Nhigh : do you guys want new functions ?
- RoboBarber
It corrects some glitches, like top20 and Kool's issue on 10-3.
- Attachments
- NHigh.zip
- Version 2.0.3 Corrected
As of 04.03.2012 - (62.81 KiB) Downloaded 376 times
- RoboBarber
Thanks. If you don't mind, please download the new one, apparently the other has a small bug. (I replaced it right after you've downloaded it)EddyMataGallos wrote:Thanks for the new version and for your incessant effort on improving this amazing software :D
(the bug in question was here for months, so shouldn't be so important. Just discovered it^^)
Also could I get a version with out this formatting:
03-1 - Old: [ xaelar, 156.375] New: [ Kool-aid, 156.850]
03-2 - Old: [ xaelar, 161.975] New: [ Kool-aid, 162.125]
I'll give this a shot for the next rankings, but I think they may look a bit odd, or maybe that is just me and I'll ask everyone what they think.
- RoboBarber
Ok. I changed the way the configfile is saved (now it's binary). Works perfectly on xp and mac (yes!). I hope it will work for you too.TheRealOne wrote:Hey so I am having an issue with the newest version. I can't get the ignore list to work. I have tried deleting the complied lib and resaving the lib and then running it.
For the format thing, you can now open nhigh.pyw with a text editor, and put COLUMN_REP = 0 instead of 1 on line 33. Save and launch again and you'll have the old representation.
(I don't wanna put that in config file or whatever, you are not supposed to change it every day)
Tell me if anything goes wrong.
PS : this version might have some new functions, like player's comparison with...
PPS : to be sure the ignore list is working, try :
-download
-save
-quit nhigh & launch again
-load
I don't know why it misses some players sometimes.
- RoboBarber
HERE IS A CORRECTION.
- Attachments
- NHigh.zip
- 18.03.2012
- (38.34 KiB) Downloaded 378 times
Hooray! Thanks eru! :Deru_bahagon wrote:THE LATEST VERSION HAS ERRORS. It wasn't correctly ignoring cheaters.
Edit: is it meant to be aligned like this?
In any case, it seems to work well so far... :P
- RoboBarber
And yeah, it seems to be aligned like this (see my post on page 3, at 2/3 of the page).
I did it because when you have a lot of infos, it is a lot more readable if it has some kind of columns (this was actually your suggestion).
Basically, players are represented over 14 characters (or more if needed, but it is enough for 95% of the players and all the active ones).
If you don't like it, you can open nhigh.pyw with text edit (or something to read text on windows), and change COLUMN_REP to 0. (at the beginning of the program)
If many of you don't like it, I will change that for next version, so tell me!
And so vankusss lost ep ownage on 48 ^^
It takes a little getting used to, but yeah. Nice! I vaguely recall suggesting this and had some deja vu seeing the alignment (thinking i'd read a post regarding it, which obviously I had, otherwise, why would there be a connection ;) Good job :Deru_bahagon wrote:@ska : ok
Edit: just reviewed your old post (and saw what you wrote about column structure, me, darkshadow etc (14chars) and it came back to me. Thanks for the update. It now finally seems perfect to me! :) Congratulations on being awesome!
By partially ep ownage I mean episodes in which you have a level left to ownage, 2 levels left to ownage, 3 levels left to ownage, etc. Do you think this could be possible?
Oh btw new version works perfect for me too, and new style is great :D
- RoboBarber
EDIT: However you may want to add something that detects tied Ep ownage. Like Ep98. van has 0th on all, but -1 where he tied xaelar for 0th. So maybe like an astrix next to his name in the ownage section. Or however you want to denote it.
- RoboBarber
Oh yeah, didn't think about that. I basically took the first entry on the board.TheRealOne wrote:Eru that is awesome. Well done. I love it.
- RoboBarber
And congrats for the all the 0ths. I do enjoy watching them. 35-3 was a huge cleaning.
