problem with visual display on opened windows
Postby Radium » 2010.01.07 (03:32)
well i recently got a laptop with windows 7 and i realized recently that all my windows that i open up look messed up:
this is a recent issue..
Postby SlappyMcGee » 2010.01.07 (03:44)
Moved.
Raigan and the Horse-Woman
Postby sidke » 2010.01.07 (05:15)
Try this.
Go to the start menu, type in 'aero'. Click on 'Find and fix problems with transparency and other visual effects'.
It'll open up a window, click next. It'll go through a bunch of stuff on its own, checking your video card and such.
If that doesn't work, you can try turning off transparency by right-clicking your desktop, then clicking on personalize. Go to 'Window Color' at the bottom and uncheck 'Enable transparency'.
If /that/ fails, make sure you restart... and if it's still not working, consider getting a new video card.
Postby Vyacheslav » 2010.01.07 (13:59)
Before considering getting a new card, updating the drivers first is a much better, cheaper solution.
Postby Radium » 2010.01.07 (15:23)
sidke's method did the trick. thanks guys:)
Postby sidke » 2010.01.08 (08:36)
87654321 wrote:Before considering getting a new card, updating the drivers first is a much better, cheaper solution.
Windows 7 does a pretty good job of automatically getting the latest drivers for a lot of stuff, especially video cards.
That is as long as automatic updates are on.
Also, glad it works, Radium :)
