do you play your NUMA levels in debug or userlevels
Moderators: Rose, Sunset
which?
debug
24
65%
userlevels
13
35%
Total votes: 37
Postby Radium » 2010.05.24 (02:25)
i play in debug for convenience
NUMA Profile: http://nmaps.net/user/mahi_mahi
Postby Mustardude » 2010.05.24 (02:27)
Nreality userlevels is my preference, mainly because you can easily submit your highscores.
Check out the pack thread, click the picture above
wordblamcreator wrote:mahi_mahi has the french flag up! He must be surrendering...
mahi_mahi wrote:It's the Russian flag.
Postby otters~1 » 2010.05.24 (02:36)
Debug. Never use Nreality, so I have no reason to be in userlevels.
I play packs in userlevels.
Postby Scrivener » 2010.05.24 (02:43)
debug, unless i'm in nreality for some reason, like if i was going to be playing some nreality maps anyway. i generally don't map in nreality, because i have a tendency to get a blank flash player with "your flash player may have been running with an abnormally speed" displaying where my beautiful map used to be.
Postby Rose » 2010.05.24 (02:45)
I play my NUMA levels in my userlevels, since they are there along with all the countless maps I haven't submitted.
I play NUMA levels on NReality because of the highscore submission system and the fact that you only have to press {spacebar} instead of ~ R tab tab 1 P with caps lock on.
For anything else, though, I use N. userlevels for packs, and obviously debug for mapping :p I never map in NReality. Too many horror stories about Flash crashing, which has never happened to me in N.
Postby Nexx » 2010.05.24 (05:46)
NReality userlevels.
Postby Seneschal » 2010.05.24 (09:00)
Nreality userlevels. Much less hassle, plus it has an inbuilt highscoring system :)
Postby origami_alligator » 2010.05.24 (10:36)
debug is original and nostalgic.
Postby rocket_thumped » 2010.05.24 (11:26)
debug of course.
Postby toasters » 2010.05.24 (12:23)
Debug. Packs of course go into userleves.
Eleven Squared
NUMA Profile: http://nmaps.net/user/nevershine
Postby nevershine » 2010.05.24 (16:48)
debug mode. Sometimes I tend to put all my favourites in my .txt file or something like that. Packs go into userlevels as well.
<~blue_tetris> First off, making a game and calling it the sequel to Tetris is like making "Butter 2: Revenge of Butter".
<~blue_tetris> And it's actually margarine.
Postby heatwave » 2010.05.24 (18:19)
Radium wrote:i play in debug for convenience
I play in userlevels for convenience. o_O
Postby Pheidippides » 2010.05.24 (21:30)
I agree with heatwave that Userlevels is more convenient, but only in the long run - say, if you're looking to make a fast demo. There's no denying that pressing the Spacebar between plays is way easier than ~ + R + 1 + CapsLk + P + CapsLk, no matter how good you are at the latter.
And yet, I use debug (even when recording demos) because it makes loading the level faster. In my defense, this is because I don't often see myself trying to make a fast demo.
Postby Radium » 2010.05.24 (23:35)
hmm.. i just feel more natural in debug.
i'm a mapper, not a xaelar. NED is my home<3
Postby 29403 » 2010.05.24 (23:41)
I used debug mode.
Postby Tunco » 2010.05.25 (18:18)
debug more just because it takes more than a minute (or less) to play my map in userlevels.
Intel 80486
Postby epigone » 2010.05.26 (15:20)
Always in debug. It's great especially since I suck and I can just respawn after I die without having to start over.
The Best of Epigone
Postby Kablizzy » 2010.05.26 (21:29)
I play my jazz in Ned.
Postby Pikman » 2010.05.26 (22:25)
\ ctrl a ctrl v l capslock 1 p
(Debug, for the advantage of being available in both N and NReality.)
NUMA Profile: http://nmaps.net/user/furry_ant
Postby maya » 2010.06.03 (14:12)
I play all my maps in debug; so much easier. Plus, I've got use to Home + \ + r + p.
I play NUMA maps and mappacks in nreality userlevels though.
Postby koipen » 2010.06.11 (18:50)
Userlevels.
Way easier, and I can return to maps whenever I want. I generally don't want to download maps which are done after single run. Exceptions are really good races. I even test my levels in userllevels, the hassle to retry the level is too big to me. Especially considering the types of maps I like to play.
Postby Rose » 2010.06.12 (22:26)
koipen wrote:Userlevels.
So you make the whole map before ever playtesting it? o_O
I do another playtest for nearly every object or tile I add or subtract.
Postby koipen » 2010.06.12 (22:50)
MAXXXON wrote: So you make the whole map before ever playtesting it? o_O
I usually build the map, playtest, then edit and repeat this cycle until I'm satisfied. DDAs are exception.
Postby Kablizzy » 2010.06.13 (01:46)
MAXXXON wrote:So you make the whole map before ever playtesting it? o_O
Most of my casual mapping is done this way. I still make them in debug, but I almost never have to playtest maps.
Same thing with maps on NUMA. I don't actually *play* maps anymore - I just look at them and see how they would play and rate them accordingly.
Postby Donfuy » 2010.06.13 (02:56)
Play NUMA levels on NReality, since I just have to put the number and voilá
Play mappacks in userlevels, obviously. One n_v14/Nreality folder per mappack (being nreality or n_v14 is random)