- Attachments
- NHigh.zip
- Version as of July 28th 2012
- (63.67 KiB) Downloaded 414 times
And thanks =D
Eru's latest version seems to be corrupted for me. Maybe something that happened when the forums moved?EddyMataGallos wrote:Thanks a lot, it works perfect for me :D And don't worry about not posting, after all, I can't think of anymore to add to this beast!
And thanks =D
Can you post your copy Eddy?
- Attachments
- NHighPlus12.07.28.zip
- By eru_bahagon.
- (63.67 KiB) Downloaded 199 times
Ah, thanks that works perfectly.EddyMataGallos wrote:Sure, here you have.
Any ideas what I did wrong?
Old 0ths on board
00-1 - Old 0th: [ Johnny_faneca, 135.375] Current 19th: [ swipenet, 135.275]
00-2 - Old 0th: [ trib4lmaniac, 110.550] Current 19th: [ Afterthought, 110.225]
00-4 - Old 0th: [ trib4lmaniac, 102.175] Current 19th: [ thedupli, 102.000]
01-1 - Old 0th: [ trib4lmaniac, 198.350] Current 19th: [ trib4lmaniac, 198.350]
02-3 - Old 0th: [ clux, 73.050] Current 19th: [ Mr_Lim, 72.925]
03-4 - Old 0th: [ glupi_zmaj, 117.450] Current 19th: [ johnny_faneca, 117.425]
04-0 - Old 0th: [ trib4lmaniac, 215.550] Current 19th: [ trib4lmaniac, 215.550]
04-1 - Old 0th: [ Unsane, 128.325] Current 19th: [ Unsane, 128.325]
04-3 - Old 0th: [ Johnny_faneca, 217.375] Current 19th: [ Hendor, 217.275]
04-4 - Old 0th: [ johnny_faneca, 141.775] Current 19th: [ swipenet, 141.300]
05-2 - Old 0th: [ clux, 82.900] Current 19th: [ johnny_faneca, 82.875]
05-3 - Old 0th: [ Knu, 121.475] Current 19th: [ glib_jase, 121.050]
06-0 - Old 0th: [ Johnny_faneca, 173.200] Current 19th: [ xdude_, 173.050]
06-2 - Old 0th: [ Melchoir79, 194.775] Current 19th: [ glib_jase, 192.150]
07-2 - Old 0th: [ johnny_faneca, 132.075] Current 19th: [ Fenneth, 129.775]
07-4 - Old 0th: [ spect, 148.000] Current 19th: [ spect, 148.000]
08-1 - Old 0th: [ jg9000, 182.350] Current 19th: [ 1211, 182.250]
09-0 - Old 0th: [ scorpio11883, 175.025] Current 19th: [ Hendor, 174.750]
09-3 - Old 0th: [ blobglob, 99.275] Current 19th: [ DJ_M, 99.150]
09-4 - Old 0th: [ clux, 125.050] Current 19th: [ xdude_, 123.800]
10-0 - Old 0th: [ clux, 118.075] Current 19th: [ johnny_faneca, 118.050]
10-1 - Old 0th: [ clux, 158.450] Current 19th: [ clux, 158.450]
10-4 - Old 0th: [ spect, 116.925] Current 19th: [ n22bs, 116.875]
11-0 - Old 0th: [ Melchoir79, 150.600] Current 19th: [ glib_jase, 148.425]
11-1 - Old 0th: [ scorpio11883, 125.625] Current 19th: [ me_is_fob, 125.525]
11-2 - Old 0th: [ trib4lmaniac, 120.975] Current 19th: [ glib_jase, 120.675]
12-0 - Old 0th: [ trib4lmaniac, 152.425] Current 19th: [ trib4lmaniac, 152.425]
12-1 - Old 0th: [ trib4lmaniac, 151.650] Current 19th: [ Botnim, 151.275]
13-0 - Old 0th: [ scorpio11883, 122.275] Current 19th: [ Unsane, 122.200]
14-4 - Old 0th: [ johnny_faneca, 117.175] Current 19th: [ 7aMaDX, 117.075]
15-3 - Old 0th: [ scorpio11883, 102.725] Current 19th: [ wedgie123, 102.600]
16-1 - Old 0th: [ scorpio11883, 93.200] Current 19th: [ scorpio11883, 93.200]
16-3 - Old 0th: [ clux, 179.975] Current 19th: [ johnny_faneca, 179.775]
16 - Old 0th: [ Johnny_faneca, 246.150] Current 19th: [ Jaclaw_PL, 244.500]
17-1 - Old 0th: [ johnny_faneca, 141.950] Current 19th: [ Mongy, 141.775]
17-2 - Old 0th: [ Sammage, 109.500] Current 19th: [ Decestation, 109.475]
18-0 - Old 0th: [ spect, 127.700] Current 19th: [ glib_jase, 126.825]
18-1 - Old 0th: [ johnny_faneca, 120.300] Current 19th: [ Hendor, 119.175]
18-2 - Old 0th: [ trib4lmaniac, 155.100] Current 19th: [ trib4lmaniac, 155.100]
19-1 - Old 0th: [ johnny_faneca, 187.075] Current 19th: [ joe1284, 186.925]
19-2 - Old 0th: [ trib4lmaniac, 156.625] Current 19th: [ Afterthought, 155.800]
19-4 - Old 0th: [ Afterthought, 182.750] Current 19th: [ Titan, 177.700]
20-3 - Old 0th: [ trib4lmaniac, 160.000] Current 19th: [ Thunder_Mute, 159.625]
21-1 - Old 0th: [ trib4lmaniac, 126.000] Current 19th: [ lookatthis, 125.900]
23-3 - Old 0th: [ Johnny_faneca, 173.325] Current 19th: [ xaelar, 173.075]
24-2 - Old 0th: [ trib4lmaniac, 107.925] Current 19th: [ DeadRabbit, 106.125]
25-0 - Old 0th: [ glupi_zmaj, 116.600] Current 19th: [ glupi_zmaj, 116.600]
25-2 - Old 0th: [ trib4lmaniac, 81.875] Current 19th: [ clux, 81.850]
25-4 - Old 0th: [ glupi_zmaj, 158.525] Current 19th: [ glupi_zmaj, 158.525]
26-1 - Old 0th: [ Toad, 83.725] Current 19th: [ Toad, 83.725]
26-2 - Old 0th: [ johnny_faneca, 139.050] Current 19th: [ blobglob, 138.900]
27-4 - Old 0th: [ Johnny_faneca, 158.750] Current 19th: [ John222, 157.825]
28-0 - Old 0th: [ blobglob, 133.525] Current 19th: [ a_krasner, 133.375]
28-2 - Old 0th: [ glupi_zmaj, 113.650] Current 19th: [Darkshadow1416, 113.075]
28 - Old 0th: [ glupi_zmaj, 235.950] Current 19th: [ animal_rights, 231.125]
29-0 - Old 0th: [ johnny_faneca, 153.900] Current 19th: [ mc_george, 153.900]
29-1 - Old 0th: [ tktktk, 132.900] Current 19th: [Darkshadow1416, 132.475]
29-3 - Old 0th: [ johnny_faneca, 120.125] Current 19th: [ ToeFaceKiller, 120.075]
30-0 - Old 0th: [ trib4lmaniac, 95.025] Current 19th: [ Shaigel, 94.950]
30-1 - Old 0th: [ johnny_faneca, 114.950] Current 19th: [ Amdi, 114.750]
30-2 - Old 0th: [ clux, 108.625] Current 19th: [ ninna, 108.550]
31-1 - Old 0th: [ glupi_zmaj, 155.050] Current 19th: [ glib_jase, 154.625]
31-2 - Old 0th: [ Melchoir79, 116.375] Current 19th: [ Chipauz, 116.200]
32-3 - Old 0th: [ spect, 136.225] Current 19th: [ mc_george, 136.150]
33-0 - Old 0th: [ glupi_zmaj, 189.175] Current 19th: [ DJ_M, 189.125]
33-2 - Old 0th: [ spect, 149.950] Current 19th: [ trib4lmaniac, 149.525]
