Post a Run!
Glad it worked a bit, I did feel the difference when I did it on Win7.
As for that guy, that must be an admirer then :P He mostly plays userlevels but he has 3 Metanet Top-10s I think.
Nice innov indeed btw, used it to improve my run by a couple tenths.
I haven't seen this much highscores competition on an NReality map since "International take a 0th off xaelar week"!golf wrote:Taking dan and my advice and moving this discussion over here: 129-1 is mine again. I think its time you step off of this see-saw we've been riding on and just admit defeat daniel :)
Fine.golf wrote:I think its time you step off of this see-saw we've been riding on and just admit defeat daniel :)
SIKE! Have another 14 frames. :P I promise I'll stop now.
lol sure looks like it. I may try to retake it, but that's a pretty sizable lead at this point. When I got that 110.000 score I knew there was still a lot left in the level. I compared our runs in demo mode, and dan had me by a good 10+ frames right until the chimney up to the door. I was able to go pretty much straight from landing after the last set of gold straight up to the chimneying, while he slowed down to get a better angle up and in. So that was maybe a half a second swing.ska wrote:Daaaaaaaaaaaaaamn. Golf got owned!
To answer MiBeM's question, I think there has to be some timing involved. Go take a look at the last several posts in the Metanet 0th thread (which title looks like a dude shrugging his shoulders right now... thanks van) to see the discussion that's spawned. Really, about the entire last page worth is pretty interesting and I think worth reading. To be a little more specific, you have to have a pretty good amount of speed, but for a chimney of the length in the 129-1 route you just can't get enough pure speed to blaze past the first door, so there has to be some sort of timing needed to make it through. Personally, I've never really known what that is, my usually terrible chimneying tends to put me through every once in a great while, only often enough to me that it seems completely random.
As an aside, I want to see what ska can get on 121027 since you made that comment that started this whole mess on 129-1, and it looks like you've never posted a score there.
(Until I take my next 0th)
I think you can shave off a few frames here and there...
Yep. well done, my comp is lagging right now, so 230871 hs is a run I made the other day.alsojp27ace wrote:Nice run, taken with a pretty simple innov at the startska wrote:230846 hs
Edit: also got a pretty neat run on 200013 (still sr)
Edit 2: 200015 sr, can't believe I just did all those cjs o.O
200013 was a pretty neat run, but not neat enough :) And your start on 15 you make it look deceptively easy to get that first corner jump, good job there.MiBeM wrote:Edit: also got a pretty neat run on 200013 (still sr)
This would be the ideal route:
$###9000000000000000000000000000000000000000000000800000000000000000000001111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000N11111190000000000000000000006000000000000000000000000000000000000000000000000000000000000000000000800000000000000000000071111111PP000NN111111111111111PP000NN111111111111111PP000NN111111111111111PP000NN1111111111111111P000NN111111111111190000000000000000000006000000000000000000000000000000000000000000000000000000000000000000000800000000000000000000071PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111111111PP000NN11111111111000000000000000000000060000000000000000000000000000000000000000000007|12^204,420!12^180,396!12^156,372!12^132,348!12^108,324!12^108,228!12^132,252!12^156,276!12^180,300!12^204,324!12^348,324!12^348,228!12^372,300!12^396,276!12^372,204!12^396,180!12^420,156!12^444,132!12^444,228!12^420,252!12^588,84!12^612,108!12^636,132!12^660,156!12^684,180!12^684,276!12^660,252!12^636,228!12^612,204!12^588,180!2^48,576,0,-1!2^72,576,0,-1!2^720,24,0,1!2^744,24,0,1!5^60,528!11^732,528,732,528!0^276,546!0^288,540!0^294,528!0^288,516!0^276,510!0^264,504!0^258,492!0^264,480!0^276,474!0^276,456!0^264,450!0^258,438!0^288,450!0^294,438!0^264,426!0^288,426!0^276,420!0^516,450!0^504,444!0^498,432!0^504,420!0^516,414!0^528,408!0^534,396!0^528,384!0^516,378!0^516,360!0^504,354!0^498,342!0^504,330!0^516,324!0^528,330!0^534,342!0^528,354!6^228,132,2,1,0,3!6^324,468,2,1,0,1!6^564,132,3,1,0,3!6^468,468,3,1,0,1#170:17895697|17895697|17895697|17895697|40265457|35791394|35791394|8738|35791392|35791394|8738|35791360|35790850|35791394|107405858|107374182|107374182|107374182|107374182|237117990|107374182|107374182|107374182|105145958|1638#By the way, why not try 200012?
I kinda got bored of that map after playing around with it for a while. Maybe I'll try it again later._danielr_ wrote:why not try 200012?
Fun levels, took both. I did 12 in hs mode because it also submits to sr, which doesn't happen the other way around, remember that, it's beneficial._danielr_ wrote:Took 200015. Plenty cleanable though.
Not that hard to do, but it looks cool. :D
Come on then. How long did it take to cut it down to that speed? ;)macrohenry wrote:[128999 sr] Not that hard to do
Eddy's run - TROLOLOLOLMiBeM wrote:200020 sr, just barely couldn't get under 1000 frames :P
Dammit Eddy. You did that on purpose didn't you? :|_danielr_ wrote:Eddy's run - TROLOLOLOL
Users browsing this forum: Baidu [Spider], Google [Bot] and 36 guests
