110-2 help?
Tetris
NUMA Profile: http://nmaps.net/user/randomviewer896
Postby randomviewer896 » 2010.10.21 (05:29)
I cant beat level 110-2
Can someone explain the awkward timings necessary for this overly challenging level?
Thanks
Gross
Postby BluePretzel » 2010.10.21 (06:46)
Check out the highscores under 'speedrun', and click the lowest score. Chances are, it'll show you a nice and easy way to complete it.
EDIT: The demo by bcut looks simple. Also, good work on coming so far!
~By me
~By UniverseZero
~By Slick265
4 Mappacks, 1 comic:
<CLICK>
<transcendence!>
Postby Kablizzy » 2010.10.21 (07:24)
One of these columns is not like the others... One of these columns just isn't the same...
Postby 大見解 » 2010.10.21 (11:01)
that column is the NReality death column. Insane to pass, satisfying to pass too.
Alot like the guy who made the whole column, that guy.
Postby mathy » 2011.08.11 (12:12)
This is just about impossible.
1.Do a very quick wall jump on the switch.
2.Go to the far left then jump onto the raised platform.
3.You should have a sufficient run-up. Do a corner jump to get onto the platform then simply jump up.
4.Run very fast but slow down after a 'skipper' gap. Get the switch.
5.This is the hardest part and relies mostly on luck and precise skill. Run back but make sure that you do not get hit by a mine. Can someone tell me how not to get hit by a mine?
6.A simple jump to the terminal switch(es).
7.Mine jumper.Easier said than done. Need help.
7b.Just jump carefully then 4 in reverse.
Postby mathy » 2012.08.13 (14:24)
Col11 is the hardest, closely followed by col10.
NUMA Profile: www.nmaps.net/user/Vanquish
Postby Vanquish » 2012.10.04 (12:37)
that level is pretty hard, but once you get the flow of it, it can be easy. so far ive only gotten up too 115-3 but yeah, 100 and 110 are the hardest columns in nreality.