34-1 - Old 0th: [ trib4lmaniac, 134.900] Current 19th: [ trib4lmaniac, 134.900]
34-2 - Old 0th: [ clux, 101.600] Current 19th: [ clux, 101.600]
34 - Old 0th: [ glupi_zmaj, 201.375] Current 19th: [Mr__Threepwood, 201.075]
36-3 - Old 0th: [ glupi_zmaj, 61.300] Current 19th: [ Izzy, 61.000]
36-4 - Old 0th: [ glupi_zmaj, 174.425] Current 19th: [TWA_MATO_BY_Titan, 169.200]
36 - Old 0th: [ glupi_zmaj, 202.250] Current 19th: [ ari22hoops, 187.175]
37-0 - Old 0th: [ spect, 121.150] Current 19th: [ maister_lp, 120.775]
37-1 - Old 0th: [ johnny_faneca, 93.125] Current 19th: [ Seifer, 93.000]
37-2 - Old 0th: [ spect, 197.400] Current 19th: [ glupi_zmaj, 197.150]
37-3 - Old 0th: [ glupi_zmaj, 107.250] Current 19th: [ ToeFaceKiller, 106.700]
37-4 - Old 0th: [ glupi_zmaj, 157.375] Current 19th: [ trib4lmaniac, 153.950]
38-4 - Old 0th: [ glupi_zmaj, 135.425] Current 19th: [ loudog004, 134.025]
39-1 - Old 0th: [ glupi_zmaj, 137.575] Current 19th: [ joe1284, 137.500]
39-2 - Old 0th: [ SirKnil, 152.425] Current 19th: [ omludo, 150.925]
39-4 - Old 0th: [ spect, 137.275] Current 19th: [ EL_FERNET, 137.200]
40-2 - Old 0th: [ Seifer, 110.325] Current 19th: [ glib_jase, 110.250]
40-3 - Old 0th: [ Afterthought, 117.550] Current 19th: [ Chouse, 117.400]
42-1 - Old 0th: [ tktktk, 169.475] Current 19th: [ Fenneth, 169.350]
42-2 - Old 0th: [ trib4lmaniac, 166.600] Current 19th: [ romaniac, 166.150]
42-3 - Old 0th: [ johnny_faneca, 183.925] Current 19th: [ ToeFaceKiller, 180.375]
42-4 - Old 0th: [ Seifer, 98.575] Current 19th: [ BlackyFrost, 98.500]
43-0 - Old 0th: [ Seifer, 158.200] Current 19th: [ davulcu2000, 158.075]
44-0 - Old 0th: [ Seifer, 104.275] Current 19th: [ xdude_, 104.225]
44-1 - Old 0th: [ spect, 155.575] Current 19th: [ hardcore_dood, 155.250]
44-2 - Old 0th: [ spect, 120.250] Current 19th: [ Hendor, 118.925]
44-3 - Old 0th: [ spect, 120.675] Current 19th: [ Personman, 119.875]
44-4 - Old 0th: [ spect, 215.350] Current 19th: [ Crimer, 214.775]
45-0 - Old 0th: [ Wolfos, 83.400] Current 19th: [ glib_jase, 83.150]
45-2 - Old 0th: [ spect, 144.700] Current 19th: [ trib4lmaniac, 144.525]
45-3 - Old 0th: [ Brian1233, 63.050] Current 19th: [ trib4lmaniac, 62.900]
45-4 - Old 0th: [ trib4lmaniac, 145.850] Current 19th: [ glib_jase, 145.475]
45 - Old 0th: [ trib4lmaniac, 190.475] Current 19th: [ _mjkisgod_, 189.750]
46-1 - Old 0th: [ glupi_zmaj, 147.575] Current 19th: [ Chouse, 147.525]
47-2 - Old 0th: [ tktktk, 128.825] Current 19th: [ Nickouu, 128.375]
47-3 - Old 0th: [ johnny_faneca, 95.725] Current 19th: [ glib_jase, 94.850]
48-3 - Old 0th: [ trib4lmaniac, 213.175] Current 19th: [ swipenet, 212.475]
49-0 - Old 0th: [ Seifer, 115.550] Current 19th: [ Sammage, 111.575]
