much and don't worry i know how to make maps :P I only make precision jump maps, not really into the whole gold aspect more of the challenge people with precision.
Also are the maps smaller in 1.4? it seems like it
Some examples (Those are just the hard difficulty maps, i plan to release much harder)
http://i.imgur.com/MaErabI.png
http://i.imgur.com/bYIMZXz.png
http://i.imgur.com/OBrC22k.png
http://i.imgur.com/pdfYUdf.png
Postby DraxoBox » 2013.06.13 (12:07)
EddyMataGallos wrote:Yeah well, why not use the official site?
Oh. That makes sense.
Postby zoasBE » 2013.06.13 (22:53)
Them looks really cool, seriously, although I would play them to have a more solid opinion (Actually I can't because my Nv2.0 lags too much under my XP operative system, that' why I play at NReality_v6g2) I can notice in them that you place a lot of unnecesary mines, like the ones in upper tiles and like placing three instead of only two for each square in grounds or slopes, just take it if you want as advice. You can force the player to very precise movements using more than the half of objects. You should get into NUMA, feedback from other users it's one of its greatest things, also there hundreds of thousands of maps and great authors and you can get a lot of inspiration there.
btw, I like the way you place your Exits with those one-ways and normal doors, it's kinda unusual and stylish.
Sincerely, I hope to see you soon in NUMA, and that way you can check some of my maps.. :P A no, the level size for both versions it's the same, as well every object and stuff. <3
Return to “Troubleshooting (Nv1.4)”
