running from the terminal has this output
i looked around the forums and found that i needed to install libgtk1.2, but when i try to do that i get~/Downloads/n_v1linux$ ./n_v14
./n_v14: error while loading shared libraries: libgtk-1.2.so.0: cannot open shared object file: No such file or directory
so now what do i do? thanks for any help.sudo aptitude install libgtk1.2
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reading extended state information
Initializing package states... Done
No candidate version found for libgtk1.2
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B of archives. After unpacking 0B will be used.
Writing extended state information... Done