49-2 - Old 0th: [ spect, 117.650] Current 19th: [ spect, 117.650]
49-3 - Old 0th: [ clux, 127.900] Current 19th: [ ToeFaceKiller, 127.750]
49-4 - Old 0th: [ johnny_faneca, 130.150] Current 19th: [ alimbach, 128.175]
49 - Old 0th: [ Sammage, 251.700] Current 19th: [ LouDog004, 227.575]
50-0 - Old 0th: [ trib4lmaniac, 162.275] Current 19th: [ Tivo, 162.250]
50-3 - Old 0th: [ trib4lmaniac, 229.625] Current 19th: [ Hendor, 229.550]
50-4 - Old 0th: [ trib4lmaniac, 138.975] Current 19th: [ Analu, 138.675]
51-3 - Old 0th: [ Melchoir79, 100.225] Current 19th: [ xaelar, 99.050]
51 - Old 0th: [ Melchoir79, 215.275] Current 19th: [ x-y-z, 212.975]
52-4 - Old 0th: [ Sammage, 124.225] Current 19th: [ blobglob, 123.775]
53-0 - Old 0th: [ Afterthought, 115.125] Current 19th: [ Afterthought, 115.125]
53-2 - Old 0th: [ scorpio11883, 143.300] Current 19th: [ x-y-z, 143.075]
54-1 - Old 0th: [ johnny_faneca, 130.975] Current 19th: [ Sammage, 130.950]
55-1 - Old 0th: [ trib4lmaniac, 132.725] Current 19th: [ trib4lmaniac, 132.725]
55-4 - Old 0th: [ trib4lmaniac, 109.350] Current 19th: [ Seifer, 108.750]
56-0 - Old 0th: [ Brett_Sully_, 92.125] Current 19th: [ Killock, 90.900]
56-4 - Old 0th: [ johnny_faneca, 101.250] Current 19th: [ Unsane, 97.850]
57-1 - Old 0th: [ johnny_faneca, 183.800] Current 19th: [ wedgie123, 183.575]
58-2 - Old 0th: [ trib4lmaniac, 109.375] Current 19th: [ trib4lmaniac, 109.375]
58-3 - Old 0th: [ Sammage, 123.875] Current 19th: [ zapkt, 123.075]
58-4 - Old 0th: [ trib4lmaniac, 56.175] Current 19th: [ Chouse, 53.600]
58 - Old 0th: [ Sammage, 218.050] Current 19th: [ jg9000, 191.075]
59-0 - Old 0th: [ Knu, 84.700] Current 19th: [ Knu, 84.700]
59-1 - Old 0th: [ Toad, 80.150] Current 19th: [ Mr_Lim, 79.150]
59-2 - Old 0th: [ trib4lmaniac, 112.575] Current 19th: [ Analu, 110.625]
59-3 - Old 0th: [ johnny_faneca, 98.875] Current 19th: [ Sammage, 92.575]
59-4 - Old 0th: [ blobglob, 149.625] Current 19th: [ Dan_K, 147.950]
59 - Old 0th: [ emotion87, 145.900] Current 19th: [ Philc12, 124.325]
60-2 - Old 0th: [ Seifer, 96.325] Current 19th: [jump_around_guy, 96.250]
61-2 - Old 0th: [ Melchoir79, 174.425] Current 19th: [ Chouse, 174.400]
61-3 - Old 0th: [ clux, 168.650] Current 19th: [ Mr_Lim, 168.525]
62-4 - Old 0th: [ blobglob, 121.300] Current 19th: [ zapkt, 121.200]
63-0 - Old 0th: [ spect, 124.600] Current 19th: [ spect, 124.600]
63-2 - Old 0th: [ Afterthought, 200.950] Current 19th: [ Nickouu, 199.125]
63-3 - Old 0th: [ KinGAleX, 103.925] Current 19th: [ KinGAleX, 103.925]
64-1 - Old 0th: [ Seifer, 151.825] Current 19th: [ Chipauz, 151.525]
64-3 - Old 0th: [ Johnny_faneca, 106.475] Current 19th: [ ToeFaceKiller, 106.025]
65-4 - Old 0th: [ Eeyore, 116.050] Current 19th: [ DJ_M, 115.675]
66-0 - Old 0th: [ wedgie123, 167.550] Current 19th: [ Mr_Lim, 165.775]
66-1 - Old 0th: [ Seifer, 147.325] Current 19th: [ Zhaine, 146.600]
66-3 - Old 0th: [ tktktk, 173.050] Current 19th: [ zj820, 172.250]
67-3 - Old 0th: [ Johnny_faneca, 166.425] Current 19th: [ J0803_again, 165.650]
68-4 - Old 0th: [ Brett_Sully_, 152.750] Current 19th: [ schwah, 152.575]
69-1 - Old 0th: [ Johnny_faneca, 128.675] Current 19th: [ blobglob, 128.125]
69-2 - Old 0th: [ Johnny_faneca, 137.650] Current 19th: [ trib4lmaniac, 136.675]
69-3 - Old 0th: [ Johnny_faneca, 102.800] Current 19th: [ vankusss, 102.475]
69-4 - Old 0th: [ trib4lmaniac, 233.475] Current 19th: [Darkshadow1416, 233.450]
70-0 - Old 0th: [ clux, 117.000] Current 19th: [ Qix, 116.725]
70-1 - Old 0th: [ clux, 90.025] Current 19th: [ Fenneth, 89.925]
70-2 - Old 0th: [ clux, 178.700] Current 19th: [ glib_jase, 177.325]
70-3 - Old 0th: [ clux, 184.675] Current 19th: [ blobglob, 184.575]
70-4 - Old 0th: [ Johnny_faneca, 109.525] Current 19th: [ xaelar, 109.050]
71-3 - Old 0th: [ spect, 105.350] Current 19th: [ glib_jase, 105.275]
72-1 - Old 0th: [ trib4lmaniac, 119.775] Current 19th: [ Johnny_faneca, 116.700]
75-0 - Old 0th: [ Johnny_faneca, 165.825] Current 19th: [ henry_yhwh, 163.825]
75-4 - Old 0th: [ Johnny_faneca, 106.475] Current 19th: [ spect, 106.225]
76-0 - Old 0th: [ Johnny_faneca, 135.925] Current 19th: [ animal_rights, 135.800]
76-1 - Old 0th: [ blobglob, 203.675] Current 19th: [ Mr_Lim, 203.275]
76-2 - Old 0th: [ Johnny_faneca, 170.900] Current 19th: [ 7aMaDX, 169.500]
76-3 - Old 0th: [ trib4lmaniac, 173.675] Current 19th: [ ToeFaceKiller, 172.925]
76-4 - Old 0th: [ Johnny_faneca, 123.625] Current 19th: [ spect, 122.275]
77-0 - Old 0th: [ Johnny_faneca, 107.825] Current 19th: [ lol000, 107.325]
77-1 - Old 0th: [ Johnny_faneca, 136.150] Current 19th: [ unconditional, 135.550]
77-2 - Old 0th: [ jg9000, 128.600] Current 19th: [ glib_jase, 127.725]
77-3 - Old 0th: [ Johnny_faneca, 126.925] Current 19th: [ trib4lmaniac, 126.700]
77-4 - Old 0th: [ clux, 85.150] Current 19th: [ xXxVladyxXx, 85.000]
77 - Old 0th: [ Johnny_faneca, 214.950] Current 19th: [TWA_MATO_BY_Titan, 192.925]
78-0 - Old 0th: [ spect, 168.775] Current 19th: [ Nickouu, 168.425]
78-2 - Old 0th: [ jg9000, 150.450] Current 19th: [ Johnny_faneca, 149.300]
78-3 - Old 0th: [ sammage, 232.750] Current 19th: [OptionalBowser, 232.700]
78-4 - Old 0th: [ scorpio11883, 85.750] Current 19th: [ scorpio11883, 85.750]
79-0 - Old 0th: [ clux, 221.050] Current 19th: [ zapkt, 218.350]
79-1 - Old 0th: [ scorpio11883, 121.250] Current 19th: [ xdude_, 119.750]
79-2 - Old 0th: [ spect, 135.225] Current 19th: [ glib_jase, 134.500]
79-4 - Old 0th: [ Afterthought, 100.400] Current 19th: [Ben_Schultz_11, 100.050]
