Post a Run!
Postby Raif » 2012.05.07 (16:36)
00-0 Speed
Yes, it needs to be in bold. My hands are tired.
Postby vankusss » 2012.05.07 (16:39)
Raif wrote:00-0 Speed
WHAT THE FUCK?????? WHAT? WHAT?
Postby TheRealOne » 2012.05.07 (20:40)
=O WTF?! At your ending. Kool is NOT going to be happy about that.
Postby Kool » 2012.05.08 (04:20)
>____>
(and there goes another 3 hours of my life via taking this back)
great run tho raif, well deserved.
Postby vankusss » 2012.05.09 (17:25)
151-0 sr
i just randomly opened that level, tied 0th within 4 tries, then tried jumping, because why not, right? we never understood how that works. bum, 0th under 1 minute. lol
edit: that is also my second sr 0th where i beat all-board-tied scores (12-3)
Postby 999_Springs » 2012.05.09 (17:57)
151-0 speedrun, tied vankusss after like twelve minutes.
ska queried me this on IRC.
[18:45:07] <Zapmeister> i want to watch this level get maxed out in a week
[18:46:21] <Zapmeister> again
[18:49:38] <ska> XD
[18:49:41] <ska> i doubt it
[18:49:46] <Zapmeister> yeah i checked, you do need to jump to get 152
[18:49:52] <ska> i think it'll be amitious to get 4 or more callers
[18:49:59] <Zapmeister> oj
[18:50:01] <Zapmeister> kool
[18:50:02] <Zapmeister> you
[18:50:06] <Zapmeister> therealone
[18:50:06] <ska> mm
[18:50:14] <ska> i tell you what
[18:50:23] <ska> if you get /more/ than 6 callers in a week
[18:50:24] <Zapmeister> at least 2 or 3 rising random speedrunners i've never heard of
[18:50:27] <ska> i'll give you a ded
[18:50:36] <Zapmeister> alright
[18:50:38] <ska> if not, you ded a map to me. ok?
[18:50:48] <Zapmeister> i've never made a map, but, meh
[18:50:51] <Zapmeister> fine
[18:50:54] <ska> :D
HEY EVERYONE GET ON 151-0 SPEEDRUN AND REMEMBER TO DO THE JUMP AT THE END TO GET 152
vankusss, myself and ska all did it, so I only need 4 more to win the bet. GET IN THERE
edit: kool-aid did it 1 second after ska. 3 more people please
edit: outrightoj did it, need 2 more people
edit: nice one chrisE
edit: golfkid got it. ska, you owe me a ded now :P
Postby ska » 2012.05.09 (18:09)
FUCK YOU. YOU MOTHERFUCKING CUNT TOAD.
Respect.
Postby eru_bahagon » 2012.05.09 (21:12)
Why does jumping works on that level, and not like, on 14-2 ?
(I tried, but just like 30 times... don't know if you need some luck)
Postby TheRealOne » 2012.05.09 (21:55)
eru_bahagon wrote:Why does jumping works on that level, and not like, on 14-2 ?
Got on 151-0 to make Ska Dedicate a map.
I think it has to do with footing. Like jumping on 14-2 gets you closer to the door on the second to last frame, but doesn't get you far enough to reach it a frame earlier. I know it sounds like a cop-out I always use to explain things, but it really has a lot to do with how N works and how certain glitches work. If Unreality felt like making a new version I would request that he puts in a position, hspeed, and vspeed counters next to the frame counter. That would show a lot that we want to know.
Postby Raif » 2012.05.11 (04:04)
Got .925 on 5-2 speed as well.
This is the second level where I have all 3 (hs/sr/uc) 0ths. Already had 16-1 before. (Edit: Got 63-4 as well, by taking the uc 0th)
On another note, .925 on 5-2 is surprisingly easy. Got it in slightly under half an hour this time.
Postby 999_Springs » 2012.05.14 (19:55)
Yay, a thousand nreality legit mode level top20s again.
