MAPDRAFT (x_x)
Postby Rose » 2011.02.21 (16:21)
Yes. The amounts stack up.
Postby Rose » 2011.02.22 (18:31)
Okay, I'm sending out the packs myself. I don't have the program that PALEMOON does, so I'm having to distribute each pack manually one-by-one. Please be patient. As soon as you receive your packs, you're welcome to post your maps. Make sure you tag your map with 'mapdraft,' otherwise it will not be judged.
Postby koipen » 2011.02.22 (19:12)
Are exits included in packs automaticly, or are they only there if mentioned? Can I fill any space that is not filled by the tiles in the pack with any tiles I want?
NUMA Profile: http://nmaps.net/user/sayko
Postby sayko » 2011.02.22 (19:17)
I've received my packs. 3 of them are paling me about tiles. But i'm confused about especially one of them. CLICK to see thoes packs.
My Cup Runneth Over by kkstrong
Rule
If Applicable, multiply the number of tiles of each type you are assigned by 3. If you
cannot do this because it causes more than 713 tiles in the map, ignore this rule for
that specific tile.
Life247 is the coolest. by Life247
X 'E' tiles
X Gold
'X' is equal to your age.
Scapeshift
Tiles
Use the Tiles of your most recent map posted on NUMA (BEFORE this round started) for
your mapdraft map this round. Any tiles you receive in your booster pack remain the same.
First pack says "every type of tiles will be a multiple of 3" and second one says "24 (my age) E tiles. 24 is a multiple of 3, so no problem with these 2 packs.
But the third one says "use your last map's tiles". So what should i do? Do i have to ignore other packs' rules about tiles? Or to add my recent map's tiles 23 more E tiles (i've used in that map only one E tile)?
Postby atomizer » 2011.02.22 (20:08)
sayko wrote:First pack says "every type of tiles will be a multiple of 3" and second one says "24 (my age) E tiles. 24 is a multiple of 3, so no problem with these 2 packs.
First pack should be considered last, because it's a "general" rule (if I got it right). If so, the second pack gives you 24 E tiles and 24 gold. The third pack gives you one more E tile, 25 total. The first pack brings this to 25 * 3 = 75 E tiles. So, you should use 24 gold pieces and 75 E tiles.
Postby Rose » 2011.02.23 (01:45)
koipen wrote:Are exits included in packs automaticly, or are they only there if mentioned? Can I fill any space that is not filled by the tiles in the pack with any tiles I want?
You get exactly one exit unless one of your packs specify otherwise (for example, I know at least one pack exists that gives you 5 exits. In that case, you would have to use exactly 5). Same thing applies to ninjas. You can only use the tiles allocated to you in your packs; everything else MUST be blank.
Rule
that specific tile.
X 'E' tiles
X Gold
Scapeshift
Tiles
Multiply your tiles from your last map by 3, as well as multiplying whatever other tiles you got.
Some of you have received your packs and some haven't. I'm getting them to the rest of you as quickly as I can when I'm not doing homework etc.
Postby Erik-Player » 2011.02.23 (02:33)
YO BRO GET ME ON THAT LIST or i'll die. I love you. Not really. Yeah. No i do. No really.
Postby trance » 2011.02.23 (14:41)
I want to try this out. Sounds very interesting.
Sig by Aidiera.
My Accomplishments
I have 167 speedrun Episode Top-20s and I'm 4th on the boards. :D
NUMA Profile: http://nmaps.net/user/lsudny
Postby lsudny » 2011.02.23 (19:08)
Where do I receive the packs? Here, on the forums?
soundcloud | facebook
That is why I decline the title of Iron Cook and accept only the lesser title of Zinc Saucier, which I just made up. Also, it comes with double prize money!
Postby trance » 2011.02.23 (19:34)
Is it too late too join?
Sig by Aidiera.
My Accomplishments
Postby zoasBE » 2011.02.23 (22:56)
I have not received my packs.
Where do I get?
just as friends as enemies
even fewer friends
Postby ENT474 » 2011.02.23 (23:02)
I hope it's not too late for me to join.
Anyways, good luck everybody.
Postby Pheidippides » 2011.02.24 (02:04)
Just got my packs. When are the maps due?
Postby Rose » 2011.02.24 (04:12)
lsudny wrote:Where do I receive the packs? Here, on the forums?
