That was my first thought too, but xaelar's way needs to be pretty much perfect, so the cj might be easier.ska wrote:heh.. that actually looks harder to me with the corner jump. (I'll take your word for it!)macrohenry wrote:73-2:
I know, xaelar already beat the drone, but this way it's easier. However, you'll need another innovation to beat the drone on the left.
Also useful for speedruns!
With all of the low jump innovations being thrown around I'll suggest this one. A LJ or CK will get it done, but this is probably too hard to get with any reliability.
Basically, if you watch my newly made 1st run, you'll see I get pushed down by the thwump. You can actually get nudged down clip the switch on your way down, saving a significant number of frames... macrohenry might want to look into this. I've been ahead by maybe 0.3 or so near that double jump, but botched the run. Good luck to anyone who tries...
Did you do this on purpose? ;) I won't try that, but maybe someone else will. I never liked this level.ska wrote:35-3.
Potential 53-0 innovation:
I'm not even sure if it's faster, but maybe someone wants to try: If you chimney and hit the corner on the left at a certain angle you might get some horizontal speed. Very, very rough execution:
Surprisingly, yes!macrohenry wrote:Did you do this on purpose? ;) I won't try that, but maybe someone else will. I never liked this level.ska wrote:35-3.
Do you mean, nudged down by the last thwump and then taking the switch? Because not even Raif's MBD does that, so if possible, that should be added. Raif gets the first thwump push, and the walljumps and grabs the switch on the way down, with no push this time though.ska wrote:35-3.
By the way, I think this has already been suggested (by Kool iirc, and probably more people), so maybe its just plain impossible, but now that we are talking about 35-3, I'll just leave this here:
i didn't do it in my 126.750 run - it was only half the innovation, but it's definitely possible - only done it once, however.EddyMataGallos wrote:Do you mean, nudged down by the last thwump and then taking the switch? Because not even Raif's MBD does that, so if possible, that should be added. Raif gets the first thwump push, and the walljumps and grabs the switch on the way down, with no push this time though.ska wrote:35-3.
The other one you showed I've tried before and it just doesn't seem remotely plausible to me... the trajectory required would get you smashed by the bottom thwump every time!
Oh, the first thing is great to know, the second, not so much :Pska wrote:i didn't do it in my 126.750 run - it was only half the innovation, but it's definitely possible - only done it once, however.
I had no luck, but I didn't spend too much time trying. Here is a little test map.EddyMataGallos wrote:Do you mean, nudged down by the last thwump and then taking the switch? Because not even Raif's MBD does that, so if possible, that should be added. Raif gets the first thwump push, and the walljumps and grabs the switch on the way down, with no push this time though.ska wrote:35-3.
TheRealOne wrote:I had no luck, but I didn't spend too much time trying. Here is a little test map.EddyMataGallos wrote:Do you mean, nudged down by the last thwump and then taking the switch? Because not even Raif's MBD does that, so if possible, that should be added. Raif gets the first thwump push, and the walljumps and grabs the switch on the way down, with no push this time though.ska wrote:35-3.
Nice, i keep getting results similar to this...
Also like this push
69-3
This innovation is super hard, right in the middle of the run, and guarantees death or missed gold if attempted and failed, but someone should totally pull it off.
EDIT:
18-0
Two different endings here that involve taking the 3 gold on the lower right platform before going in to the center to get the exit switch.
Easy Version
Hard Version
Yeah, clever combo!alsojp27ace wrote:A simple little innovation for 55-2, I might try for a proper run later.
Why not add another CJ to an already super hard ending?
Unfortunately, there's that drone near the end which you have to beat and I haven't figured out if it's even possible. You need another innovation for the top part with the thwumps or you won't be able to beat that drone. However, in case you manage to do it you continue like this:
This would be around 126 with all the gold.
I don't think it's possible, even with a really really awesome innovation for the thwump part, but maybe if you're super fast you might even be able to beat the drone at the very end:
This would have been around 127.
macrohenry wrote:While trying to retake 56-1 I came up with a new route.
I like the ideas. This map certainly has a more optimal route, but it does require reinventing the entire route to make it happen. That said I don't really have anything in mind, but here is a little test map for anyone looking to innovate the thwump section. Would someone please lay down a good clean run of the current route as a baseline, because apparently I suck and cannot make that happen right now...
Take this for instance:TheRealOne wrote:I like the ideas. This map certainly has a more optimal route, but it does require reinventing the entire route to make it happen. That said I don't really have anything in mind, but here is a little test map for anyone looking to innovate the thwump section. Would someone please lay down a good clean run of the current route as a baseline, because apparently I suck and cannot make that happen right now...
Time to beat: 244 frames
Bit slower than Eddy's demo, but my route can be slightly faster if you do the ending properly. But even if you pull it off cleanly it will not be enough, I guess.
A very difficult innovation (at the beginning) I came up with a few weeks ago, requiring 2 additional corner jumps. It still wasn't enough to beat another drone, but I came relatively close.
woah... I still stand by getting that extra piece, combined with a clean run/innovs.macrohenry wrote:58-3
So this is possible. Probably too hard and I have no idea what it means for the drones later on, but it is much faster.
Super Hard Half Second Innovation:
- Normal Route
- Innovation:
Random Thought, This May be too Close to Call:
- Normal Route:
- Possible Innovation:
Users browsing this forum: No registered users and 44 guests
