CollabX: a site to make large-scale N collaborations easier.
Example input:
Password: ninjarobotyeti
Collab ID: 93e78baafd
Example input:
Map data (only use this to look at the demo):
It doesn't work, and it shouldn't work either. User IDs are collab-specific.Scrivener wrote:check out collab id f04d1156ff
i guess use the same public user id that's in the first post?
Submitting only a tileset, with no objects yields a rather ungainly error.Warning: Invalid argument supplied for foreach() in /home/fraxtil/public_html/altarc.xtil.net/collabx/mapimage/levelthumb.php on line 223
Your collab ID is 6b8844a9d4 and your own user ID is 70a159df84. Store these for future reference.
00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000GK0000000000000000000GK1100000000000000000GK1111000000000000000GK1111110000000000000000000B1110000000000000000000>11100000000000000000000B1100000000000000000000>1100000000000000000000003000000000000000000000310000000000000000000031100000000000000000003111000000000000000000000B1000000000000000000000>10000000000000000000000B0000000000000000000000>000000000000000000000GK0000000000000000000GK110000000000000000000B1110000000000000000000>11100000000000000000000B1100000000000000000000>110000000000000000000FJ11000000000000000000000FJ000000000000000000000000000000000000000000000000000000000000000000000|
00000000000000000http://altarc.xtil.net/collabx/image/6b8844a9d4-0.png000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000GK0000000000000000000GK1100000000000000000GK1111000000000000000GK1111110000000000000000000B1110000000000000000000>11100000000000000000000B1100000000000000000000>1100000000000000000000003000000000000000000000310000000000000000000031100000000000000000003111000000000000000000000B1000000000000000000000>10000000000000000000000B0000000000000000000000>000000000000000000000GK0000000000000000000GK110000000000000000000B1110000000000000000000>11100000000000000000000B1100000000000000000000>110000000000000000000FJ11000000000000000000000FJ000000000000000000000000000000000000000000000000000000000000000000000|
Ah, that's a problem with Arachnid's old thumbnail generator. I should probably fix that, seeing as it affects AltArc as well... (Edit: fixed; future tilesets without object data will not screw up)squibbles wrote:Submitting only a tileset, with no objects yields a rather ungainly error.Warning: Invalid argument supplied for foreach() in /home/fraxtil/public_html/altarc.xtil.net/collabx/mapimage/levelthumb.php on line 223
Sorry, the creator of the software is not responsible for lost or damaged items. (In all seriousness though, sorry about that- there's no way for me to get it back now that I've erased the old files.)Scrivener wrote:edit: also, i hate you, because I didn't save the data for that collab I started and I was gonna finish it D:
