I found using terminal to make hidden folders viewable/unviewable too tedious so I made some automator programs to do it for me.
one to show and one to hide... they are thus named.
Warning!!! it will close all your finder windows.
they are easy to make, but save yourself the trouble and DL them here...
Enjoy...
//Zander
Hidden folders on mac
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/%5D%7BNO3
- Attachments
- HiddenFolders.zip
- (497.71 KiB) Downloaded 229 times
I love you.
Um.
Well, people on Macs should find it useful. So there's not a single option that allows all hidden files/folders to be revealed?
...holy shit. Is that seriously what it takes to make a simple app like this? I was just curious to see your source, but I didn't expect that zip to contain so goddamned much metadata. Two directories, one with an overabundance of underscores, and both at least 8 directories deep.
I have a superior solution in your own goddamned OS (but that also works in mine), and it's only 20 bytes big.
Here it is:
BAM.
The show command would obviously be the other way 'round.
Put that shit in your ~/.${SHELL:t}rc and you're golden, asshole. You'll have bitches hanging off of you like Christmas ornaments begging you to show them how you hide and show your shit so efficiently.
Now go ahead and try it.
Oh my fucking God, I just came.
Here it is:
hide() { mv $1 .$1 }The show command would obviously be the other way 'round.
show() { mv .$1 $1 }Now go ahead and try it.
$ touch foo
$ ls foo
foo
$ hide foo
$ ls -a .foo
.foo
$ show foo
$ ls foo
foo[spoiler="you know i always joked that it would be scary as hell to run into DMX in a dark ally, but secretly when i say 'DMX' i really mean 'Tsukatu'." -kai]"... and when i say 'scary as hell' i really mean 'tight pink shirt'." -kai[/spoiler][/i]
Tsukaddox, I presume?
Seriously what the FUck? all I did was opened automator made it run two terminal scripts, one to change the visibility, another to reload the finder...Tsukatu wrote:...holy shit. Is that seriously what it takes to make a simple app like this? I was just curious to see your source, but I didn't expect that zip to contain so goddamned much metadata. Two directories, one with an overabundance of underscores, and both at least 8 directories deep.
Here it is:BAM.Code: Select all
The show command would obviously be the other way 'round.Put that shit in your ~/.${SHELL:t}rc and you're golden, asshole. You'll have bitches hanging off of you like Christmas ornaments begging you to show them how you hide and show your shit so efficiently.Code: Select all
Now go ahead and try it.Oh my fucking God, I just came.Code: Select all
$ touch foo $ ls foo foo $ hide foo $ ls -a .foo .foo $ show foo $ ls foo foo
I'm no coder, none of that made any sense. and a word of advice you sound like an arse...
cd [i]directory[/i]
ls -a
I highly suggest you rtfm, since you not knowing what he means implies that you don't know the first thing about bash. Suki's example is the proper method of hiding folders, yours is quite inefficient.//Zander wrote:Seriously what the FUck? all I did was opened automator made it run two terminal scripts, one to change the visibility, another to reload the finder...Tsukatu wrote:...holy shit. Is that seriously what it takes to make a simple app like this? I was just curious to see your source, but I didn't expect that zip to contain so goddamned much metadata. Two directories, one with an overabundance of underscores, and both at least 8 directories deep.
Also, giving advice to people who don't ask for it makes you sound like an arse.
Note that this issue is not about hiding and unhiding folders, it's about displaying or not displaying hidden folders. Suki's method is appropriate for actually changing the status of the folders, not for simply listing dotfiles along with everything else. For displaying hidden folders in a Finder window in OS X:scythe33 wrote:I highly suggest you rtfm, since you not knowing what he means implies that you don't know the first thing about bash. Suki's example is the proper method of hiding folders, yours is quite inefficient.
defaults write com.apple.Finder AppleShowAllFiles YESThis will cause Finder to display both dotfiles and system files that it normally hides (/usr, /etc, /lost+found, etc...)
Of course, if you were on Windows, it'd just be Organize > Folder and Search Options > View tab > select "Show Hidden Files and Folders" (Vista and later) or Edit > Folder Options > View tab > select "Show Hidden Files and Folders" (XP and earlier).
Or the following registry files (you can set these to keyboard shortcuts if you're geeky like me)
Show:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
"Hidden"=dword:00000001
"Hidden"=dword:00000000
