ModMaster v1.4 *** Dronie Award :: Program Of The Year ***
- MBTI Type: ESTP
(I've never designed a functional site before, if anyone would like to help me out or teach me some basics, it would immensly speed up the process, and help me out a lot!
the only thing i can see is to make it a little more clear on what you should replace the x, y, path etc... with
that would help
Thought I'd make this section look a little nicer for ya. ;Dkkstrong wrote:On the objects/drones that you can code individually on:Note: I have entered in the default values for all of these. If you calculate code with these given values, the object will appear normal in NReality.
- You will only be able to do one line at a time. To make several of these objects in a map simply:
- Enter in Values in each text box (note: if you leave a text box blank, it will not crash the program, the program will just simply ignore it)
- Press the "Calculate Code" Button
- Copy and Paste given code, and replace words with correct values
- Repeat until desire is fulfilled (what will happen is the code will just be replaced)
On objects/drones that you cannot code individually on:
- You will only be able to calculate one mod at a time. To use this function:
- Choose Mods you would like to use. By checking the boxes, you will turn off the read-only function assigned to the text boxes, and you will be able to write in the text boxes. ( you can see the readonly function is marked by a slightly bluish tint)
- Enter in values for boxes.
- Press the "Calculate Code" Button.
- Copy and Paste given code, and replace words with correct values.
If you would like to do this several times, remove the values of "x,y,path" and replace them with desired code.- Repeat until desire is fulfilled (what will happen is the code will just be replaced)
- MBTI Type: ESTP
- MBTI Type: ESTP
http://www.box.net/shared/6kk2thvl4k
- Triforce
take out the check boxes
make the link in the playermods tab work
have the ! that you have to put in automatic
put a direction,and a path dropdown arrow
have a x and y coordinate box and
explain how to put in multiple things that start with a | and have them all work
- MBTI Type: ESTP
As for the other suggestions, I'll consider em.
- Triforce
- MBTI Type: ESTP
- MBTI Type: ESTP
- MBTI Type: ESFP
<3kkstrong wrote: - Hyperlink in playermods sections working
- Member
- NUMA Profile: http://nmaps.net/user/n0_ma11y
- Member
- Oops Pow Surprise
What is the Framework thing supposed to do to help me? I'm running an XP by the way.
||||122,_icon,^^http://img189.imageshack.us/img189/9536/cannonball.png|#
but it generates this instead it has the wrong number for tile-drone and many of the other mods
||||0,_icon,^^http://img189.imageshack.us/img189/9536/cannonball.png|#
Also when you add a pathing mod to something which already has multiple ^ it then gives you to many ^'s befor the pathing section you should fix this cause it took me ages to work out what I was doing wrong when I first started modding.
Thanks for this program it's really useful good work
- Maxwell Smart
- NUMA Profile: http://www.nmaps.net/user/ninja_matt
- Oops Pow Surprise
- Ego Lancer
I even haven't downloaded the latest ModMaster version....yet. But I'll say, it's a lot easier now making codes for Nreality this time!
Shortest: Y
- Triforce
- NUMA Profile: http://nmaps.net/user/rubberninja
- MBTI Type: ESTP
Also ~~800 downloads~~
- Triforce
yeah, i know, but i mean which file when i download it.kkstrong wrote:It is on the first topic of this post. Please read before posting next time.
- MBTI Type: ESTP
