I don't know what happened but I have my sol file from another computer and now I am trying to put it in my specific flash player folder but every time I do that and open n_v14 it gets overwritten with no data and I am left with nothing just an empty screen and I don't wanna start over because I had all Ngame columns and most of the Nreality columns done..
Is there anything I can do or is it just accept the defeat and start over?
.sol
- Richard Richards
I hope this helps: http://forum.droni.es/viewtopic.php?f=21&t=4705
In fact, I restored and used my backup of my .sol archive (which I make a backup of it eventually) a couple of times, and it worked for me. What I did was this, I formatted my computer, so my N did not recognize anything in memory, as it was the first time I opened N, I accepted the order of the program to save information to disk (Flash order at the first time you boot N), then N flash created a new and empty .sol file in its folder as always, then I just replaced it with my older and backup one. Hope this works for you. <3
just as friends as enemies
even fewer friends
[spoiler=CLICK!!!]Here you can find all my maps.
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
My 100 Vehemence 4 Maps
MOSS
Vehemence 4 as THE23
VODKALOVER Session One
VODKALOVER Session Two
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
MOSS
- Richard Richards
Thanks for the reply zoas but I think I am flunked.. Argh it is disturbing making my 200th map and this is not what I needed, you see the for the map I´m making I need the underclock unlocked but what I know of is that you have to beat at least 10 columns or more to get it.. :X
Seriously, try to make what I did.
You have your .sol backup right? Then remove the current .sol you has in its folder. You can found it by following the steps in the thread I previously linked to you here. Then you must pretend that you start from zero. Open your N for the first time, accept the Flash order to save data on your computer, then go to the folder in where the .sol is (explained in the other thread too) and now just replace the .sol that has been created by default by the one you has as backup. I'm sure this must work.
Anyway, why do you need the underclock mode? For playtesting? I can playtest your 200th map if you want or if you didn't have enough skills to it. Just send to me if you want. ;)
even fewer friends
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
MOSS
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
MOSS
- Richard Richards
Well the problem is that my .sol file seems to have gone broken so I cannot get it working, just gotta start from zero again I guess... But thanks for your thoughts zoas..!
