Edit: Also, no idea if this can be made to work but if you can dodge the rocket it's faster (34-2).
Unreality's awesome mod
#1 there are many routes to the left side, none of which i found suitable
#2
It continues like this: (it's also a practice map)
You can try to find the rest of the route on this map (the hard drone is deleted - make sure it doesn't cause any problems later in the run)
edit: just posting this in case anyone has a lot of time and wants to keep exploring...
Also, if anyone wants a top-20 on 15-3 my route is incredibly easy. I also have a slight modification that might be able to take 0th. See below for crappy example
EddyMataGallos wrote: Took 91-4 by 2.5 seconds
I agree getting a really clean run is obscenely difficult. That's why maximizing the start is so important. Here's an even faster route (though I haven't confirmed if the last chaingun dodge is possible).TheRealOne wrote:I would love for someone to throw down an epicly clean run on that map. It has been the one level that has avoided control by the community. There has been a years long battle between x-y-z, 7aMaDX, and TWA. LAT is the only one of us to even make a some what decent attempt at it. Even Lim the master of cleaning super long hard runs is 5 seconds of the pace.
Edit: Potential way around that:
- Gross
If you are using NReality when you die from anything in game other than suiciding wait for the message box that says press space to play again or r to replay your demo. At this point press "SHIFT+R" and then a webpage from infunity.com (the hosting site for NReality) will pop up, just copy the text that appears on that page. When pasting that on the forums use thejp27ace wrote:I've had a little look and come up with a route that's about 2 seconds faster, but I suck too much to pull it off, and I have no idea how to save a replay of half a run.vankusss wrote:I feel there are few seconds hidden on 93-4, I just can't find them.
- Gross
awesome!jp27ace wrote:Ah awesome thanks TRO, testing:
Hopefully the end of the run is obvious (pretty much do the mirror of the LHS)
Edit: Is there any way to ghost against a run where you die?
Edit 2: Took 19th, missing half the gold but showing the full route
As for 91-4, I remember I discussed with Raif one day about a faster start we had both thought about which turned out to be the same, pretty much the same you showed as well dark, basically maxing it out. The problem with that level, at least for me, is the awful top part. I have never been able to realize a consistent way of doing it (like top players do) which doesnt depend on, you know, randomness.
Edit: And I have no idea why no one uses these openings for 37-4. They aren't much harder than the normal one since you can just insta-suicide if you miss the triple jump.
If you try to go even faster:
Maybe going this fast and trying to sneak below the drone:
Same idea but better:
Not sure if possible or moreover if fast enough.
EDIT: So I pretty underestimated this, looks like 20-30 frames:vankusss wrote:I dunno if anyone can do anything with this, but I'll leave it here anyway (35-0)
EDIT2: HOPS I USED QUOTE INSTEAD OF EDIT FIRST TIME
anyway I took it so these posts are outdated
Do you think it will help?
What level is that? (is there a way I can find out?)
Nice 196592 sr earlier btw
It's 39-4; a level notorious for ruining episode runs ;)_danielr_ wrote:Yeah - if you can repeat it! ;)
Users browsing this forum: Google [Bot] and 27 guests
