Solutions for tricky levels in 2.0
Moderator: Oleary15
Postby Fnord » 2013.05.25 (00:46)
So in 2.0, you can only look at replays after beating levels, which adds a bit of puzzling flair.
But there are a few levels that leave the less-than-pro players like me a bit TOO puzzled. Starting out here with a5-4: I can hit all the switches that are immediately accessible, but how the heck am I supposed to get to the top two switches opening the bottom doors? Can't seem to find a jump that lets me grab the ledge below.
Postby EddyMataGallos » 2013.05.25 (00:54)
You mean those on the chamber? Those are fairly easy, check this:
Actually I just checked you can just stand on the door, jump and walljump on the left wall. If done properly you can reach the tunnel as well, although the iamges method is easier.
Postby Fnord » 2013.05.26 (02:17)
I do feel somewhat silly now - somehow, I managed to not get that jump right until I knew it was possible - then it was simple. Thanks!
And now... I'm kinda stumped on a9-4. I get to the top left switch easily, with lots of drone-time spare, but how the heck am I supposed to get down before they close everything off?
The Loneliest Number
Postby Ptolemy » 2013.08.12 (16:15)
Can someone explain how to get the switch up top on the left? I can get all the others.
NUMA Profile: www.nmaps.net/user/Vanquish
Postby Vanquish » 2013.08.22 (09:41)
Ptolemy wrote:Can someone explain how to get the switch up top on the left? I can get all the others.
here are a few options of what you could try. i think i went either the red or the green way. hope this helps
Postby EddyMataGallos » 2013.08.22 (16:51)
Did you test these? None of them work, with the red jump you cant reach the slope, with the blue one you can't reach the wall, and with the green one, well, I've managed to do it running from the very left of the map, but definitely not with that little run-up. Also its hard and definitely not recommendable. These are two proper ways to do it:
I of course recommend the yellow one, its the easiest by far, just run towards the slope, jump when you are on it, and when you reach the slope do a perpendicular leap.
The orange one is harder because after jumping you have to slow down or will crash against the mines.
Postby Vanquish » 2013.08.23 (14:14)
hmmm, i was sure at least the red one worked. sorry for misleading.