Did that for no reason at all except 1) to spite Eddy 2) to confirm that I'm still lurking around this place and 3) to procrastinate working.
edit: Apparently the average time to take breakfast in Ecuador is 6:38. :/
Edit 2: LouDog004, going through all my legit mode 19ths and sequentially bumping them off is really not funny and has absolutely no point whatsoever except to waste both of our time. >:(
Postby TheRealOne » 2012.05.14 (21:17)
999_Springs wrote: Edit 2: LouDog004, going through all my legit mode 19ths and sequentially bumping them off is really not funny and has absolutely no point whatsoever except to waste both of our time. >:(
I think it is rather funny.
Postby ska » 2012.05.14 (22:35)
219434 sr
Postby Kool » 2012.05.16 (22:54)
183-0 sr taken back, nice innov van. tested a cs at the switch, but I'd either hit a drone, chain, or miss the bb completely. Somebody improve :)
Postby Raif » 2012.05.18 (16:33)
69930 hs/sr
Postby ska » 2012.05.19 (05:44)
Raif wrote:69930 hs/sr
Nice run. Taken by 0.2 seconds.
Not actually an admin
Postby Paradox » 2012.05.19 (13:03)
121027 hs sr 2nd, also (AS I SEE IT) Kools chimney was not a perfect chimney because of the trap & when his demo is played on a map with the missing tiles & without the trap
Frame 32
Frame 33 & Frame 33 without One-Way
Image Image
As it says on the wikia, http://n.wikia.com/wiki/Kool-aid the demo has a jnnj at frames 19-22
He did reach the exit in 32 frames, with the help of a trap, the equilivant of a perfect chimney, but not a 'perfect chimney' (jnjnjnjnj...)
Postby Kool » 2012.05.19 (18:50)
Paradox wrote:121027 hs sr 2nd, also (AS I SEE IT) Kools chimney was not a perfect chimney because of the trap & when his demo is played on a map with the missing tiles & without the trap
Frame 32
Image Image
yes yes we all know this, I got one jnnj. But still, you think you can tie me or better yet get an absolute perfect chimney? gl ;)
Edit: good job on 2nd tho nioce
Postby vankusss » 2012.05.19 (22:33)
Kool wrote:yes yes we all know this, I got one jnnj. But still, you think you can tie me or better yet get an absolute perfect chimney? gl ;)
you're high
Postby amomentlikethis » 2012.05.21 (18:56)
Unless it's somehow improvable, 52-3 speedrun is now fully maxed out (sorry Analu!).
Hi.
Postby 999_Springs » 2012.05.22 (19:04)
amomentlikethis wrote:Unless it's somehow improvable, 52-3 speedrun is now fully maxed out (sorry Analu!).
You can fully max out 151-0 too if you want. Get on it.
edit: ToeFaceKiller beat you to it.
Postby EddyMataGallos » 2012.05.22 (19:13)
Now that you mentioned it, has anybody done 151-0 sr in WinXP? Because I did it in Win7, but the day after that I uninstalled my OS and went back to WinXP again (though this is not the reason, N goes perfect here!). Ok, so I tried doing 152 frames in 151-0 sr again, and guess what, its not possible. I don't know if its because of the OS or because of my PC, but seriously, I tried hard, a bunch of times, and none gave result. I tried copying other people's run with ghost mode on and nothing worked. Compared to Win7 in which it was absurdly easy to do it, just jumping and you got most times. I mean, im pretty sure its not possible to do it here (in my computer at least). This is really weird.
Postby Kool » 2012.05.22 (19:34)
That's weird, I highscore on XP and I literally got it on the 2nd or 3rd try.
Postby EddyMataGallos » 2012.05.22 (21:08)
Crap then its because of my PC then :S I did also achieve it in 3 or 4 tries, and did it again a bunch, I dont know if I should be worried of this haha
Postby ska » 2012.05.22 (23:00)
EddyMataGallos wrote:Crap then its because of my PC then :S I did also achieve it in 3 or 4 tries, and did it again a bunch, I dont know if I should be worried of this haha
The 152 demos display the correct frame count though, right? Have you tried replicating a 152 run in FBF?
