Error When Submitting Maps
Moderators: Rose, Sunset
Alive
Postby Buckeye23 » 2009.07.25 (00:30)
Its says the map data must have a "|" in it, what does that mean?
Postby Pheidippides » 2009.07.25 (00:39)
The "|" separates the tile data from the object data. If you copy the map data directly from N's level data box, it should already contain the "|". Tile data comes first, so if you're only submitting a tileset, the "|" occurs at the end of the data, and is still necessary. (I think you need at least one object to submit a map anyway.)
Hope that helps.
Raigan and the Horse-Woman
Postby sidke » 2009.07.25 (00:40)
You probably don't have any objects in your map data.
Put a gold piece in an inconspicuous spot and try submitting it again.
Pheidi is on top of things. (Shouldn't you be out partying or something?)
Alive
Postby Buckeye23 » 2009.07.25 (00:52)
sidke wrote:You probably don't have any objects in your map data.
The code has a | separating the tiles and objects but it still wont submit.
Postby a happy song » 2009.07.25 (01:05)
Be sure you don't have anything either side of the map data. Raw map data only, not userlevel data.
You want it to look like this:
0000001110000000000000000000011100000000000000000000111000000000000000000001110000000000000000000011100000000000000000000111000000000000000000001110000000000000000000011100000000000000000000111000000000000000000001110?1100000000000000GK1110CA000000000000000B11111E000000000000000001QQQ1A00000000000000000Q000Q000000000000000000000001D0000000000000000000001E000000000000000000000000000000000000000000000000000000000000000000001D0000000000000000000001E000000000000000000000000000000000000000000000000000000000000000000001D0000000000000000000001E00000000000000O000O00000000000000000?1OOO100000000000000000C11111D000000000000000?E0111MI0000000000000011A0111000000000000000000001110000000000000000000011100000000000000|5^708,60!0^348,204!0^354,192!0^354,216!0^366,222!0^378,222!0^390,222!0^402,222!0^414,222!0^426,222!0^438,222!0^450,222!0^462,222!0^510,222!0^522,222!0^534,222!0^546,222!0^558,222!0^570,222!0^582,222!0^594,222!0^606,216!0^612,204!0^606,192!0^594,186!0^582,186!0^546,186!0^534,186!0^522,186!0^510,186!0^498,186!0^486,186!0^474,186!0^462,186!0^450,186!0^438,186!0^426,186!0^414,186!0^378,186!0^366,186!0^498,222!0^474,222!0^486,222!0^390,186!0^570,186!0^558,186!0^402,186!12^396,204!12^564,204!12^480,204!12^468,330!12^456,342!6^612,228,4,0,0,2!6^348,180,4,0,0,0!1^564,252!12^396,306!12^408,318!12^588,354!12^600,366!12^612,252!12^348,156!3^396,156!12^684,168!12^672,156!12^288,252!12^276,240!12^768,564!12^756,576!12^252,336!1^252,360!12^228,168!12^216,156!12^108,168!12^96,156!12^168,132!12^180,120!12^24,132!12^36,120!12^108,96!12^96,84!0^168,156!0^180,156!0^192,150!4^132,162,1!11^708,60,48,156!12^24,36!12^36,24
and not like this:
 $200: lightly seared on the reality grill#astheoceansblue#none#0000001110000000000000000000011100000000000000000000111000000000000000000001110000000000000000000011100000000000000000000111000000000000000000001110000000000000000000011100000000000000000000111000000000000000000001110?1100000000000000GK1110CA000000000000000B11111E000000000000000001QQQ1A00000000000000000Q000Q000000000000000000000001D0000000000000000000001E000000000000000000000000000000000000000000000000000000000000000000001D0000000000000000000001E000000000000000000000000000000000000000000000000000000000000000000001D0000000000000000000001E00000000000000O000O00000000000000000?1OOO100000000000000000C11111D000000000000000?E0111MI0000000000000011A0111000000000000000000001110000000000000000000011100000000000000|5^708,60!0^348,204!0^354,192!0^354,216!0^366,222!0^378,222!0^390,222!0^402,222!0^414,222!0^426,222!0^438,222!0^450,222!0^462,222!0^510,222!0^522,222!0^534,222!0^546,222!0^558,222!0^570,222!0^582,222!0^594,222!0^606,216!0^612,204!0^606,192!0^594,186!0^582,186!0^546,186!0^534,186!0^522,186!0^510,186!0^498,186!0^486,186!0^474,186!0^462,186!0^450,186!0^438,186!0^426,186!0^414,186!0^378,186!0^366,186!0^498,222!0^474,222!0^486,222!0^390,186!0^570,186!0^558,186!0^402,186!12^396,204!12^564,204!12^480,204!12^468,330!12^456,342!6^612,228,4,0,0,2!6^348,180,4,0,0,0!1^564,252!12^396,306!12^408,318!12^588,354!12^600,366!12^612,252!12^348,156!3^396,156!12^684,168!12^672,156!12^288,252!12^276,240!12^768,564!12^756,576!12^252,336!1^252,360!12^228,168!12^216,156!12^108,168!12^96,156!12^168,132!12^180,120!12^24,132!12^36,120!12^108,96!12^96,84!0^168,156!0^180,156!0^192,150!4^132,162,1!11^708,60,48,156!12^24,36!12^36,24#
Alive
Postby Buckeye23 » 2009.07.25 (01:15)
I Dont, nothing on either side.
Postby sidke » 2009.07.25 (01:23)
Could you pastebin the code, maybe then we can try to see what's wrong.
http://www.pastebin.com/
Alive
Postby Buckeye23 » 2009.07.25 (01:34)
Postby sidke » 2009.07.25 (01:48)
Okay, here's the working version: http://pastebin.com/m2462298c
What atob said is half true. You can have the stuff around the data, but make sure it's all there. Your data had the left side, but didn't have the closing '#', and that's what messed it up.
Alive
Postby Buckeye23 » 2009.07.25 (01:50)
Thank you soooo much!
also what do u think of the level?
Postby Pheidippides » 2009.07.25 (03:10)
sidke wrote:Shouldn't you be out partying or something?
I think we all saw that I already had my party, right here at Metanet. XD
