stupid flash won't recognize any non english character. You probably have placed it on a path where it contains non standard english characters.
for an example, I experienced the same problem when I placed NReality on chinese windows xp desktop, because the full path is
"C:\Documents and Settings\Unreality\桌面"
where 桌面 caused the nreality failed.
So please try placing it at c:\
- Beyond a Perfect Math Score
No change in behavior.Unreality wrote:So please try placing it at c:\
I keep thinking it must be missing a file or something, like how v6d4 requires the column files, but then I remember it was working fine on the previous machine with just as few files. :(
- Commodus
login your N and everything will be fineRule wrote:The main menu demo's are corrupted in my flash, and it doesn't save highcores...
And getting NUMA maps in by numbers desn't work either.
But these things must have been noticed before.
- Commodus
Wow, I feel incredibly stupid now, thanks for the help on that. Now it works fine.Unreality wrote:login your N and everything will be fineRule wrote:The main menu demo's are corrupted in my flash, and it doesn't save highcores...
- Semimember
why is this world so cruel?
Just unpack the file. It'll work.sawyerscott52 wrote:i downloaded the file, and i opened it. it worked the first time, then i closed it. when i tried to open it again, it showed a grey screen! it still had the white words in the margins, but the rest was blank!
- MBTI Type: ESTP
* means you have ro have had a 0th on the level or episode when 10 other people (at least) have submitted runs also.Superpok wrote:what are the *s next to highscores? what are the requirements for you to be eligible to get one on a level and stuff?
It's just 9 other people, isn't it?kkstrong wrote:* means you have to have had a 0th on the level or episode when 10 other people (at least) have submitted runs also.Superpok wrote:what are the *s next to highscores? what are the requirements for you to be eligible to get one on a level and stuff?
It's actually 10, by the fact that th numbers actually starts at 1 and 0 has a no value.999_Springs wrote:It's just 9 other people, isn't it?kkstrong wrote:* means you have to have had a 0th on the level or episode when 10 other people (at least) have submitted runs also.Superpok wrote:what are the *s next to highscores? what are the requirements for you to be eligible to get one on a level and stuff?
Yeah, it's 9. Though, I think people should have something like ** or *+ when they have 19 people behind them on the next version of NReality.
- Bacardi
- NUMA Profile: http://nmaps.net/jinxed_07
Me too, but i never had that problem last year when i had Nreality... oddRule wrote:Wow, I feel incredibly stupid now, thanks for the help on that. Now it works fine.Unreality wrote:login your N and everything will be fineRule wrote:The main menu demo's are corrupted in my flash, and it doesn't save highcores...
I sent Nreality to a few of my friends in one of my classes and now we are racing through the coloums..
I was looking through my scores on your infunity page, and noticed that my ep 30 score was marked as non-legit. I looked in NReality and saw that I had to retrieve that score from the tables for some reason, and it is labeled as v0 in my highscores. I know that I used v6d4 to make that run, since I did it this fall, and that's all I've used this year to play with. Could you change my score to being legit in your database?
fixed. The run in database does say it is v6d4golfkid wrote:Unreality,
- MBTI Type: ESFP
- Member
- NUMA Profile: http://nmaps.net/user/n0_ma11y
Other than the highscores not loading, nothing seems wrong there. What usually loaded on your pc thats different from that pic?n0_ma11y wrote:This allways shows up, on my pc it would load idk man btw Great program, check out some of my maps ;)
Is n.infunity.com blocked on your computer?n0_ma11y wrote:This allways shows up, on my pc it would load idk man btw Great program, check out some of my maps ;)
login and you will able to see the highscoresn0_ma11y wrote:This allways shows up, on my pc it would load idk man btw Great program, check out some of my maps ;)
- Semimember
Sorry, I know if I read this thread I would know, it's just a bit wordy for me. What I did gander upon and absorb was that it has more levels. Does it have new bots? What else is new with it? Thanks! :D
- MBTI Type: ESFP
It's basically a mod of N. Lets you do more things, and highscores have better anti-cheat protection.Gregis wrote:So what is NReality? Like a mod for N?
