Postby Unreality » 2009.03.11 (05:37)
UniverseZero wrote:
Unreality wrote:
UniverseZero wrote:The new Nreality doesn't seem to have the same .sol file; all my flavours and completed columns are gone, I'm not sure what's happened. :/ Because, when I open the original N, it has all of my save data.
is your NReality 6d4 a "Flash player 10" version? or a "Flash player 9" version?
Adobe Flash Player 9.0 r115
Should I get 10?
9 is the correct one.
Strange it shouldn't eat your data :( have you backup the sol?
NUMA Profile: http://nmaps.net/user/esay
Postby esay » 2009.03.11 (05:44)
I have the same problem as UZ, it still shows my N progress in The old NReality, and in N_v14, but it doesn't show it in the New NReality. If you complete a level in the new NReality, it is there the next time, therefore it must be keeping an additional .sol file somewhere else..
Also, if you want I will make you a special forum, I'm quite good at that kind of stuff.
MBTI Type: ESTJ
Postby Kablamo » 2009.03.11 (06:33)
Got the same prob as both UZ and esay, it hasnt eaten our data (cause its still in the n_v1.4) Is there perhaps a new .sol file created?
cause its annoying having no completed columns and no flavours. >:(
Hi Everybody!
Postby Unreality » 2009.03.11 (09:34)
it will be good if you can check the folder to see whether a new sol has been created or not.... since I haven't faced this problem and I don't know how to debug
Postby esay » 2009.03.11 (18:32)
My .sol files don't show up regardless in a search, so mine didn't find anything, but when kablamo's normal one does show up, it doesn't show up this supposed new .sol - quite strange.
Postby EdoI » 2009.03.11 (18:59)
Today I started submitting my highscores for the very first time, and I should have 13th highscore on 00-4, but that's not the case. Look: my highscores; 00-4 highscores; Interesting.
Postby ToeFaceKiller » 2009.03.11 (19:31)
I'm not having the problem everyone else is, which seems strange. Why would some people have it and some not? I'm also using Flash Player 9.
Postby The Kitchen Sink » 2009.03.12 (02:45)
ToeFaceKiller wrote:I'm not having the problem everyone else is, which seems strange. Why would some people have it and some not? I'm also using Flash Player 9.
Hahaha
"Why would some people have it and some not?"
Hahaha
Sorry. I mean, really though. It's not like every computer is a complete 100% clone of the other. Any discrepancy could be the source of the problem.
Although I would like to add that I am experiencing no such problem. Perhaps this is an OS thing. I'm on XP (SP2). I'll bet you those experiencing the problem are on Vista.
MBTI Type: ESTJ
Postby Kablamo » 2009.03.12 (05:24)
The Kitchen Sink wrote: Although I would like to add that I am experiencing no such problem. Perhaps this is an OS thing. I'm on XP (SP2). I'll bet you those experiencing the problem are on Vista.
yeap. we are all on vista :p
Hi Everybody!
Postby Unreality » 2009.03.12 (05:25)
EdoI wrote:Today I started submitting my highscores for the very first time, and I should have 13th highscore on 00-4, but that's not the case. Look: my highscores; 00-4 highscores; Interesting.
That is because your run is not a NReality run. Only run that is made in NReality will be considered "legit".
In n_v14, people use speedhack or sol editing to make illegal scores. NReality blocks all of this, so the runs that made in NReality will be ranked higher.
MBTI Type: ESTP
Postby kkstrong » 2009.03.12 (16:15)
Hmmm...suggestion for NReality
acceleration/decceleration of drones and objects.
for example:
a value of 1.001 for acceleration will speed up the the drone/object by 1.001x every second.
a value of 6 for acceleration will speed up the drone/object by 6x every second.
a value of .5 for decceleration will slow down the drone/object by 2x every second.
I ran it by some of the people in #n-highscores , and they thought it was a cool idea that could produce some really cool puzzles.
Postby TheRealOne » 2009.03.12 (16:54)
kkstrong wrote:Hmmm...suggestion for NReality
for example:
I really like that idea. I think it would be cool if someone applied it to n, so that as you progressed through the lvl you got slower until you just stopped. that would make for a cool new way to make people do a map quicker than the 90seconds with out just blocking off the exit with a timed drone.
Postby Brainwasher » 2009.03.12 (20:34)
Unreality wrote:In n_v14, people use speedhack or sol editing to make illegal scores. NReality blocks all of this, so the runs that made in NReality will be ranked higher.
does that mean that you can score now in episode 00 in legit mode?
Now back from life.
Postby ToeFaceKiller » 2009.03.12 (23:02)
Yeah, that's been the case since legit mode came out.
Postby The Kitchen Sink » 2009.03.12 (23:18)
for example:
It would be per frame, not per second, and it would be better if it were additive instead of multiplicative, IMO. Overall a neat idea, but I'm not sure it would be all that possible.
IMO it would be better, if possible, to allow us to use equations and variables when it came to numbers like speed/radius. Variables such as frame # or time left. This would ultimately accomplish the same thing, with many other applications as well.
Postby Unreality » 2009.03.13 (01:42)
for example:
hey have you noticed that when you set the drone speed it will need to be 1,2,3,4,6,8,12,24 etc? cause it has to be a factor of 24 (or 36? I forget), otherwise the drone will pass through the tiles. It is how the system work and will be quite hard to change.
To implement your suggestion will need a new full set of AI pathing... and consume much more cpu
Postby Unreality » 2009.03.13 (01:44)
yep. please kindly read the readme.txt in the NReality folder for more detail
Postby Unreality » 2009.03.13 (17:34)
sry nreality server is down at the moment. i will post the status everyday
MBTI Type: ESTP
Postby kkstrong » 2009.03.13 (18:44)
Is there any other round about ways of messing with acceleration? It would be a really cool tool.
Postby 999_Springs » 2009.03.13 (19:51)
Unreality wrote:sry nreality server is down at the moment. i will post the status everyday
Argh. And just when I had a nice *0th that I had been working on since Wednesday that I really wanted to submit. The score database is still there, hopefully?
Postby EdoI » 2009.03.13 (20:59)
Patience, patience, I know... but when could the server be up again? I improved some scores, so...
Postby Unreality » 2009.03.14 (03:39)
server is up :)
Postby Raif » 2009.03.14 (04:38)
Unreality wrote:server is up :)
And no scores are missing :)
Postby Nexx » 2009.03.14 (05:00)
It is? Neither thumbs nor scores are loading, and n.infunity.com gives me "Page Error".
Postby Unreality » 2009.03.14 (05:13)
The server is very unstable.. the ISP technician will come to check in 10 hours
