Post a Run!
Postby darkshadow » 2009.07.17 (15:24)
TheRealOne wrote:
glib_jase wrote:
darkshadow wrote:God Friggin' Damn It!
Edit: Got it five tries later.
Dude, that is an awesome innovation - how do you spot this kind of stuff? It just goes to show that even when a high scoring route looks like it has no alternative, it's always worth taking a second look.
Also, very nice 96-1 run, no way I can compete with that. I've given up trying to get that lower gold on the left when dropping down - it's the one point during the run when you need to avoid the rocket and you can't get far enough to the right at the top of the jump to get the right angle. Although no doubt someone will prove me wrong ;-)
Acctually that innovation was Meta_ing's. He showed it to me yesterday, and I let it slip to dark about it and he took the 0th a short while later.
Actually all you did was remind me to retry routes on that level using the jump pad. I had to come up with the route myself because I couldn't understand you when you described the route with a six-letter acronym. While meta came up with it first I did come up with that route independently.
Unreality's awesome mod
Postby vankusss » 2009.07.17 (19:44)
175006
hs and sr (depends on the route, it can be the same with right route)
slow FBF sr demo
i think that OutrightOJ is near max for hs with his 149 (submitted on sr)
i found this map pretty fun, that's because i'm putting it here
Postby jasdanu » 2009.07.17 (20:01)
175026 highscore and speedrun
Sig: Izzy
Postby xaelar » 2009.07.17 (23:47)
vankusss wrote:175006
slow FBF sr demo
149 frame highscore, 148 frame speed,
131 frame underclock run, anyone up for this? :D
EDIT: 175026:
130 frames hs / sr, 125 underclock
Postby Raif » 2009.07.18 (10:02)
175062 highscore and speedrun (both). I found this map pretty fun.
Postby ska » 2009.07.18 (12:42)
mohamedraif wrote:175062 highscore and speedrun (both). I found this map pretty fun.
Claimed the highscore
Edit: Ties xaelar's speed run... twice in a row
Postby bhz » 2009.07.18 (16:18)
MickyTP wrote:84943. Really like my innovation. Should be easily improbable though.
I don't think you submitted it
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby ToeFaceKiller » 2009.07.18 (16:41)
It's 89493 xP
Postby Raif » 2009.07.18 (17:28)
ToeFaceKiller wrote:It's 89493 xP
Taken both 0ths on that level (both speedrun and highscore)
Postby Cheez » 2009.07.18 (17:36)
You made that run as I was playing it. :D
Trying to beat that run. :/
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby Raif » 2009.07.18 (18:20)
Taken highscore back from vankusss with a bad run. However, I don't have much time to play right now so it'll have to stay as it is.
Edit:- Taken back speedrun from vankusss too. Now I really have to go.
Postby bhz » 2009.07.19 (11:52)
26476 from kryx
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby darkshadow » 2009.07.19 (18:07)
The start of my 6-2 run is much faster than the current route. I'd like to see what xaelar or eru could do with it.
Edit: Another kryX bites the dust. 93-3. The route can be modified even more to do this (yes AGD is easily possible):
Postby jasdanu » 2009.07.19 (23:53)
speed on 175257
Sig: Izzy
Postby eru_bahagon » 2009.07.20 (14:31)
0th ;)
Nice innovation. I've become 195.025 with a missed gold.
Postby aids » 2009.07.20 (14:50)
Took 80000 from Meta.
Postby darkshadow » 2009.07.20 (15:50)
Anyone want to try this on 6-4 speed (I'm still pretty pissed I screwed this up)?
Edit: And will someone please put together a decent run on 26-3 speed.
Edit: My 18-3 can be improved to at least 127.500 if not more.
Postby 999_Springs » 2009.07.20 (16:40)
Is this usually what happens on 10-1 or is it just me?
Postby jasdanu » 2009.07.22 (03:01)
175449
Sig: Izzy
Postby TheRealOne » 2009.07.22 (17:55)
jasdanu wrote:175449
Taken by 13 frames over Van, with a pretty crappy run.
Postby darkshadow » 2009.07.22 (20:08)
33-4. I've had a route on the backburner for awhile that could reach well over 142 but required a lot of difficult jumps and needed one spot on rocket dodge so I decided that for now I'd just take it with this. (Interesting fact the route that gets to over 142 shares pretty much nothing with LAT's route)
Postby xaelar » 2009.07.22 (20:16)
Tied you :D (speedrun)
EDIT: 141.45 on 33-4. I'd love to see that route dark. Because I think this is one of the best and funniest levels from N :D
EDIT 2: 33-2 by 0.475, innovation again by dark ;)
Postby darkshadow » 2009.07.22 (21:13)
Nice runs xaaaaeeeelaaaar! ;)
As per request:
The ending should be quite clear.
Edit: This might be slightly faster on 20-3:
Postby xaelar » 2009.07.22 (23:24)
33-3 by 3 frames.
EDIT: Improved 33-4 to 141.675 using most of darks innovation. I think this ending is faster and easier dark :D
EDIT 2: 141.900 :D
Postby darkshadow » 2009.07.23 (02:29)
xaelar wrote:33-3 by 3 frames.
EDIT 2: 141.900 :D
Nicely done however while that method is easier it's actually significantly slower.
Edit: Make that maybe 8 frames slower. However I guess I showed how easy 142 is even with this method.
Edit 2: Congratz on 71400 total score xaelar.
