Tool-Assisted Highscores/Speedruns
Postby EddyMataGallos » 2020.04.11 (01:04)
We finally have a good AGD route for 43-0! Nice stuff Raif.
I'll take this opportunity to post this collaborative MBD, mainly by ska:
95-0, 127.600, 0.375 faster than the 3-way tie for 0th beating the drone bottleneck.
ska wrote:In April 2020, a four-way collaboration on 95-0 managed to achieve an innovation that until then had only been theoretical. An idea, raised by ska, was to dodge the drone near the very end of the level. The first phase of the plan was to ensure the dodge (dubbed the 'slip' by ska) was even possible. Vankusss supplied ska with demo data, confirming that the slip was possible. Next, ska made some comparisons between the top-performing highscorers to see where time could be saved. He extracted the first 400 frames or so from Mr Lim's 0th run, which he noticed was exceptionally clean. The initial plan was to stitch various runs together, but after a while it became evident that a proper MBD would need to be made. Because it was ska's first attempt at an MBD, it took him a solid day to get most of the run done. However, he was finding the end to be particularly tricky, so he handed over the final chimney section for EddyMataGallos to complete, which he did, managing to successfully execute the slip to break the bottleneck and thus saving 0.375 seconds and breaking a 13-year-old record (albeit not done in a real-time run). The run is Mr Lim's last remaining 0th, which is currently a three-way tie on the official boards.
EDIT: Btw I'd like to mention that Raif has further investigated this level in an attempt to completely beat the drone at the end, and it seems like this is not possible.
Postby Raif » 2020.04.13 (03:50)
Redid my 29-3 MBD from eleven(!) years ago. Should be close to maxed without another way around the drone bottleneck.
29-3 Highscore (124.775, 0.475 faster than old MBD, 2.100 faster than macro)
Postby Raif » 2020.04.13 (10:06)
Don't normally MBD NReality columns, but the launchpad walljump opportunities here were too good to pass up
197-4 Highscore (136.125, 20.300 faster than Eddy)
Postby macrohenry » 2020.05.13 (12:19)
Amazing as always, Raif. 197-4 is impressive for the sheer number of hard tricks but 29-3 is even more enjoyable to watch for more, simply because of how perfectly clean the run is.
Postby EddyMataGallos » 2020.05.13 (22:05)
Yeah, even though we already talked in the Discord, I should give the recognition through here as well, both runs are nuts. You straight up humiliated those poor launchpads in 197-4, give them a break dude xD
Postby ska » 2021.03.15 (10:32)
I've never been more excited for an MBD than raif's 78-3. I won't post the WIP yet, but I can't express in words how excited I am for it (based on what is done so far). If it all comes together, it will be a masterpiece.
Postby zapkt » 2022.03.10 (16:32)
Hi there!
In case you haven't seen, a N+ TAS has been made: https://tasvideos.org/4602M
That kind of makes me feel like compiling the TASes in this thread to make a full run of the game. But there aren't a lot of runs not going for golds, are they?
For the record, there is an old thread about N submissions on tasvideos.org here: https://tasvideos.org/Forum/Topics/9371
(I wish this forum's logging issue was fixed. Who is maintaining it?)
Edit: there are 51 speedruns out of 500 levels, that leaves a lot of work :/
Edit2: A 100% run could be a decent submission, though. Just not sure whether this would be considered too long (and if a flash game would be accepted)
There are currently ~150 highscore TAS. Would anybody feel like going through all the level and see which ones still have room for improvement in a TAS?
Postby ska » 2022.03.12 (01:59)
zapkt wrote:
2022.03.10 (16:32)
Hi there!
