Post a Run!
Postby natrues peril » 2009.10.05 (05:07)
161-3 hs
new route
by nicnac
Postby aids » 2009.10.07 (04:57)
182687 (triple off a corner)
FBF demo on the map.
Postby Raif » 2009.10.09 (11:29)
Some runs with edited ends:-
31-2 highscore
Differences from vankusss's original demo:- No corner hit, better exit key collecting, better end
(5 frames faster than original run)
36-2 highscore
Differences from xaelar's original demo:- 1 frame bbcj, better walljumps, Analu's end
(16 frames faster than original run)
If you have any doubts whether this was a completion remove the |139810 from the end of the demo and watch. You should see that a death from crashing on the floor after thwump proplusion is 377 frames not 376.
136604 speedrun
Differences from Meta_Ing's original demo:- j-n-j end, I also think there might have been a jump on the lowest locked door O_O
(2 frames faster than original run)
Postby vankusss » 2009.10.09 (12:14)
i've pulled off this on 36-2 hs yesterday, but there are several problems:
1) getting the right angle to actually can hit the bbcj
2) get the bbcj right to take the switch and avoid the drone (you can past above it or hit the drone with wrong bbcj's)
3) get new route because you're catching the second drone too early so you can't pass it (maybe it can be attracted when you're at the bottom, but it's pretty random)
4) get the end (with analu's end that would be like 30 frames faster than xela, without i hope maybe 10-15)
Postby Raif » 2009.10.09 (17:56)
vankusss wrote:i've pulled off this on 36-2 hs yesterday, but there are several problems:
I am afraid your methods not very much faster, due to the drone. Here's a 377 frame death demo next to the door with your method:-
And here's my old demo made using xaelar's start, a 376 frame completion (for people who don't want to scroll up) :-
Edit:- Theres something funny with this demo the NReality framecount says its 376 frames while the timer seems to think its 377 frames. Its the same with Analu's demo NReality framecount says its 395 frames while timer seems to think it is 396 frames. (Analu's score shows up as .125 on the scoreboard but when watched it's .100) :/
Postby ska » 2009.10.09 (18:06)
Vankussssss.... you've officially arrived baby.
time to take 'wannabee' out of you sig..
Postby Cheez » 2009.10.09 (23:02)
I knew van would be great from the day he popped up and posted a demo on my map that beat Meta.
EDIT: 178091 speed *0th after so long. D:
182880 speed
182867 speed
182868 speed
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby vankusss » 2009.10.11 (11:08)
ska wrote:Vankussssss.... you've officially arrived baby.
thx :)
Postby ska » 2009.10.11 (14:34)
thx :)
You're my idol!
Postby natrues peril » 2009.10.13 (13:05)
183180 speed
mabye 1 or 2 frames off max
by nicnac
Postby golf » 2009.10.15 (00:42)
556, a couple things about it. First, I don't recall ever seeing a one-way act the way it does for me just under the right side of the roof. Second, I must have been only 1 or 2 frames away from being killed by the laser before I hit the exit...
Postby Raif » 2009.10.16 (10:18)
183437 highscore and speedrun
183430 speedrun (Also someone might want to try htcjing on hs)
182235 speedrun
Triforce
Postby Arctic Fox » 2009.10.16 (14:03)
Well I finally managed to complete this map in userlevels: http://www.nmaps.net/97269
With a score of .3 1.975
It's not really a great speedrun, but I've never seen a Pipes race completed in userlevels before. =D
Postby Cheez » 2009.10.17 (02:36)
181911 speed/hs
Postby ToeFaceKiller » 2009.10.17 (04:54)
golfkid wrote:556, a couple things about it. First, I don't recall ever seeing a one-way act the way it does for me just under the right side of the roof. Second, I must have been only 1 or 2 frames away from being killed by the laser before I hit the exit...
Taken with an innovation on the left side.
Postby Raif » 2009.10.17 (12:34)
Manually made sub-200 demo for 38-1 speed (27 frames faster than current 0th):-
Postby natrues peril » 2009.10.19 (18:12)
183712
1.125 secs
by nicnac
Postby jasdanu » 2009.10.20 (04:35)
183770
Sig: Izzy
Postby natrues peril » 2009.10.21 (18:47)
183888
more or less right through the rocket
by nicnac
Postby jasdanu » 2009.10.22 (00:40)
183912
Sig: Izzy
Postby Izzy » 2009.10.22 (00:53)
65-4 HS taken from L3X.
Posted on van's thread.
Postby MiBeM » 2009.10.22 (14:34)
56-3 speedrun. My 1st 0th, so i'm really proud of it.
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby ska » 2009.10.23 (13:52)
those old maps are just swarming with glitches :P
@Izzy
O_O
Great 0th!
Is that your first metanet 0th?
that's crazy man, good stuff fer pulling that off
Postby 999_Springs » 2009.10.23 (14:17)
The ninja went THROUGH THE BOUNCEBLOCK!?!?!?
I think this level is conspiring against me...
Postby TheRealOne » 2009.10.23 (16:26)
121031 Speedrun
Messed up the ending a little with the pj up top.
Users browsing this forum: No registered users and 61 guests
