Postby EddyMataGallos » 2011.12.05 (17:11)
Map: 4-0
Time Saved: 20-30 frames
Difficulty: Easy
Current Route:
New Route:
CJ route [Thanks to Raif] Over a second saved:
Postby TheRealOne » 2011.12.07 (05:20)
Map: 05-0
Time Saved: 2 frames
Difficulty: Easy
Current Route
New Route
Paradox-dragon posted a run with this in it, and me and golf thought it was rather interesting. It doesn't really save much if anything but it found it rather cool looking if nothing else.
Postby TheRealOne » 2011.12.09 (00:59)
Map: 37-4
Time Saved: 16 Frames
Difficulty: Easy
Current Route
New Route - Triple Jump
Map: 14-1
Time Saved: 4 frames
Difficulty: Easy
Current Route
New Route - Don't Triple Jump
Postby TheRealOne » 2011.12.16 (05:47)
Map: 25-1
Time Saved: ??? Decent Amount
Difficulty: Moderate
New Route
I was going to save this route change for my self, but i got fed up with trying. The route isn't that hard at all and it is faster than Lim. I do not know by how much because I didn't make it as a test map, but if you watch my demo with the lim's run on the demo feature you can see i beat him to the top left switch, but then I fuck up. Also I am rather slow here, you can go much faster.
Also this double CJ route should be a little faster than the above, but also harder.
Postby vankusss » 2011.12.16 (14:38)
TheRealOne wrote:Map: 25-1
New Route
Awesome innov, took 0th with it. I suppose it can be cleaned a lot.
Postby eru_bahagon » 2011.12.16 (15:36)
Yeah took 1st. Thx TRO
Probably around 141 is possible with very good cj (like van's ones).
Postby TheRealOne » 2011.12.16 (19:40)
Yeah, Wow van. I didn't think the innovation was that fast. There is definitely room to push it to 141.000, but that will mean getting a fast pj in the middle like I do, and even mine is slow compared to a few others I got. The problem is if you go for it you are very likely to miss a gold.
Postby eru_bahagon » 2011.12.16 (19:50)
What is a pj ? push jump ?
What is it ?
Postby Raif » 2011.12.16 (20:11)
eru_bahagon wrote:What is a pj ? push jump ?
What is it ?
Perpendicular jump, also known as reverse jump.
Postby glib_jase » 2011.12.18 (00:47)
TheRealOne wrote:Yeah, Wow van. I didn't think the innovation was that fast. There is definitely room to push it to 141.000, but that will mean getting a fast pj in the middle like I do, and even mine is slow compared to a few others I got. The problem is if you go for it you are very likely to miss a gold.
Agreed, that gold is not my friend.
Postby ska » 2011.12.18 (05:17)
Just a tip, I found it a lot easier when testing to just simply wall jump instead of RJ but that's just me, it might be a frame or two slower but it's a hell of a lot easier to pull off...
Postby eru_bahagon » 2011.12.18 (06:41)
ska wrote:Just a tip, I found it a lot easier when testing to just simply wall jump instead of RJ but that's just me, it might be a frame or two slower but it's a hell of a lot easier to pull off...
Having tried Lim's route before, I found easier to "pj" and not "wj". Maybe it is just about the vertical speed...
Postby ska » 2011.12.18 (09:34)
Well, my girlfriend finds it easier to bj instead of hj so she can still dj.
Postby TheRealOne » 2011.12.18 (23:20)
Map: 41-2
Time Saved: ~.300
This is basically a total route change. I hit the floor at .875 so that means I probably got the door around .950 Someone better than me could probably push the map up to 145.000 with this, unless for some reason that gold I miss take a lot of time, but I don't see why that would happen because Lim doesn't lose much getting those gold in the exact same fashion. Also of course anywhere you could throw in a CK would speed things up, but those are tough. I am thinking maybe on the bottom right E tile would be a nice place to throw one because of the angle you come off the wall would make it plausible.