Hmm... this would be an absolutely herculean task, although it would be amazing to see. If this were to be done, I think the best thing to do would be to collate all the speedrun 0ths—both legit and TAS. You could then go through and decide which ones are worth improving via TAS or FBF. Whatever gets left behind can just be included as is. One could simply subtitle each level with who created the run and whether it was TAS or a real-time run. I've always thought about doing this, but my worry was always that it would become obsolete fairly quickly. Now that the 1.4 scene is pretty much dead, I think it would be a good time to preserve its legacy in video format. Oh, by the way, I also think there should be a highscore category, if it's possible to combine the individual TAS and real-time highscores into a single playback that preserves the score across levels. Happy to help make this happen, even if it's just doing screen capturing or video editing.
Cheers.
P.S. It's great to see you again, zapkt! Hope you're doing great!
Postby zapkt » 2022.04.17 (19:07)
Update : there is a first Flash TAS! TASing flash is definitely possible now. See https://tasvideos.org/4633M. A comment says it's using Ruffle + libTAS
Postby ska » 2022.04.21 (22:37)
zapkt wrote:
2022.04.17 (19:07)
Awesome! Someone call raif!
Postby EddyMataGallos » 2022.09.28 (22:16)
Very interesting, libTAS has already been used successfully in the past to TAS N++ as well, see this video by euni from 2019:
https://www.youtube.com/watch?v=qBE1Oq-WdTM
Currently, over in the Discord, we have developed other methods for TASing N++ though. They're both more similar to MBD's. The first one was via editing attract files, which contain demos, and thus it is essentially the same as for N. The second one injects the inputs directly into the game's memory, so dealing with files and reloading the game is avoided.
A tool was developed last year by Dan (not here) that performs this task (Win-only):
https://cdn.discordapp.com/attachments/ ... V3.123.zip
The most active TASer is SimVYo (whom I don't even think is here), he has produced hundreds of runs, mostly speedruns. The 2 major examples are:
https://www.youtube.com/watch?v=7K8Ek0cYrqQ
https://www.youtube.com/watch?v=vFOGODYz6gk
Postby ska » 2023.01.10 (10:06)
P.S. I wonder if raif will ever get around to finishing his 78-3 MBD. :(
P.P.S. Can you please update the master list? :)
Postby zapkt » 2025.08.23 (19:09)
I hyped myself into TASing N 1.4 but couldn't get libTAS to work with ruffle (Flash emulator, required by tasvideos.org). And I tried *everything*.
This is weird, because others have managed to make it work out of the box.
I'll try on another computer in a week, but my hope is low atm. I guess I'll try again in 2 years if libTAS and Ruffle are more stable then
Postby ska » 2025.08.26 (18:47)
zapkt wrote:
2025.08.23 (19:09)
Good luck!
Postby EddyMataGallos » 2025.08.27 (01:04)
Interesting endeavor, I've hardly used libTAS and never with Flash. Over in N++ we have some tools but they're also for MBDing, folks like SimVYo have produced full speedrun TASes by splicing MBDs together (e.g. 1, 2, 3, 4). He tried libTAS and managed to get it to work with N++, but it wasn't trivial, and I'm not sure he got around to producing a full run, and he's our best TASer. Nevertheless the tool has been discussed and used in our TAS channel, so you might want to hop in to the Discord for more direct help, although I'm not sure anyone's going to have experience with Flash specifically.
Postby zapkt » 2025.10.27 (10:32)
Update: I'm now actively TASing N!
I've already done all the work on menuing and calculating all level loading times. I made a set of scripts that build a libTAS inputs file from individual level demos. This allowed me to produce videos of all RTA scores (0ths) and RTA speedruns (see dedicated thread). This means I can reuse demos produced using the MBD method, providing I get authorization from their authors (I got it from Eddy and TRO, waiting for Raid to respond).
Next I'll work on lua scripts to get information such as speed to help TASing even further.
Check the repository out if you want to help TASing N! https://github.com/Perdu/nv14_TAS/
I also included information to help set up libTAS for N specifically.
See also the demo I already produced here: https://github.com/Perdu/nv14_TAS/blob/ ... l_data.yml . I also post them on Discord as I go