Yeah, you'll get them via PM.
zoasBE wrote:I have not received my packs.
Where do I get?
I wrote:Some of you have received your packs and some haven't. I'm getting them to the rest of you as quickly as I can when I'm not doing homework etc.
1211 wrote:Is it too late too join?
You, Erik, and anyone else will be added starting next round. This is an indefinitely continuing thing, so it's not an issue to join after Round 1. In other words, this isn't a tournament or anything.
Pheidippides wrote:Just got my packs. When are the maps due?
Well, since I've been late getting out the packs, I'll give you guys until Mon. March 7. That'll give even the last people to receive the packs a good week and some change.
Postby ENT474 » 2011.02.25 (05:05)
Have I been added?
Postby Rose » 2011.02.25 (16:36)
ENT474 wrote:Have I been added?
You're in starting with Round 2.
NUMA Profile: http://nmaps.net/user/apse
Postby aapse » 2011.02.25 (17:22)
hmmm.
is there a rule regarding starting a map full of tiles or starting a map with no tiles at all (i.e. pressing H or J in the debug menu)?
i have an exceptionally gay pack which requires me to use 20 D tiles which, if starting with a blank map, is rendered useless.
what can i do?
Postby Rose » 2011.02.25 (17:29)
aapse wrote:hmmm.
what can i do?
The point of that pack IS that it's useless. Sorry. :p Basically, it's a tile pack that gives you nothing.
OKAY, SO EVERYONE SHOULD HAVE THEIR PACKS BY NOW. It's long overdue, I know. You all have until MONDAY, MARCH 7. Good luck. If for some reason you don't have your packs, just post here or PM me and I'll get them to you.
Also, I know I didn't say this before, but it would help if you posted the packs you had to use for your map either in your map description, in a comment on your map, or in this thread. Not only does this make it easier for me, but the other judges can't see my PMs.
Postby aapse » 2011.02.25 (17:32)
eevee wrote:The point of that pack IS that it's useless. Sorry. :p Basically, it's a tile pack that gives you nothing.
right ._.
Postby Rose » 2011.02.25 (22:25)
right ._.
Heh, I didn't make the pack. You'll have to take it up with PALEMOON if you don't like it :p
Postby Avatar_Fanatic » 2011.02.26 (10:28)
How many rounds will there be? (This is really fun so far!) :D
Postby 大見解 » 2011.02.26 (16:01)
I do not have a pack.
Postby zoasBE » 2011.02.26 (18:15)
My Packs are insane !!!
Just not enough people. by erik_player
Items
4 Ninjas.
25 gold.
1 chaingun drone.
1 locked door.
Trembling Heart by Diamondeye
Rule
All enemies besides Mines must be placed so that they only influence the optional
routes in the map (there must be a "safe" way thru the map).
Octane by kkstrong
Tiles
80 'E' tiles
8 '1' tiles
8 '2' tiles
8 '3' tiles
8 '4' tiles
8 '5' tiles
8 '6' tiles
8 '7' tiles
8 '8' tiles
Pick Your Poison
Booster
15 Floorguards and 1 'Seven' Tile
OR
15 Thwumps and 1 'Three' Tile
Questions:
1. I have to use the 4 packs in the same map, right?. And I can not use anything more than what they ordered, right?
2. In Trembling Heart by Diamondeye: The safe route can be solely and exclusively to complete the map. The gold I can include in the non-secure route would be the AGD route with enemies?
even fewer friends
Postby Rose » 2011.02.26 (19:00)
Avatar_Fanatic wrote:How many rounds will there be? (This is really fun so far!) :D
This will continue on as long as possible. :D
大見解 wrote:I do not have a pack.
D: I'll send them to you as soon as I'm done with this post.
zoasBE wrote:My Packs are insane !!!
Items
4 Ninjas.
25 gold.
1 chaingun drone.
1 locked door.
Rule
Octane by kkstrong
Tiles
80 'E' tiles
8 '1' tiles
8 '2' tiles
8 '3' tiles
8 '4' tiles
8 '5' tiles
8 '6' tiles
8 '7' tiles
8 '8' tiles
Pick Your Poison
Booster
OR
Questions:
1. Yes.
2. Sure, you can do that. As long as there's a non-threatening way through the map, you're all good.
Postby 大見解 » 2011.02.27 (15:22)
Bam. subbed yesterday. Thanks gloomp for the bounceblocks :3
