N and Ubuntu.
Once downloaded the Linux version of N I tried installing it and then figured out there is nothing to install to just run the program but it's won't work for me.
Is it just me being new to Linux or what?
As a formal welcome to Ubuntu, allow me to give you the following advice: When reporting a problem in Linux, your best bet will always be to try to do what you're doing from the console and then providing exactly the error text.
Go ahead and follow the instructions listed in the readme in a terminal, and copy-paste the output text (although I bet you $20 it's about libstc++5).
eric@eric-laptop:~$ n_v14
bash: n_v14: command not found
eric@eric-laptop:~$ open n_v14
Couldnt get a file descriptor referring to the console
eric@eric-laptop:~$ cd Desktop/n_v1linux
eric@eric-laptop:~/Desktop/n_v1linux$ n_v14
bash: n: command not found
I also tried to open it just as a file and it said something about not opening a binary file.
cd ~/Desktop/n_v1linux
ls
./n_v14b
and paste the results here.
eric@eric-laptop:~/Desktop/n_v1linux$ ls
editor_manual.doc license.txt n_v14 userlevels.txt <====== The "n_v14" was highlighted green in the terminal.
editor_manual.txt n_cheats.txt readme.txt
eric@eric-laptop:~/Desktop/n_v1linux$ ./n_v14b
bash: ./n_v14b: No such file or directory
./n_v14: error while loading shared libraries: libgtk-1.2.so.0: cannot open shared object file: No such file or directory
sudo aptitude install libgtk-1.2
(type in your password when prompted, and follow instructions)
./n_v14
Try 'libgtk1.2' without that hyphen.
Paste this into the console, basically:
sudo aptitude install libgtk1.2
And then try running N again.
eric@eric-laptop:~$ Desktop/n_v1linux/n_v14
Desktop/n_v1linux/n_v14: error while loading shared libraries: libstdc++-libc6.2-2.so.3: cannot open shared object file: No such file or directory
Now it's come from a rarely-seen problem to the most common one (and I was off by one version of libc in my prediction at the start of the thread).
All you have left to do is:
sudo aptitude install libstdc++6
...and you should be golden.
If the game is running particularly slowly, you may want to start it with:
sudo nice -n -20 ./n_v14
...which will give it much higher CPU priority (as opposed to starting it with just ./n_v14).
This will more than likely get it working for you, but I think there's still a chance you'll have one final problem involving the 2-2.so.3 bit, but that's also a quick fix.
- Almost as Bad as One
>bbgun06@bbgun06-laptop:~$ ./n_v1linux/n_v14
>./n_v1linux/n_v14: error while loading shared libraries: libstdc++-libc6.2-2.so.3: cannot >open shared object file: No such file or directory
I would appreciate any additional help.
Well, you can still get it to work with something that resembles a dirty hack, so no worries! (This worked for me, anyway, and I don't know why it wouldn't work for you.)
Change to root ("sudo -s" and type in your password), and "cd /usr/lib".
The standard C++ libraries are typically similar enough to each other that giving one a cheap tuxedo and having him pretend he's another library actually works far more often than you'd think.
So next, we find a suitable candidate. Do "ls libstdc++*" and see what's available. Pick a library that's closest to the version number we're looking for (libstdc++.so.6.0.9 for me), and make a symbolic link to it with the name of the library than N is looking for: "ln -s libstdc++.so.6.0.9 libstdc++-libc6.2-2.so.3".
Then exit out of root, head back into the directory you untarred N, and try running it again.
Here's me doing all of the stuff I just said above:
cvp@strife:~/dl/n_v1linux$ ls
cvp@strife:~/dl/n_v1linux$ ./n_v14
./n_v14: error while loading shared libraries: libstdc++-libc6.2-2.so.3: cannot open shared object file: No such file or directory
cvp@strife:~/dl/n_v1linux$ sudo -s
[sudo] password for cvp:
root@strife:~/dl/n_v1linux# cd /usr/lib
root@strife:/usr/lib# ls libstdc++*
libstdc++.so.5 libstdc++.so.5.0.7 libstdc++.so.6 libstdc++.so.6.0.9
root@strife:/usr/lib# ln -s libstdc++.so.6.0.9 libstdc++-libc6.2-2.so.3
root@strife:/usr/lib# exit
exit
cvp@strife:~/dl/n_v1linux$ ./n_v14Like I said earlier in this thread, consider running it with nice -n 20 to reduce lag.
I am also a ubuntu user.
I folowed the instructions by Tsukatu
They made n run in flash player 6
But, after I choose to play a level and need to press space, I realize that the buttons does not work.
I get an error message ( I think this is something with the sound though):
Gtk-WARNING **: Failed to load module "libcanberra-gtk-module.so": libcanberra-gtk-module.so: cannot open shared object file: No such file or directory
However with lagging keystrokes.
Jakob
my problem was exactly the same, only difference is that I have "libstdc++.so.6.0.10" instead of "libstdc++.so.6.0.9"
Jakob
Do this at a terminal (doesn't matter if you're root): apt-cache search canberra
If you see any packages called libcanberra, try to install them.
Otherwise, Google results are popping up with people who already have a version of libcanberra in /usr/lib/gtk-2.0/modules/. Check to see if you have a copy there, and if you do, try the symbolic link trick as above (put the link in /usr/lib).
Otherwise, I don't really have much of an idea, dude. Sorry.
Canberra is for... sound? Maybe changing your default sound driver would fix it?
Also, do you know which flash player you're using? Do you know if it's the proprietary Adobe flash player or the open-source alternative gnash?
The ninja movements are not lagging, but screen rendering is.
Thanks for your help anyway
(btw this is my first official post)
I used Adobe,
Just installed gnash ..
How do I launch n in gnash?
My N game is working
But Userlevels are not working, can it be something with my flash not connecting to the internet ?
//Jakob
The only difference with this would be if you have NReality. If so, and you're talking about the NUMA function built into it not working, then it would most likely be a problem of not communicating with the internet for some reason.
donfuy@donfuy-desktop:~$ ./n_v14
bash: ./n_v14: No such file or directory
donfuy@donfuy-desktop:~$ cd Desktop
donfuy@donfuy-desktop:~/Desktop$ cd n_v1linux
donfuy@donfuy-desktop:~/Desktop/n_v1linux$ /.n_v14
bash: /.n_v14: No such file or directory
donfuy@donfuy-desktop:~/Desktop/n_v1linux$ ./n_v14
donfuy@donfuy-desktop:~/Desktop/n_v1linux$ ls libstdc++*
ls: cannot access libstdc++*: No such file or directory
donfuy@donfuy-desktop:~/Desktop/n_v1linux$ sudo -s
root@donfuy-desktop:~/Desktop/n_v1linux# cd /usr/lib
root@donfuy-desktop:/usr/lib# ls libstdc++*
libstdc++-libc6.2-2.so.3 libstdc++.so.6 libstdc++.so.6.0.10
root@donfuy-desktop:/usr/lib# ln -s libstdc++.so.6.0.10 libstdc++-libc6.2-2.so.3
ln: creating symbolic link `libstdc++-libc6.2-2.so.3': File exists
root@donfuy-desktop:/usr/lib# exit
exit
donfuy@donfuy-desktop:~/Desktop/n_v1linux$ FUCK
bash: FUCK: command not found
sudo -s
cd /usr/lib
rm libstdc++-libc6.2-2.so.3
ln -s /usr/lib/libstdc++.so.6.0.10 libstdc++-libc6.2-2.so.3
./n_v14
