King of the Ditch
Postby notsteve » 2008.10.11 (04:52)
i claim legal ownership of the ditch through a series of contracts and other official looking documents, then have you evicted
MBTI Type: ESFJ
Postby jackass » 2008.10.11 (05:47)
I sew you for forging those documents and then evict you back! Therefore its mine
[align=center]Image
Postby Universezero » 2008.10.11 (08:36)
I burn your documents. Then I burn you.
King
Postby jean-luc » 2008.10.12 (06:41)
The FSS Enterprise has been forced to detach it's saucer section due to core failure. While the engineering section (with tactical bridge) stays to continue the fight, under the command of cmdr. Riker, as it is better armed (albeit very awkward looking with the saucer section missing). The saucer section, under the command of cpt. Jean-Luc Picard, proceeds to the nearest space station.
In the midst of the short trip containment in the saucer's ancillary independent propulsion system begins to fail. With hull integrity already at a minimum due to the previous battle, they have no choice but to attempt a landing, something that galaxy-class vessels are not intended to do (much less only half of the vessel).
By freak chance, the saucer section comes to rest directly on top of UniverseZero. Jean-Luc arises from the captains chair, slyle performing the Picard maneuver [obscure star trek reference], and proceeds to the nearest airlock. He steps off the edge of the saucer section (no trivial task, considering that the edge of the saucer section is 3 decks high) in to the ditch. Striking a triumphant pose, he plants the flag of the United Federation of Planets.
MBTI Type: ESFJ
Postby jackass » 2008.10.12 (06:55)
I come along and meanly say "GO AWAY" and you actually listen take your flag and leave .. then i plant my awsumness flag
[align=center]Image
Postby wumbla » 2008.10.16 (01:33)
you make a warm fire and acendentally catch your flag on fire tehn you get upset then you shoot yourself, then i claim the ditch.
eganic wrote:I WUMBLA
YOU WUMBLA
HE SHE ME
WUMBLA
Postby Zora_S_Kenneth » 2008.10.16 (04:11)
You just broke rule 3.
Zelda/Zora S. Kenneth's Rule 3 wrote:No WMDs of any sort. Any moves can only affect ONE PLAYER OR ONE ARMY at any one time.
By using incorrect grammar, you caused fright seizures in several not-so-innocent bystanders. You are evicted. And then, I only wanted the ditch so I could get rid of (aka Ditch) a stupid female not-so friend (aka "Girlfriend" as a few almost taunted me) who keeps following me around and asking me to do all sorts obscene things that almost made me want to call the beef dealers instead.
Nobody's king.
MBTI Type: ESFJ
Postby jackass » 2008.10.16 (06:18)
Hmm no1 has the Ditch then ... Well i make a balloon wall around ditch with me inside ... so everyones afraid theyll pop and wont come near ..
KING!
[align=center]Image
Postby rambo5252 » 2008.10.19 (23:16)
fills ditch with some fricken dirt, and pops the ballons
Thanks Toasters for the siggy
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
Postby isaacx » 2008.10.20 (12:24)
*dig out real ditch*
*goes in*
King
Postby rambo5252 » 2008.10.20 (14:03)
tells you your name is spelled like a retard and ther shouldnt be an X so u run away to your mommy
*king*
Other sigs
Postby notsteve » 2008.10.22 (00:41)
i produce some shady legal documents that throw you off, but you refuse so i bring in the military and force you to leave. then i fill in the ditch
Postby Zora_S_Kenneth » 2008.10.22 (01:34)
The amount of weight that is caused from filling in the ditch causes the bottom to collapse, which in turn empties into a load of hot lava. The top layer cools, but it is thin enough so that if anyone tries to fill in the ditch AGAIN, it will just collapse under them. I discarded a frickin' badger just to check. So I am now giving his mother the queenship.
*BQotV-ABD*
MBTI Type: ESFJ
Postby jackass » 2008.10.22 (10:10)
Whaaat? Yer lets just say the ditch is mine
KING
[align=center]Image
Postby rambo5252 » 2008.10.22 (20:21)
I use the force and lift you outa the ditch and walk in then sarround the ditch with jedis to keep people away, and i put an army of cute little fire breathing 3 ton dragons in the sky
Other sigs
Postby notsteve » 2008.10.22 (23:10)
i step in the ditch and it collapses underneath me
Postby rambo5252 » 2008.10.22 (23:12)
notsteve wrote:i step in the ditch and it collapses underneath me
wait......how would u get in retard, still mine
Other sigs
Postby notsteve » 2008.10.23 (01:41)
im sneaky like that
Postby rambo5252 » 2008.10.23 (19:33)
well now its a hole sarrounded by jetis and dragons (still mine even tho im dead with notsteve)
Other sigs
Postby handofgod » 2008.10.23 (23:09)
me and the jedis and dragons go to the bar and have a few drinks and decide to overthrow you.
even though your dead.
Postby wumbla » 2008.10.24 (00:36)
*takes metications to stop seizures*
summons a giant hand out of teh sky that grabs you and takes you out of the ditch
*king*
YOU WUMBLA
HE SHE ME
WUMBLA
Sonnet
NUMA Profile: http://nmaps.net/user/matttaylor
Postby matttaylor » 2008.10.25 (02:14)
I summon a massive army of dead zombies that eat you and throw you out of the ditch then i step in
*KING*
Sig by Jackass77
Power of Five :-)
izzy wrote:90% of teens today would die if Myspace had a system failure and was completely destroyed.
MBTI Type: ESFJ
Postby jackass » 2008.10.25 (02:16)
Bahahaha by the look of your siggy u go for the tigers so i turn them agaist you using brain control and they kick your A** and i add the finsishing touches and kick you out now the ditch is mine
KING!
[align=center]Image
Postby rambo5252 » 2008.10.25 (02:25)
hmm *rises out of firey-lava* says boo, you run away
*noones king cause dead people cant legally own anything*
Other sigs
Postby 29403 » 2008.10.25 (07:15)
Yeah. I take rambo off your name.
I am king.
Users browsing this forum: No registered users and 52 guests
