Post a Run!
Postby xaelar » 2009.05.31 (15:48)
16-3:
180.500. It can be much faster if you make a backwardsjump on the right 8 tile. It's just difficult.
Postby ToeFaceKiller » 2009.05.31 (16:02)
Yup, I got .8 doing that jump with a missed gold.
Postby vankusss » 2009.05.31 (16:04)
Tunco123 wrote:
cheesemonger wrote:168648
Speedrun and Highscore.
2 frames behind you! Oh, can't beat kryX, btw.
Oh, what a run.
Anyway;
Speed on ;
-138944
-152230
-2226
138944 taken (i have that faster route from nmaps, dunno why nobody did it without fbf) - slow ending (reaaaally slow)
152230 taken, maybe it's max, i died at 103
2226 too
also 170-4 speed, my first 0th from kryX :P it can be much faster because of my crappy ending
and xaelar nice 16-3
Postby Cheez » 2009.05.31 (16:49)
I've taken two speedruns today: 94-0 and 6-4.
Neither are very good, though. >.>
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby darkshadow » 2009.05.31 (18:05)
I actually think the fastest route on 16-3 is to extend the jump on the second from the left platform to reach the exit platform then jump to the exit switch and jump back to the exit from there.
1 2 3
_________________
1 -> 2 -> 3 -> 2
I just don't know if that's possible without missing either the gold on the right of the second from the left platform or one of the golds on the jump from the leftmost one to it. (Yay for confusing descriptions!)
Edit: Why the crap do the spaces disappear in my horrid ascii drawing? What it's supposed to show is going 2nd->3rd->5th->3rd counting from the left side.
Edit 2: Possible 96-4 beginning?
Edit3: Is it just me or is the end of xaelar's descent on 90-3 significantly faster than kryX's?
Unreality's awesome mod
Postby TheRealOne » 2009.05.31 (20:12)
darkshadow wrote: Edit3: Is it just me or is the end of xaelar's descent on 90-3 significantly faster than kryX's?
I think they are very close if not the exact same speed until the last 1 tile there kryx holds right longer so he falls on the slant of the 1 tile, where as xela goes faster on the last 1 tile and he hits the corner of e tile and 1 tile on the floor, but I can't tell you which one is faster because i don't have the demo data for kryx's run to check with fbf.
Postby Seneschal » 2009.05.31 (20:38)
169020
169026
Both speedruns.
Postby darkshadow » 2009.05.31 (21:16)
I was referring to specifically the last tile not the entire descent. I think that effect might allow a significantly faster fbf/underclock run.
Postby TheRealOne » 2009.05.31 (21:44)
Yeah, I think you are right. I post this a while back and Knu got .650 (374 frames) and he nicks the corner like xela, but he also does the last jump of the chimney differently so I can't how much faster it is to hit that corner, but it faster.
Postby darkshadow » 2009.05.31 (22:10)
TheRealOne wrote:
darkshadow wrote: I was referring to specifically the last tile not the entire descent. I think that effect might allow a significantly faster fbf/underclock run.
I had completely forgotten that Knu did 90-3. That fact that he used that same trick convinces me that it's faster since, given how much time Knu put into perfecting his fbf runs, I can't imagine him using a slower method.
Postby ToeFaceKiller » 2009.05.31 (22:12)
I bet you could easily get a highscore on 90-3 TRO. You should go for it.
Postby TheRealOne » 2009.05.31 (22:22)
ToeFaceKiller wrote:I bet you could easily get a highscore on 90-3 TRO. You should go for it.
I have tried. I really want one. I got a 147.825 with a missed gold once, but I absolutely suck at the double perp jump at the begining going in to the chimney, it messes with the rhythm of my chimney.
Postby Cheez » 2009.05.31 (22:43)
Tied kryX and 999_Springs on that.
Might be able to tie you...
Postby darkshadow » 2009.06.02 (00:08)
Interestingly macrohenry uses a completely different route on 54-2 that's still faster than the old one. Also, what the hell is with the the central bounceblock on 56-4? I've had a run over two seconds faster than the 0th ruined because of it's weird instability.
Postby TheRealOne » 2009.06.02 (00:19)
darkshadow wrote:what the hell is with the the central bounceblock on 56-4? I've had a run over two seconds faster than the 0th ruined because of it's weird instability.
I don't know what you are talking about with the center bounce block, but I can say that, that maps needs some work, xaelar's run seems quite sloppy for a xaelar 0th.
Postby glib_jase » 2009.06.02 (06:42)
darkshadow wrote:Also, what the hell is with the the central bounceblock on 56-4? I've had a run over two seconds faster than the 0th ruined because of it's weird instability.
Weird, I've noticed that before too, it's almost as if that bounceblock is lighter than normal. More bounce than block!
Postby TheRealOne » 2009.06.02 (07:01)
30-1 speedrun innovation
If I didnt royal fuck the end, it would have been a a lot faster than the current 0th.
Postby Izzy » 2009.06.02 (19:08)
TheRealOne wrote:30-1 speedrun innovation
I think that was rabarint's old route before the scoreboard mess up.
Postby ADMINISTRATOR » 2009.06.03 (03:51)
Nice innovation. It's definitely faster. FBF demo
Road_rage
Postby Tunco » 2009.06.03 (19:02)
138552 highscore.
Postby TheRealOne » 2009.06.03 (21:41)
134005 highscore.
Postby xaelar » 2009.06.03 (22:15)
You're crazy...
Postby ToeFaceKiller » 2009.06.03 (22:35)
Haha, that's ridiculous. I made a demo on that map a longg time ago but never submitted till now. Me and a kid were taking shifts on it, heh.
Postby Unreality » 2009.06.04 (10:33)
definitely wasting server space to store those demo :|
Postby Raif » 2009.06.04 (15:02)
980 highscore (164.550(Beaten kryX by 0.150))