80-1 - Old 0th: [ trib4lmaniac, 139.500] Current 19th: [ lisztig, 138.375]
80-2 - Old 0th: [ Seifer, 161.600] Current 19th: [ Izzy, 161.250]
80-3 - Old 0th: [ spect, 127.150] Current 19th: [ trib4lmaniac, 127.050]
80-4 - Old 0th: [ Afterthought, 186.425] Current 19th: [ Chouse, 185.950]
81-0 - Old 0th: [ trib4lmaniac, 145.100] Current 19th: [ Just4TheFun, 144.850]
81-1 - Old 0th: [ jg9000, 93.850] Current 19th: [ glib_jase, 90.875]
81-3 - Old 0th: [ Johnny_faneca, 112.425] Current 19th: [ Dr_Karlossus, 111.500]
81-4 - Old 0th: [ Melchoir79, 127.475] Current 19th: [ Amdi, 127.075]
81 - Old 0th: [ Sammage, 218.425] Current 19th: [ howtofoldsoup, 210.625]
82-0 - Old 0th: [ Melchoir79, 138.450] Current 19th: [ Msyjsm, 138.425]
82-1 - Old 0th: [ Isdariel, 150.150] Current 19th: [ glib_jase, 149.275]
82-2 - Old 0th: [ jg9000, 142.100] Current 19th: [ Hendor, 142.025]
83-2 - Old 0th: [ Johnny_faneca, 145.300] Current 19th: [ randoMentity, 144.525]
83-3 - Old 0th: [ Sammage, 70.400] Current 19th: [ Saradominist, 61.050]
83-4 - Old 0th: [ Sammage, 115.050] Current 19th: [ cev62, 114.625]
84-0 - Old 0th: [ alimbach, 134.200] Current 19th: [ Chouse, 126.925]
84-1 - Old 0th: [ trib4lmaniac, 180.575] Current 19th: [ Izzy, 180.400]
84-2 - Old 0th: [ Seifer, 101.100] Current 19th: [ Chouse, 100.450]
84-4 - Old 0th: [ spect, 159.225] Current 19th: [ Firepaw, 156.925]
85-1 - Old 0th: [ jg9000, 172.450] Current 19th: [ Izzy, 169.950]
85-2 - Old 0th: [ Seifer, 101.375] Current 19th: [Darkshadow1416, 101.050]
86-2 - Old 0th: [ blobglob, 133.925] Current 19th: [ vankusss, 132.325]
86-4 - Old 0th: [ Johnny_faneca, 140.325] Current 19th: [ Amdi, 139.800]
87-4 - Old 0th: [ trib4lmaniac, 139.350] Current 19th: [ trib4lmaniac, 139.350]
88-1 - Old 0th: [ johnny_faneca, 154.725] Current 19th: [ Izzy, 153.775]
88-2 - Old 0th: [ johnny_faneca, 93.300] Current 19th: [ Mongy, 92.175]
88-3 - Old 0th: [ trib4lmaniac, 206.025] Current 19th: [ Hendor, 204.200]
88-4 - Old 0th: [ blobglob, 150.550] Current 19th: [ johnny_faneca, 150.250]
89-1 - Old 0th: [ trib4lmaniac, 145.550] Current 19th: [ trib4lmaniac, 145.550]
89-2 - Old 0th: [Jiggerjaw12358, 177.850] Current 19th: [ Zmaj, 177.550]
89-3 - Old 0th: [ Melchoir79, 87.900] Current 19th: [ jumanji21, 86.250]
89-4 - Old 0th: [ johnny_faneca, 122.550] Current 19th: [ rahmberg, 120.175]
89 - Old 0th: [ Zmaj, 260.725] Current 19th: [ hoya08, 248.900]
90-0 - Old 0th: [ trib4lmaniac, 121.750] Current 19th: [ Toad, 121.500]
90-1 - Old 0th: [ Seifer, 104.275] Current 19th: [ johnny_faneca, 104.250]
90-3 - Old 0th: [ Knu, 150.100] Current 19th: [ TheRealOne, 149.475]
91-0 - Old 0th: [ clux, 113.750] Current 19th: [ trib4lmaniac, 113.625]
92-0 - Old 0th: [ spect, 130.950] Current 19th: [ Chris_Hipser, 130.175]
