Postby macrohenry » 2015.09.02 (22:44)
62-4 with an extra corner jump to get a better angle for the ending. I wonder if it's possible to beat the drone.
Also, this:
Postby EddyMataGallos » 2015.09.03 (01:46)
macrohenry wrote:I wonder if it's possible to beat the drone.
I do believe so ;) Also retook 23-2.
Postby golf » 2015.09.03 (01:55)
Only 8 frames by beating the drone? I expected more out of you, Eddy.
jk, great run.
Postby TheRealOne » 2015.09.03 (12:58)
Nice job making use of that corner in the top left on both the way down and the way up. That was enough to make it happen. Nice work.
Postby EddyMataGallos » 2015.09.03 (20:21)
Thank you guys, yeah that corner you mention there is the only way to reach the floor after the triple jump too. Well, actually you can reach it if you plain don't hit it, and then avoid the ceiling, however that's too slow to beat the drone afterwards.
Postby macrohenry » 2015.09.07 (21:34)
Ep20 and Ep30 taken. No idea why I suddenly went for episode speedruns.
Postby TheRealOne » 2015.09.08 (00:02)
macrohenry wrote:Ep20 and Ep30 taken. No idea why I suddenly went for episode speedruns.
52 & 85 frames off the level 0th pace. That is pretty impressive. Nice job on 30-1 as well. That 0th route is damn hard. When Kool took that 0th I tried for hours to get two clean 8-tile jumps after the opening triple and failed miserably.
Postby shomman » 2015.09.08 (02:32)
macrohenry wrote:No idea why I suddenly went for episode speedruns.
Probably because Eddy isn't.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 :):(
Other Stuff
Image Thanks Nyan!
Postby EddyMataGallos » 2015.09.08 (03:15)
Tied 20-0, took 20-1, 20-2 and 20-3. Hmm, look at that, seems like I'm only missing the ep now...
Is 20-0 maxed anyways?
Postby TheRealOne » 2015.09.08 (13:29)
EddyMataGallos wrote:Tied 20-0, took 20-1, 20-2 and 20-3. Hmm, look at that, seems like I'm only missing the ep now...
Nice Eddy. Those levels are all super tight.
Side note, would a low jump save frames on 20-1? I would think not since you already land almost before the door anyway, but it just popped in to my head.
Postby EddyMataGallos » 2015.09.09 (00:18)
In my humble opinion, those were a bit subpar for what macro could've pulled off in the speedrun of 2 relatively simple eps.
I've taken them and changed those figures to 4 & 7 frames off level 0th pace respectively. Improved my 0ths in 20-2, 20-4, 30-4; and took 30-3 on the way as well.
TheRealOne wrote:Nice Eddy. Those levels are all super tight.
Cheers man. It could actually help, the reason we already land right before the door is because we jump before reaching the edge of the tile so as not to overshoot the door. A low jump would allow running to the end, but would this compensate the slight deceleration it causes?
Postby macrohenry » 2015.09.09 (16:09)
TheRealOne wrote:52 & 85 frames off the level 0th pace. That is pretty impressive. Nice job on 30-1 as well. That 0th route is damn hard. When Kool took that 0th I tried for hours to get two clean 8-tile jumps after the opening triple and failed miserably.
Eddy is completely right. I guess I'm missing the patience to pull off a close to perfect episode run as those would take me at least 2 hours whereas Eddy most likely doesn't spend longer than 45 minutes on them. Impressive new 0ths, good job! Also, clever little innov in 30-1.
Postby TheRealOne » 2015.09.10 (00:47)
Well if that is the case, what could the two of your narrow the SR EP Total to Level Total gap too?
Postby EddyMataGallos » 2015.09.11 (04:07)
Well, potentially speaking it could get as low as you're willing to devote to it, certainly below 1000 frames (eps 00-99 only). More realistically speaking I'd aim for 4-5k at first, which is certainly plausible. The difference currently stands at 10875 if my calculations are right, which averages 108.75 frames lost per episode evidently. Tbh I was expecting much more, as the few episodes I see tend to be sorta poor, but I guess the shorter lenght of the runs or the tighter eps make up for that.
