Sig Troubles
Postby Slayr » 2009.12.13 (17:27)
I've tried to add a few images to my sig, but each time it says: It was not possible to determine the dimensions of the image.
Can you tell me how to fix this?
Postby Spawn of Yanni » 2009.12.13 (17:40)
Can you tell us how exactly you tried to add the image? (what format did you use, etc.)
Postby Slayr » 2009.12.13 (21:02)
Step 1: I right click on the image and click properties.
Step 2: Highlight the URL, right click Copy
Step 3: Use then paste URL in between.
Postby Spawn of Yanni » 2009.12.13 (21:32)
Slayr wrote:Step 1: I right click on the image and click properties.
Step 1: You can just right click and select "copy image address" or something to that effect, but what you did should work anyway.
Step 3: Hm, what? Say your image is http://www.domain.com/image.jpg , you want to put
[img]http://www.domain.com/image.jpg[/img]
in your sig. Not .
Postby T3chno » 2009.12.13 (21:43)
Spawn of Yanni wrote:Step 3: Hm, what? Say your image is http://www.domain.com/image.jpg , you want to put
in your sig. Not .
No such image at the location. It redirects to domain.com.
Postby Slayr » 2009.12.17 (01:44)
i tried to add another image and the same thing happened.
Postby Spawn of Yanni » 2009.12.17 (01:59)
You're saying when you paste this exact code
[img]http://i857.photobucket.com/albums/ab134/north_ocean/condemned2.jpg[/img]
into your sig, it doesn't work?
Postby Slayr » 2009.12.18 (01:05)
yes
Postby Pheidippides » 2009.12.18 (01:40)
This is a real longshot, but are you over the character limit for signatures? You do have quite a few things in there already.
Edit: Eh, just eyeballing it, there's no way that's over 9999 characters. Back to the drawing board.
Postby Skyling » 2009.12.18 (02:43)
I'm pretty sure four signatures, thirteen little image bars, and an assorted shitload of shit is enough for one signature anyways.
Sonnet
NUMA Profile: http://nmaps.net/user/Kaylab
Postby Kaylab » 2010.01.19 (09:40)
I under stand how to add a sig to your comment, im just not sure where you got/made your sigs from
Postby Universezero » 2010.01.20 (10:20)
Kaylab wrote:I under stand how to add a sig to your comment, im just not sure where you got/made your sigs from
You request people to make them for you. I suggest you browse through here.
Users browsing this forum: Google [Bot] and 12 guests
