Walkover - A 2D Shooter.
Postby Snuggletummy » 2009.01.07 (23:40)
Topic taken from Facepunch
Walkover is a 2d shooter. You can control units to help you fight and to help build laster towers, rocket towers, and build teleporters to beam support units. Servers can hold up to 64 people, and can have up to 1000 enemies or more!
This game is pretty old but it is still fun. It can get really fun if you have people to play with because there is little to noone playing. It would be awesome for people to start playing.
Some images.
Walkover Manual
For playing the game, you need a desktop resolution of 1024x768 or 1280x1024.
Minimal system requirements: 600Mhz, 8MB Grafikkarte, recommended Hardware CPU>=1000Mhz, >=32MB Grafikkarte.
Single Player
There is no single player mode at the moment. But you can easily host a game locally by yourself without submitting it to the online game browser. That way, you can play on your own.
Multi Player
The simplest way for multiplaying is to join one of the available dedicated servers. If you play in a LAN and have no connection to the internet, one player has to host the game, the others have to join it by manually typing the hosters ip in the ip textbox. For hosting a game, port 4009 must be open for incoming TCP/IP connections. If the connection doesn't work, check your network configuration for that port being open.
Generell advices for staring a Game
For starting a game, all players have to set their state to ready. You can see the current state of each player by checking whether there is a [] (not ready) or a[*] (ready) behind his name. Furthermore, a map has to be selected, as well as a game mode. Afterwards, the map gets loaded. When you can see the map, it usually takes a few more seconds until the game really begins. The reason for that is that after all clients loaded the map, the game needs to be synchronized. That takes a few seconds. Besides, not all PCs load equally fast and you have to wait for the slowest.
Gameplay
You can move your soldier with WASD or WAXD. You aim with your mouse and fire with your left mouse button.
There are several different units on the playground. The green soldiers are your army. One of them are you. The human controlled soldiers have a blue circle beneath them as well as their name written above their head.
The main part of your enemies are bugs. They can be born from nests. You can increase the size of your army by taking reinforcement symbols. They are silver or gold blinking. If you die, you get reborn at a respawn point, if your army consists of more than 0 non human controlled soldiers. Otherwise, you loose. The goal of the game is to kill all enemies on the battlefield.
>You can give orders to the soldiers near to you. Have a look below for the possible commands. You can send a chat message by hitting enter, typing your message, and hitting enter again. You can also define hotkey messages on your number block. Before starting walkover, you can modify hotkeymsgs.txt to contain the messages you need often. While playing, you can send the predefined messages by just pushing the respective key on the number block.
Aftermath
After the game, you see, depending on the gamemode, more or less detailed statistics of the game. After closing that dialog, it takes some time until you see the chat dialog again. This is normal.Nach dem Spiel dauert es etwas bis das Menu wieder erscheint. Das Spiel ist dann nicht abgestürtzt, es dauert nur etwas. If someone could tell me how to accelerate glDeleteTextures(), this could be changed.
Key Reference
W up
A left
D right
S/X down
Q Soldiers nearby follow
E Soldiers attack the location where you point at with your mouse
C Soldiers defend the position they are standing at. They shoot
better than in normal mode, but don't move at all.
Y Set Soldiers back to normal behaviour state
R builds a laser tower
F builds a rocket tower
V builds a teleporter, beaming in support troops from time to time
Soldiers have to be around the construction site to finish the building.
The player soldier doesn't count.
ENTER activate chat mode
0-9 Hotkeymessages (Numberblock)
1-7 Choose skills after a level up
ESC Leave the game. Attention: If you host the game and leave a game,
all others stop playing the game, too!
The manual is.. slightly Germanified. Anyway, this next little bit is from me, this game may look kind of crap at first, but my god, it's the bloodiest thing you'll play. The multiplayer supports up to about 64 people, possibly even more if you tinker with it, and in a way, it's almost like a multiplayer version of Crimsonland, as, it has a bunch of weapons, the same controls, and perks when you level up. Yes, you level up, alas, there's only 7 perks, per say, and even then, they really aren't perks, but they do make the game much more enjoyable. Either way, it'd be cool if we could all get together and play this, considering your PC doesn't have to be godlike or anything.
Anyway.. here you go.
Download Link: Download
Postby T3chno » 2009.01.08 (07:01)
This looks awesome. I have got to try this out. We should totally do a MetaWalkover night where everyone comes in and plays.