Anyway, I just randomly took 16-0 with an obvious change at the end.
Postby xaelar » 2015.09.11 (10:07)
I just noticed that the old mbd for episode 00 speedrun are: 00-0 beaten, 00-1 beaten, 00-2 tied, 00-3 beaten.
That's impressive!
Postby _danielr_ » 2015.09.11 (15:41)
EddyMataGallos wrote:Anyway, I just randomly took 16-0 with an obvious change at the end.
I notice you also took 16-4. There is a quicker ending to that level, where you jump onto the trampoline so that it throws you off at an angle to avoid the drone (see pic). I did manage it once, but died from hitting the roof with too much speed! :)
P.S. Also, you can beat the drone at the bottom if you skip the wall hug.
Postby EddyMataGallos » 2015.09.14 (21:58)
But that super cool dude did beat the drone, although maybe you mean falling on the slope without wallsliding. Regarding that ending, well that's interesting, now it sounds familiar.
EDIT: Randomly took some 0ths in 26-1, 26-4, 51-1, 55-2, 56-4 and 75-2. 26-1 with naem's route again ^^
Postby _danielr_ » 2015.09.14 (23:56)
EddyMataGallos wrote:But that super cool dude did beat the drone, although maybe you mean falling on the slope without wallsliding. Regarding that ending, well that's interesting, now it sounds familiar.
The sarcasm is palpable.
EddyMataGallos wrote:EDIT: Randomly took some 0ths in 26-1, 26-4, 51-1, 55-2, 56-4 and 75-2. 26-1 with naem's route again ^^
One frame off 75-2? Ugh. Well done on the route for 26-1 :)
Postby EddyMataGallos » 2015.09.16 (20:57)
_danielr_ wrote:One frame off 75-2? Ugh. Well done on the route for 26-1 :)
Well a frame lead is like a compliment for how clean your run was right? :P And thanks man.
Took 15-0, 15-1 and 15-2.
Particularly happy with my -1, although it still includes some sloppiness at the top and at the end. The ending and the starting sequence is changed. I innovated the ending of -2 as well.
EDIT: Took 62-0 and 62-1. I wonder if I lost a frame at the end of -0.
Postby _danielr_ » 2015.09.17 (13:47)
Aha, I guess so. Thanks ;)
EddyMataGallos wrote:Took 62-0 and 62-1. I wonder if I lost a frame at the end of -0.
Taken -0 :)
Postby EddyMataGallos » 2015.09.17 (20:54)
Taken -0 :)
Cool innov, you gained that frame before the wj so it's possible that there's another frame left that we lost after the wj, maybe :P
Took 11-1, 15-3, 63-1, 63-4, 64-0 and 64-1. Tied 15-4 and 63-2 as well. The first one seems cleanable, the second one could be maxed.
Postby TheRealOne » 2015.09.17 (21:54)
Taken -0 :)
Nice runs. The extra WJ on the BB on 11-1 is awesome. Nice find.
Postby EddyMataGallos » 2015.09.18 (12:04)
Much appreciated, I can't take credit for that though, that's macro's innov for hs (which has the same ending of course).
Postby TheRealOne » 2015.09.18 (13:01)
EddyMataGallos wrote:Much appreciated, I can't take credit for that though, that's macro's innov for hs (which has the same ending of course).
Well, credit to macro on that one then. That is a nifty little trick that looks like it save a nice chuck of frames.
Postby EddyMataGallos » 2015.09.18 (19:15)
Took 64-2, 64-3, 65-1, 65-3, 65-4, 66-0, 66-1, 66-2, 66-3. Tied 65-2.
Notes: Used macro's hs route for 65-4, big innov in 66-3 and small ones in 64-3 and 65-3.