Postby glib_jase » 2011.12.19 (19:05)
My current 25-1 HS. Is my change of route on the left hand side any quicker?
Postby vankusss » 2011.12.19 (19:32)
glib_jase wrote:My current 25-1 HS. Is my change of route on the left hand side any quicker?
You can easily test that yourself by creating a test map. For this time, I did that for you:
According to my runs, it's pretty much equal. But I guess you know which one is 100x easier :P
Postby vankusss » 2011.12.19 (23:08)
TheRealOne wrote:Map: 41-2
Time Saved: ~.300
The ck in bottom left, which is necessary to take the left bottom gold, might render your left wall climbing impossible to do. But dunno, I didn't try.
I made my own route though, which may or may not be faster than current 0th's/yours route. I found it easier at least.
Lords a-Leaping
Postby mfb » 2011.12.21 (20:48)
You can spend ~1/3s for a small corner jump at the upper right platform (left side) to get the gold at the wall earlier. No idea whether that is better than getting the gold with the last jump.
Postby trance » 2011.12.23 (02:55)
On 81-4 sr, it is possible to get across with hitting the corner of the second thwump. Is it possible for this route to be used to take the current sr 0th*?
Sig by Aidiera.
My Accomplishments
I have 167 speedrun Episode Top-20s and I'm 4th on the boards. :D
Postby TheRealOne » 2012.01.06 (07:15)
Map: 78-1
Time Saved: ???
Difficulty: Easier than Analu's current route
This just seems a hell of a lot easier and a little faster than Analu's triple corner jump route.
Postby ska » 2012.01.07 (06:22)
trance wrote:On 81-4 sr, it is possible to get across with hitting the corner of the second thwump. Is it possible for this route to be used to take the current sr 0th*?
userlevels data only please.
Not actually an admin
Postby Paradox » 2012.01.07 (09:45)
96-4
sr
possibly impossible
3 demos showing how close i can get to make the gap to beat the drones, basically, you need to perfect the start & get the cj to be able to hit the 1Q tile before the drone blocks it
I'm sure someone else could get a much closer demo
The main problem is getting enough speed off the cj & the wj as well as getting the angle perfect, i've tried this a bit more & it's probably impossible unless someone can get the key at the start fast enough
Postby glib_jase » 2012.01.07 (12:12)
61-4 HS
The idea is to beat the first drone to the right hand side door switch. In this demo I then go under the drone although it is quicker to go over it, and once you drop down to the bottom all the gold on the right should be collected.
From the bottom I ideally want to get up to the left switch in one go (just miss it in the demo and have to do a WJ) - however I'm not sure this is possible due to having to avoid the drone at the top?
After hitting the next switch on the left I'm not sure whether to try and take the top gold and beat the drone again on the right hand side, or to take the route in the demo and then get the top gold on the way back to try and beat the drone to the left switch? Either way the drone paths are extremely annoying.
Postby vankusss » 2012.01.07 (12:16)
Paradox-Dragon wrote:96-4
sr
possibly impossible
It's not really an innov, because it doesn't speed up anything. You end up in the same route after doing that (unless you're willing to find a whole new route after that - good luck).
Postby Paradox » 2012.01.08 (12:26)
vankusss wrote: It's not really an innov, because it doesn't speed up anything. You end up in the same route after doing that (unless you're willing to find a whole new route after that - good luck).
Yeah, that's a big problem with 96-4, all the different routes, some with fast drone dodges, they all end up at the same pace, unless you can are able to get to the next pace
Hmm, i only watched lats sr 0th & sort of predicted being about 40 frames ahead of where he was, basically, this is what i came up with, the part i skipped where he goes from the bottom to the top, just do his route, only you will be ahead of him in frames, hopefully you don't go too fast to hit a drone, & then for the ending i changed it as going left only has a few quick drone jumps, the hardest one would be just after you get the exit key to go between the 2 drones
Black - First route
Red - Return route
Blue/purple - Alternative
