Post a Run!
Postby vankusss » 2010.10.15 (21:29)
176-3 sr, that felt good
EDIT: 176-1 sr, too
Postby ska » 2010.10.17 (04:19)
ToeFaceKiller wrote: 653 sr - complete luck at the end
You make your own luck, unless you're TFK in which case, luck makes you.
Postby Kool » 2010.10.19 (22:04)
taken
Postby golf » 2010.10.21 (01:14)
206713 hs. I like my run, and its on a great map to boot.
Postby vankusss » 2010.10.22 (14:26)
golfkid wrote:206713 hs. I like my run, and its on a great map to boot.
I don't get that boot part.
I don't.
Get it.
-- vankusss
Postby Izzy » 2010.10.24 (20:28)
188-3 sr improved
47-3 sr taken, can still be improved by a lot
Postby golf » 2010.10.28 (17:16)
206991 sr. After a hard day's work going as fast as he can through a level, the ninja deserves to take a rest.
Postby Kool » 2010.10.29 (02:18)
10-3 taken, as well as 194-0(nice innov OOJ, btw) and -3 sr
also 3-0 hs taken, subbed on request from gk. Tho my ending is fucked because of the damn drone :/
Postby xaelar » 2010.10.29 (11:10)
Nice 3-0 Kool! The key part was very clean.
I took 194 ep, 0 and 1 speedrun :D
Postby glib_jase » 2010.11.02 (21:27)
132-1. Was so glad when the drone went down towards the switch and not up towards the exit at the end.
Postby Kool » 2010.11.07 (00:00)
35-2 and 57-0 sr
improvable
Postby TheRealOne » 2010.11.07 (16:22)
Kool wrote:57-0 sr
Nice! About time as well. I mentioned that innovation like 2 years ago, but everyone said that second cj would be too hard. Great run!
Kool wrote:57-0 sr
Postby Izzy » 2010.11.08 (02:49)
66-4 sr with innovation on the ascent. Sloppy ending ftl.
NUMA Profile: http://nmaps.net/user/Ferox%20
Postby Ferox » 2010.11.08 (16:20)
After 7 minutes of some frustration, I got 16th on 192-0.
Postby Raif » 2010.11.08 (17:45)
Ferox wrote:After 7 minutes of some frustration, I got 16th on 192-0.
You need to try harder.
Postby Ferox » 2010.11.11 (13:34)
I did. I am now 5.
Lucky
Postby demodominator » 2010.11.14 (12:29)
I like this: 207670
good luck beating that..
I'm speeddemosnatos, call me speedy.
Postby xaelar » 2010.11.15 (17:33)
136665 speedrun.
Postby Ferox » 2010.11.18 (02:36)
Finally did a bounceblock corner jump.
Postby jasdanu » 2010.11.18 (02:48)
3371
This is a slow demo but i love that cornerjump on this run. highscore and speedrun.
Sig: Izzy
Postby ari22hoops » 2010.11.27 (20:12)
126-3 highscore
Edit: It seems xaelar has taken that run from me. Again.
Postby 大見解 » 2010.11.27 (22:11)
waaaa
meta_ing on 145535 hs
Postby ska » 2010.11.28 (00:14)
大見解 wrote:waaaa
omg
Postby xaelar » 2010.11.28 (13:58)
504 speedrun
