Local Storage [God help me]
Alive
Postby dadamonster » 2010.11.05 (20:49)
So I moved to Win7 platform and have my game totally busted.
The thing is my flash player cant save any local storage data, implying
-keys layout
-level progress
-anything else
when N starts its always CLEAN sa new:
in PLAY section only '00' ep is aviable
in SETTINGS section keys are NULL, not set to deafault as supposed to be.
Talking about FP setting, its same: LOCAL STORAGE is set to unlimited, saved, next time its NULL.
I really hope to hear something helpfull, please. If you need additional info about my configuration or anything go ahead.
In short: cant set movement keys, cant even take a step, nothing.
Raigan and the Horse-Woman
Postby sidke » 2010.11.05 (20:54)
have you tried running it as administrator or just disabling the uac altogether?
Alive
Postby dadamonster » 2010.11.05 (21:04)
Thnx for a fast reply, but sadly, I did tried "Run as dam.", as well as copatibility mode>XP. Got me nothing.
Postby sidke » 2010.11.05 (21:12)
C:/users/<user>/Application Data/Macromedia/Flash Player/#SharedObjects/<random characters>/localhost/
can you check in here if there's an n_v14b_userdata.sol, if so delete it and try then
if not, i'm stumped.
edit: you should probably back it up before deleting it. hopefully you haven't deleted it. .__.
Alive
Postby dadamonster » 2010.11.05 (21:32)
at
>%appdata%\Roaming\Macromedia\Flash Player\#SharedObjects\TUBD86EX
No such folder as LocalHost. I guess thats bad.
Postby sidke » 2010.11.05 (21:36)
yeah, kinda. i recommend downloading and trying to run nreality (http://n.infunity.com/) just to see if it works. i can't imagine why it would when yours doesn't, but maybe your binary's corrupt. i don't even remember if you need to install flash independently from windows, but if you do and it's still not working, try uninstalling and reinstalling it.
Alive
Postby dadamonster » 2010.11.05 (21:40)
I launched it on a virtual XP machine, obtained .sol at localhots at GUEST XP, moved it to localhost at HOME machine, result is null. Now, what is this Nreality project is all about in two words.
Postby sidke » 2010.11.05 (21:50)
i said binary (exe) not the data (sol). and you can always check the entire subforum devoted to nreality to find out...
Alive
Postby dadamonster » 2010.11.05 (21:57)
I tested NR and it works fine implying non-classic background color is a thing I have to live up with. it uses with Adobe FP v9 while n works with v7.
I guess I just downgrade to XP in this situation.
Users browsing this forum: Bing [Bot] and 5 guests
