Numa map numbers for v1.4 userlevels?
Postby 999_Springs » 2009.03.29 (14:06)
I'm just starting to get some NReality numa highscores, and, obviously, with 161000+ levels to choose from, I'm a bit spoilt for choice here. Does anyone have a list of map numbers corresponding to the userlevels in v1.4, or any other way I can get the numbers?
Postby EdoI » 2009.03.29 (15:45)
I've just found the way to do this! Since we can't search through NUMA by names, we can do this search in Google:
"nmaps.net" "pinball" "arachnid"
In Google, any word between two " has got to be found. If you don't put it, you'll get many meaningless results. So, to find any NUMA map write this:
"nmaps.net" "map name" "author"
And you'll get relevant result. And I'm not writing this from computer where's N, so I can't remember any other map.
Postby Nexx » 2009.03.29 (16:52)
There's a more straightforward way to Google maps:
pinball arachnid site:nmaps.net
Anyway, you can just try obvious numbers, 999_springs. There are a lot of scores on levels 1-10, I'm sure, and other #'s too like 999, 2007, maybe 123, etc. They probably aren't very good maps, but the highscoring competition on them is high.
Also, if you go to n.infunity.com, click on High-Score > Latest > Hot Numa Maps, it shows maps that have recently had a lot of high scores submitted to them. Not that recently is better, but rather that there will be lots of scores for competition.
Postby EdoI » 2009.03.29 (17:00)
Here's one more way:
"$pinball#arachind#" (and optionally) site:nmaps.net
Postby 999_Springs » 2009.03.29 (17:16)
If no-one has a list, I'll start one now. Here are some I found through Google. However, it seems that some maps are just outside Google's reach...
Name - Author - Numa map number
N Pinball arachnid 1
DoorEerie Wildcorpse123 4
The crazy miner formica 7713
Spire Jump Castaway 7037
The Pillars of Creation echarin 7385
Evihcra glenno14 7820
Raindrops great_sea 7744
Velocity great_sea 7459
Desperado jeffkillian 7575
Amun's Revenge Kablizzy 5721
Crustaceous Kablizzy 7232
Inticed littleviking001 5520
Break littleviking001 6479
The Life Aquatic LouDog004 6042
plue maximo 4959
Why must it be so shiney? maximo 5874
Perspective stepself 7964
Aspire tktktk 6627
Real 2x2 challenge daddaluma 6074
Pipe Dreaming Irrelevant 189
One Way mrawlings1078 5899
Sneak In Ninja 5960
OBSCENELY DIFFICULT Talisman 4785
simple challenge 1 tktktk 3728
simple challenge 2 tktktk 3730
simple challenge 3 tktktk 3733
Contraction nevermore 7536
(AAAAAAAAAAAAAAAAARGH! Tabs don't align in posts. GROWL.)
Now to start doing all these levels...
Postby bhz » 2009.04.26 (11:10)
999_Springs wrote:If no-one has a list, I'll start one now. Here are some I found through Google. However, it seems that some maps are just outside Google's reach...
plue				maximo			4959
Aspire				tktktk			6627
Sneak In			Ninja			5960
Fixed!
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby 999_Springs » 2009.04.26 (13:19)
bhz wrote:Fixed!
NOT!
Here are a few more...
Mine Dodger           Gogiga_Gagagigo  11559
Blocky                trib4lmaniac     4816
Day and Night         trib4lmaniac     5384
Thwump Cannon Blast!  blue_tetris      5993
292                   tonito           3677
The Sacred Hole?      Unreal           5086
(used spaces instead of tabs)
Why does mine dodger have a much larger map number thatn all the others!?
Postby EdoI » 2009.04.26 (15:47)
Sprint Brickman 4600
You can also take, for example, all Brickman's maps and search for the map you want. I also guessed this map was rated so I had to see only 43 maps (five pages, since Sprint was on second page I saw only two of them).
