Xbox 360 Controller?
Moderator: Oleary15
- Octave
Has anyone had any luck setting up the xbox controller to work with N2? I have such an easier time wall jumping with a controller in N+ I thought it might help. Thoughts?
Try JoyToKey. It will allow you to play Nv2 with your controller, but I'm not sure if it will help you with walljumps because (as far as I know) N+ has input buffering (allowing you to press jump before you reach a wall and still perform a walljump) and Nv2 doesn't.
- Octave
Ah. Ok! That makes a lot of sense. I was going to say it seems so much easier in N+. I think my brain is having trouble switching back and forth.
