NReality Suggestions Thread
Postby Zer0 » 2010.02.13 (07:50)
-Ninja Guard Drone
A bit of a blocker when you get attacked. If it is 10 or less blocks from you, I will run in front of you if something bad is about to happen. Such as rockets, guass, lasers, bullets, floor guards, and chasing drones. This will not work for, falling, mines, thwumps in any way, or any glitched kills, like getting crunched by a door or something. It has a not very fast movement, because I dont want to just plain kill the challenge.
-Rocket drone
This drone can fire rockets. Not like the kinds from the other rocket launcher, but these go straight. The drone can be hurt by other attacks, even if it is on close range with its own rocket. It has health, so if it gets hit too much, BOOM. Here is how much damage it takes from objects:
Mine: Rockets can blow it up, -60
Self Rocket: -65
Homing Rocket: -80
Thwump: -100
Floor Guard: -20
Zap Drone: -45
Laser Drone: -75
Chaingun Drone: -15 Per bullet
Guass Turret: -65
MBTI Type: ESTP
Postby kkstrong » 2010.03.05 (15:29)
Why not just have iTunes playing?
The thwump switch is interesting.
Postby Tunco » 2010.03.05 (17:05)
I don't know it this has been recommended before, if it is, sorry. Anyway, this just popped right in my mind earlier today, though I thought I would post it here.
-90*/180*/180* (degree) Map Turn Switches
-or whatever. You know, in some flash games, you just hit a button with your little tiny man and screen suddenly turns 90* (degree) and then there is a new level / puzzle? Got it? No? Example.
So, suppose you maintain that function into N, when you hit a special lock or switch or whatever it is, the screen turns 90* / 180* or any angle you would want.
I know it sounds kinda complicated, but it would make a whole new type of levels and new puzzle levels. ^_^
