Postby ska » 2012.02.11 (05:52)
40-0
I think it might be a little faster...
Not actually an admin
Postby Paradox » 2012.02.11 (07:57)
ska wrote:40-4
You mean 40-0
Postby ska » 2012.02.11 (08:03)
Paradox-Dragon wrote:
ska wrote:40-4
You mean 40-0
oops, yeah haha. I was like: "don't write 40-4. don't write 40-4. don't write 40-4." so of course that's what I do write.
Postby glib_jase » 2012.02.11 (16:40)
ska wrote:40-0
Yeah it must be, I managed to get 2nd (sorry!) with a fairly rough run.
Postby ska » 2012.02.12 (13:31)
glib_jase wrote:
ska wrote:40-0
MY ANGER IS NOW MORE THAN YOU COULD EVER POSSIBLY KNOW.
Postby TheRealOne » 2012.02.12 (17:07)
glib_jase wrote:
ska wrote:40-0
If you watch with the demo feature on van's run you had 0th up until the very last jump. you jumped too early so you didn't get the push from the 1 tile and van past you. So that route is certainly faster.
Postby eru_bahagon » 2012.02.12 (22:03)
Thx for 40-0.
My ending is .2 faster, at least. (:p van)
And my beginning too, if you don't touch the wall (I got a shitty one). Because you'll start falling earlier, thus you'll have more speed.
PS : Pablo228 got a 162 route. Not completely sure if it's possible, but probably. I'm trying.
Starting with van's route, you try to collect all the gold in one jump less, i.e. starting by collecting 2 by 2 from the top. I can get the first jumps right.
Postby vankusss » 2012.02.13 (11:23)
eru_bahagon wrote:Starting with van's route, you try to collect all the gold in one jump less, i.e. starting by collecting 2 by 2 from the top. I can get the first jumps right.
That looks best. Combine these 2 runs for agd and profit:
never got agd even on test map
Postby ska » 2012.02.13 (12:48)
We're making good progress here, guys. Nice work.
Postby vankusss » 2012.02.13 (18:33)
63-3
just do 2 more cjs at the end and you should be faster
Postby glib_jase » 2012.02.13 (20:59)
40-4.
This is possibly quicker than having to do the extra WJ on each side of the map?
Postby Raif » 2012.02.13 (23:38)
That reminds me, ska whatever happened to your route change for 40-4? Why have you still not done it? D:
Postby ska » 2012.02.14 (04:54)
mohamedraif wrote:That reminds me, ska whatever happened to your route change for 40-4? Why have you still not done it? D:
I retired! XD
51-1: compare my 139.250 run to xaelar's 0th. Notice the difference after the exit of the bottom right room...
Postby vankusss » 2012.02.17 (13:37)
43-4, can anyone do something with it?
Postby TheRealOne » 2012.02.17 (13:52)
vankusss wrote:43-4, can anyone do something with it?
If you can get better WJs or a BBCK or something so that you can beat the first drone then it is useful. Otherwise since you are limited by the drones you will just end up tied with Ska.
Postby TheRealOne » 2012.02.20 (03:27)
Map: 69-2
Time Saved: 6 Frames
Difficulty: Super Easy
Current Route: Lim waits to fall to the 1-tile before jumping.
New Route: Just wall jump instead of waiting to slope jump.
This is a super small innovation, and 6 frame probably isn't enough to beat Lim's great run, but it is also about as easy as 6 frames can come.
Postby ska » 2012.02.20 (15:52)
44-3 on the highscores board (currently 4th place).. If I can find a way to optimise the end, it could be a new 0th route. (you could even improve the 0th by simply using the normal route for the 2nd half...
Edit: Just thought I'd add that the drone can be problematic on the right side on the final ascent. The best way to counter this (assuming you choose to use part 2 of the innov), is to feint out wide to prevent the seeker from charging at you - but it's easier said than done because you can't afford to miss the gold...
Postby eru_bahagon » 2012.02.20 (16:34)
44-3. But keep misspelling the levels :P
Your route seems easier, I'll give a try. I might even consider giving you credits for it :)
Postby ska » 2012.02.21 (05:28)
eru_bahagon wrote:44-3. But keep misspelling the levels :P
Son of a bitttttttttttttttttttttch. You're right.. I really have to stop posting these innovations in the dead of night.
Postby DJ_M » 2012.02.21 (16:28)
69-2 sr
My demo is slower than the current 0th but someone might be able to do something with it.
Postby TheRealOne » 2012.02.21 (17:59)
This is why we don't give you credit for your innovations. You don't even know what level you are innovating ;)
Postby ska » 2012.02.21 (18:34)
Where did I park my car? What year is this? Who Killed Kenny? Does my butt look big in this? Where am I?
Postby glib_jase » 2012.02.27 (06:35)
Due to the "semi-random" nature of chainguns it may be possible to get this to work on 9-0 which should be faster than using the jump-pad?
Postby ska » 2012.02.27 (12:18)
glib_jase wrote:Due to the "semi-random" nature of chainguns it may be possible to get this to work on 9-0 which should be faster than using the jump-pad?
good idea.. but it's not very effective, even without the chaingun...
what is effective is the falling corner jump on the left side...
Postby eru_bahagon » 2012.02.27 (13:58)
Better use the same beginning as me (not mine!). Faster than ska. And pretty similar to your demo.
