Confirmed.vankusss wrote:@66-4: what is happening? is the earth changing it's rotation? this is wroooong
EDIT: world order restored
Metanet 0ths Thread
On a side note Eddy and I both took 0ths that ended on .400 with a .525 run. that's a pretty weird coincidence (one in 1600 chance in fact)
Smoooth. Nice cleaning up there.xaelar wrote:Confirmed.vankusss wrote:@66-4: what is happening? is the earth changing it's rotation? this is wroooong
How'd you get that number ska? Did you take into account that you both had to take a 0th that ended in .400, and not just that you both improved by the same amount? If not, then that puts the odds even higher. :)ska wrote:On a side note Eddy and I both took 0ths that ended on .400 with a .525 run. that's a pretty weird coincidence (one in 1600 chance in fact)
Well, the chance of a run ending in exactly .400 is 1 in 40 (since there are 40 frames per second during N gameplay, but it's more about the fact that there were two 0ths that ended in the same digits, more on this later)golfkid wrote:How'd you get that number ska? Did you take into account that you both had to take a 0th that ended in .400, and not just that you both improved by the same amount? If not, then that puts the odds even higher. :)ska wrote:On a side note Eddy and I both took 0ths that ended on .400 with a .525 run. that's a pretty weird coincidence (one in 1600 chance in fact)
then for both of the improved runs to end in .525 is once again 1 in 40. (40 x 40 = 1600)
However if you want to factor in the improvement time being exactly the same it would be even less common, however, it wouldn't be that much more since taking a 0th by over 1 second at a time isn't very common these days anyway. As for both taking a run that ends in .4 this is kind of redundant, since it's more about the fact that both 0ths were the same rather than the time itself, hence it's irrelevance. Think of it this way. The chances of rolling double 4s on a pair of fair, 6 sided dice is 1 in 36, but if you change the event to "The chances of rolling doubles" the chances are improved sixfold since it doesn't matter what the first roll is as the 2nd roll is independent and each number is just as likely (say if the first roll was a 2 for instance) then the chances of the 2nd dice being rolled a 2 as well is only 1 in 6. I'm sure most of you guys will have learned this in primary school maths but it can be a confusing concept nonetheless. Wow, I wrote a lot then; I hope it makes sense.
Wow O.Oxaelar wrote:Confirmed.vankusss wrote:@66-4: what is happening? is the earth changing it's rotation? this is wroooong
Didn't know 66-2 had that much left either, nice.
88-4, your turn. It was quite lucky, i got it after like 20 mins. I was quite scared at the end, this lvl will bring me heart attack some day.
Attention: Order is not restored and the world is in fact coming to an end. xaelar beat Izzy on a chimney map, and 88-4 is now a frame war map O.ovankusss wrote:I didn't know 66-4 had that much left, nicely done. But still, my innov > yours :D
Sick runs guys. I am loving the newly heated competition between xaelar and van. /me has a sneaking suspicion that there will be more dronie worthy runs coming out in the next two months.
What's the definition of dronie run?
I was talking about runs that are worthy of the Dronie for "Run of the Year." So far I think 49-2 and 88-4 are for sure going to be nominated. I am sure there are other great runs I am forgetting and some NUMA ones I haven't seen yet. EDIT: Meta's 79-4 could be the "Almost Run of the Year"vankusss wrote:I hope xaelar will stand up to his words about not playing it again, since i'm loosing on all other fronts. Well i'll just wait 2 weeks before blur is over and then try to leave for the third time :D
EDIT2: You are a beast xaelar! Where will the 88-4 progress end?!?! Raif your MBD lead is dwindling. Lol :D
i guess it's mutual, thxxaelar wrote:You, vankusss, are a legend in my eyes, when it comes to highscoring.
159 is way too much :( something new or just cleaning? i'll try more, i was prepared to spare far more than those 20mins on this anyway (that was a sheer luck)
In your run you probably could have made it over the first drone, but I guess since the ball is in your court van that is the next step towards 160 :P Beat that drone.xaelar wrote:Nothing new, just cleaner. Submitted now.
Do i have to expect another great one coming? I can't wait to see someone get 160 on MTI :P
I love ending framewars with 1+ seconds innovs (raif ones, this time), so no i don't :Pxaelar wrote:You don't feel guilty now, do you?
Nice run there van ;D
thx, i was expecting you to clean it up, so i was waiting with my response
dunno if you can expect me on 88-4 again, but probably yes (i once died at 1400 frames at the start of second to last jump); i also haven't watched your run yet, because that would depress me
whoah that's ultra-cool, i never expected that run to be beaten, at least not by that muchxaelar wrote:88-1 from trib4l, but I'm not going for ep ownage ;D
your messed climbing up on the right
i'm really surprised though, it doesn't seem so fast
edit: i'm also not convinced that doing that cs is faster, i think that you can just start climbing from there without coming back to floor
- RoboBarber
That's amazing, really. For me, it was one of the hardest 0th. And the oldest one.xaelar wrote:88-1 from trib4l, but I'm not going for ep ownage ;D
Ep 47 was ranked 97th out of all of the Episodes, Now it is ranked 50th. In one 0th. Nice Hendor.Izzy wrote:Hendor took ep 47 by a nice margin.
I took 47-4 by 3 frames.
Also great run Izzy, L3X bites the dust.