Postby t̷s͢uk̕a͡t͜ư » 2009.01.08 (09:04)
Snuggletummy, GDubs, and I just spent, like, and hour and a half in the most epic fucking battle in this game.
Y'all should come on Vent, and we'll all pay together. In this game especially, the more, the exponentially merrier.
Postby Snuggletummy » 2009.01.08 (09:09)
Here, have a screenshot to go along with his post.. in my post..
During the match match every enemy spawner spawned 8 enemies at once, and the limit was 1000. The limit actually stops oh at about about... 10,000. Anyway, look at the screenshot, look at the ground.. at the start of the level, the ground was green..
This one is an example of about 10,000 enemies...
This one is basically a victory. Jiggerjaw, GamingWolf, blue_tetris, and I all played and won.
Postby smartalco » 2009.01.08 (21:41)
holy shiz that is a lot of blood, I'll have to DL this when I get back to KU (my PC is there)
Postby t̷s͢uk̕a͡t͜ư » 2009.01.09 (00:19)
smartalco wrote:holy shiz that is a lot of blood, I'll have to DL this when I get back to KU (my PC is there)
OK, sounds good. LI to Vent when you've DL'd it, and WC all probably try PI together.
Postby Geti » 2009.01.09 (14:06)
what an angry amount of gore..
i might get this, but im not sure how much time i'd end up burning, which i dont want to do at the moment ;)
God knows if i'm back.
Postby Luminaflare » 2009.01.12 (15:50)
<3 turrets
Postby blue_tetris » 2009.01.12 (16:58)
This game is a marvel.
Play it.
The Real N Sex on the Xerox Space Pimp Online Super Fluffy Pack 1! Super Fluffy Pack 2! Super Crunchy Pack! Mother Thumping Impossible: 2005 MotY! Time is on My Side: 2006 PMotY! Survival map king! Best humor award! Best satire award! Best voice award! Inadvertently intimidating! Assholier than thou! Gdubs is totally back! WIS 14! Cyberzone creator! Clique creator! Most lines on IRC! Ventrilo moderator and regular! Certified Dungeon Master! Most modest person ever! ENTP! Incorrigible alcoholic! CHA 19! AMERICAN! Least pretentious! Elitist extraordinaire! Liberal libertarian! Incapable of experiencing love! Check Safe! Commodore of the Eldritch Seas! Archmagus of the Eleventh Hall! Sheriff of the Uncharted West! Godfather of the IRC Mafia! Pun enthusiast! Quadster! Challenging Dunbar's number! Wikipedian!Approves of 4th Edition! 1,000 Blank White Cards! radio_free_tetris! Migratory! INT 18! Doesn't know when he's being genuine, therefore cannot form lasting relationships with people! Really into black chicks! Even more into Indian chicks and Blasians! Hates moderators! Loves the C word! Tronster! Thinks we should play more Worms! Always wins iSketch! Owns a Wii! Plays as Pikachu in Smash Bros! Wrote literotica! Wrote anime fanfic! Sorta into Asians! Lived and loved the 80's and 90's! Chattiest sig! Cyberzone ][ creator! Operand of the Greater Space Pimp Continuum! Helped lead the forum move!Wizard Date! Participated in the blue_tetris takeover! Pithiest one-liners! Walkin' on, walkin' on broken glass! Seems to have an invisible touch! Economist! Mario hackster! Owner of the most complex D&D campaign setting! Micromanagerial! FREEDOM is all-American! Slowly distancing! Supports the Democrats! Supports the old GOP! CATO Institute fanboy! Penn and Teller fan! Large, in charge, and on a barge! Heralded by community as genius hero! Proud yet humble recipient of the Mare & Raigan Award for 2008! CON 9! Dave of Nazareth! Communist is annoyed with me! Not half bad at images! F.Y.I. I am a medic! It's a spook house, lame ball. Too bad! Space Pimp II: Rags 2 Bitches! F.Y.I. I am a spy! Entire team is babbies! STR 10! Sorta appreciating scythe and atob again, for new reasons! Played CS:S briefly! Welcome to Nebraska! Do you think you can Live! Heist! Portrayer of the mighty 88 Shells! Joyous proprietor of the future estate of Kablizzy and blue_tetris! It's Batmen all the way up! They brought crystals to a sceince fight; that's a good way to lose your cat! Even SlappyMcGee! I'm about to run out of either primates or sexually transmitted diseases! One-upper! Toaster oven clairvoyant Mythomaniac! That's the Magic of Macy's! Half of Half! Spend all my time making love, all my love making time!
