Playing style?
Playing style?
Postby Evil_Sire » 2008.11.12 (18:08)
What's your N playing style? Do you try and do it as fast as possible? Or take it slow and steady? Do you go for the gold or the speed?
I personally go for speedruns most of the time, but i'll play the map slowly first so that i'm used to the map.
Postby twentythree » 2008.11.12 (18:40)
I usually just start playing it the first time, trying to beat it as fast as possible. The second time I just let it run and see where the enemies move if there are any moving ones. Then I just try to beat it faster and faster.
23!!!!!
Postby Izzy » 2008.11.12 (18:47)
A perfectionist that often fails.
I'll try to make a run as fast as I can.
Postby George » 2008.11.13 (13:34)
High scorer instinct always prevails.
Postby TribulatioN » 2008.11.14 (02:09)
I always go fast. I have great luck when going fast.
Postby Rikaninja » 2008.11.15 (06:24)
I start of with a speedrun to complete the level. Then later I'll come back to it and try and get the best AGD possible.
NUMA Profile: http://nmaps.net/user/gr_8
Postby gr_8 » 2008.11.16 (17:11)
i will always go for an agd, as it offers a nice challenge, and i do it slow to get use to the map, enemie placement etc. Then, once i have got an agd, i'll try and get the agd faster and faster. When i cant go any faster with an agd, i'll do a speedrun - see how much difference there is between the two.
sig by Jackass77. | avvie by GTM
Postby Yoshimo » 2008.11.16 (17:36)
This should be a poll. But speedrun. I have almost no luck with highscoring.
Postby Condog » 2008.11.16 (22:54)
First i'll estimate the difficulty by looking at the map: If it looks hard, i'll just try to complete it; if not, i'll try to perfect an all gold run.
Pure
NUMA Profile: http://starcross64.deviantart.com
Postby Starcross64 » 2008.11.16 (22:57)
I try to do it as sneaky as possible, while collecting as much gold as I can. It's fun doing a level where none of the enemies even see you.
Octave
Postby Nightingale » 2008.11.24 (01:07)
Neither, I galumph around stupidly till I get the job done...Very slowly with little gold.
NUMA Profile: http://nmaps.net/user/samurai_maligus
Postby Maligus » 2008.12.04 (22:02)
Nightingale wrote:Neither, I galumph around stupidly till I get the job done...Very slowly with little gold.
same pretty much
Drathmoore wrote:Invader Zim. A pretty unique idea, I must admit. =D
Think you have ideas worth contributing to my comics? If so, PM me your idea and I might put it in my comic. And, of course, your name will be cited in the comic.
Postby bhz » 2008.12.05 (01:32)
Speed completion, with all free (unprotected) gold and more along the way (along my path)
Exception is when highscoring.
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby PALEMOON » 2008.12.05 (02:10)
i find k styling to be a lot of fun and very pro.
Postby rambo5252 » 2008.12.05 (02:46)
I go agd then when i die when im far into a level i go for completion then speed then an AGD again, unless meta has posted b4 me then i go straight to beating his run
Thanks Toasters for the siggy
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
Postby notsteve » 2008.12.21 (04:50)
since i beat the game, whenever i play a metanet level i try to go as fast as possible, which often ends in some reallly dumb stuff happening
Postby behappyy » 2008.12.21 (14:03)
Speeeeeeeeeeeeeeeeeeeeeeeeeeeed.
Image]THANK IZZ'
Postby Zephyr » 2008.12.26 (02:29)
I go for speed, and grab any gold that dosent need me to take a longer route on the way
Clickme
[13:57:02] -->| Zeph (irchon@scave-CB6AAD1F.static.tpgi.com.au) has joined #Worldcup
[13:32:50] -->| Zeph (irchon@scave-CB6AAD1F.static.tpgi.com.au) has joined #Worldcup
Postby Donfuy » 2008.12.26 (03:09)
Mmm... it depends. On action maps, I first take the grasp of it, trying to find the perfect route to an AGD. If I can't make it, I just try more 4-5 times with speed.
On race maps, fast.
On survival maps, fast.
But this varies with difficulty, the first look I took on the map and my own mood.