92-1 - Old 0th: [ spect, 158.200] Current 19th: [ Analu, 157.600]
92-3 - Old 0th: [ blobglob, 185.625] Current 19th: [ glib_jase, 184.850]
92-4 - Old 0th: [ great_sea, 106.125] Current 19th: [ great_sea, 106.125]
93-1 - Old 0th: [ trib4lmaniac, 162.450] Current 19th: [ swipenet, 162.425]
93-2 - Old 0th: [ jg9000, 110.100] Current 19th: [ ToeFaceKiller, 108.425]
93-3 - Old 0th: [ johnny_faneca, 119.350] Current 19th: [ trib4lmaniac, 119.275]
93-4 - Old 0th: [ jg9000, 125.175] Current 19th: [ Jp27ace, 122.500]
94-0 - Old 0th: [ trib4lmaniac, 80.650] Current 19th: [ GlaucoSK, 80.575]
94-1 - Old 0th: [ Wolfos, 155.200] Current 19th: [ Mongy, 154.925]
94-2 - Old 0th: [ trib4lmaniac, 122.825] Current 19th: [ trib4lmaniac, 122.825]
95-0 - Old 0th: [ johnny_faneca, 126.850] Current 19th: [ Amdi, 126.550]
95-1 - Old 0th: [ spect, 140.100] Current 19th: [ niskin, 138.000]
95-2 - Old 0th: [ sammage, 171.750] Current 19th: [ johnny_faneca, 162.075]
95-3 - Old 0th: [ johnny_faneca, 183.025] Current 19th: [ jg9000, 181.675]
95-4 - Old 0th: [ spect, 133.900] Current 19th: [ trib4lmaniac, 132.525]
96-0 - Old 0th: [ jg9000, 138.175] Current 19th: [ swipenet, 137.900]
96-1 - Old 0th: [ johnny_faneca, 100.350] Current 19th: [ xdude_, 97.625]
96-2 - Old 0th: [ spect, 164.875] Current 19th: [ BigRedButten, 164.700]
96-3 - Old 0th: [ jg9000, 102.425] Current 19th: [ Mr_Lim, 101.475]
96-4 - Old 0th: [ jg9000, 115.900] Current 19th: [ DJ_M, 112.550]
96 - Old 0th: [ jg9000, 249.075] Current 19th: [Ahmed_Abdullah_Alsalam, 225.150]
97-3 - Old 0th: [ johnny_faneca, 140.250] Current 19th: [ spect, 140.250]
98-0 - Old 0th: [ jg9000, 174.450] Current 19th: [ Kanundrum, 174.350]
98-1 - Old 0th: [ Seifer, 125.100] Current 19th: [ Seifer, 125.100]
98-2 - Old 0th: [ trib4lmaniac, 144.850] Current 19th: [ glib_jase, 144.650]
98-4 - Old 0th: [ johnny_faneca, 130.750] Current 19th: [ Mr_Lim, 130.625]
Total: 242 entriesSome players might have improved their scores of course, in which case it'd rather be a list of "0th that would have qualified for a current top20 if the player hadn't improved the score", clear example, johnny's 00-1. Its interesting that over half of all 0ths are now gone of the top20. I've added these to my NHigh but I'm not publishing it since this thing is pretty crappy xD Unless of course anyone is actually interested.
If anyone wants some new functions you can also tell me, although as I've often expressed, not only my knowledge in python sucks, but also I haven't inspected the code thoroughly so I'm not sure how scores are saved and sorted and so on, it definitely isn't like I do with my version for N v2.0, hence all functions are done differently.
Users browsing this forum: No registered users and 52 guests
