im stuck on episode 9..-_-
For 9-1 it's possible to get the blue switch without setting off the trapdoors. Try just touching the corner - practice makes perfect, you shouldn't need a diagram here.
There is a trick with the one-ways.
Same trick with one-ways, you should press the jump key just a frame before you hit the one-way, so you can jump through it without losing speed.
What you need to do is hold right, jump, and when you hit the one way jump again. (you're holding right in all of these steps) and you should be able to get through the one way.
You should do this fast, it's very easy to do once you got it, and it's a very helpfull and a basic trick in N.
- Demon Fisherman
When you're done with that...Teeman92 wrote:i finally beat the 1st column, my god it was hard. just imagine if i played the 100s O_O
Happy birthday.
- Radio Douchebag
I don't think many people have beat all 500 levels.Kablizzy wrote:When you're done with that...Teeman92 wrote:i finally beat the 1st column, my god it was hard. just imagine if i played the 100s O_O
Happy birthday.
Well, unless you've beaten nreality.
Once again, not many people.
I'm working on beating it backwards.
I'm almost done with the 80s column.
This is how I personally beat 9-0. you get rid of the rocket & the gauss is still aiming right when you have to do the one-way glitch. Then you can get a bunch of gold AND have an easier time getting down to the bottom without a fall death.
Here you can hit the exit trigger without getting the trap door triggers. It requires precise jumping, but it is possible. It makes the level very easy... just go in from the left and out the right.
Last one Ill bother to do. idk why im even still doing this:
Double wall jump to the exit door, then single wall jump to the blue #1. the zap drone comes down and turns right. Play jump rope with the rocket until he seeker drone reaches blue #2. Then destroy the rocket (important) and jump to the upper right entrance. Run all the way left, the gauss should cause little trouble if done right. Get the switch by wall sliding, then go up and exit, taking the launchpad to the bouncy & then to the finish.
what levels in ep 18?
Follow the blue line right first. At red circle #1, pause briefly to allow the laser to start heading down (2 seconds about). Rest is fairly easy.
Follow the blue line again. the yellow strips are the drone paths that you have to watch out for. The drones are unpredictable though, so keep a general eye out for them. The best way to dodge them is make them sense you from a distance, so they speed across to the other side of the map.
- MBTI Type: ESFP
You mean all of the original 500? I'm pretty sure quite a lot of people have.Rhekatou wrote:I don't think many people have beat all 500 levels.
The NReality levels are pretty easy too, apart from blue_tetris' episodes (100-119).
Teeman92, I suggest playing the 60 column first.
- Radio Douchebag
I meant all 500 legacy.amomentlikethis wrote:You mean all of the original 500? I'm pretty sure quite a lot of people have.Rhekatou wrote:I don't think many people have beat all 500 levels.
