- NUMA hover profile in the forum isn't working well.
- The main site is still titled "TheRealN".
- Typecocks isn't working well, sends data to therealn.com.
- None of the links at the main site is working.
- Filmroll.droni.es redirects to the therealn.com domain.
- Sotx has "Back to The Real N" button.
Ninjarobotyeti.com
I asked on IRC and Lenny or someone said, I think, that LV had to change all those links. Which is true about everything around here.
- Intel 80486
While we're listing problems, the new site doesn't keep me logged in. I've already voiced this in the moderator discussion forum, but this way we can see if anyone else is having this problem.
Have you tried either of the suggestions I've given in that thread?
There's a lot to be changed, yes. But if the links are changed here then they won't work on EasterViking, I believe. So we'll probably wait until after the new year - it'll just be a matter of time. But the essential things are all working.
Actually, ninjarobotyeti is the first domain that actually logs me in automatically.epigone wrote:While we're listing problems, the new site doesn't keep me logged in. I've already voiced this in the moderator discussion forum, but this way we can see if anyone else is having this problem.
It never worked for me, not even on the old old forums.
It's gotta be some issue at your end. Try refreshing various internetthings is all I can suggest.epigone wrote:While we're listing problems, the new site doesn't keep me logged in. I've already voiced this in the moderator discussion forum, but this way we can see if anyone else is having this problem.
EasterViking is just a backup host for everything, it won't be a big deal if it stops working now that we have this primary domain.Lenny wrote:There's a lot to be changed, yes. But if the links are changed here then they won't work on EasterViking, I believe. So we'll probably wait until after the new year - it'll just be a matter of time. But the essential things are all working.
Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
I assume so.Wight wrote:Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
Give some TRN link.Wight wrote:Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
Not necessarily. If you make it too specific, it might not catch everything; yet if it is not specific enough (like just looking for "TheRealN") then it will catch too much. It's best to check every search result and make sure you want to change it first, and that's horribly time-consuming - though not necessarily what will happen.Wight wrote:Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
No...no. http://forum.therealn.com/(wildcard) will match only URLs, just like http://forum.easterviking.com/(wildcard). It's a matter of simple regex.Lenny wrote:Not necessarily. If you make it too specific, it might not catch everything; yet if it is not specific enough (like just looking for "TheRealN") then it will catch too much. It's best to check every search result and make sure you want to change it first, and that's horribly time-consuming - though not necessarily what will happen.Wight wrote:Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
Can you repost them here?SlappyMcGee wrote:Have you tried either of the suggestions I've given in that thread?
Haha, I've just noticed that forums.droni.es works, too!
That would explain why I couldn't stay signed in. I was using forums.droni.es, not forum.droni.es.EdoI wrote:Haha, I've just noticed that forums.droni.es works, too!
