Theories to Create Popular Map Packs
Many users of N and NUMA make map packs. A series of maps usually in the same family. Making a popular map pack can be very difficult. And hopefully this text will give you some insight on how to do it.
You may have browsed NUMA and found a few map packs. I myself have developed two map packs. Many authors may see this as a way to get other users playing their levels to want to play the rest of the maps in the pack. Many of the map packs you will see are created by popular authors who have probably made many friends. That maybe another technique.
A simple way of doing this is starting of with the tileset. Make something with a simple tileset stlye that you should try and maintain in the pack.
Always playtest your levels and make sure they are enjoyable. Keep every map in the pack the same type of style though having a different objective which can be reached in a different way. There must be something that binds all the levels together, maybe a particular type. Or a common mod. Don't be afraid to be adventurous with the maps in the pack but they should all hae something in common.
You may have realised specific types of maps are more popular than usual or than others when in maps packs. I am sure the following maybe of some help to you when you choose what type of map pack you want to create:
Tilesets (Maybe accompanied by a playable version)
NReality Levels
Minimaps
Races (See Riobe's Races)
A few packs you may want to see:
Chao Star's Minimaps
http://nmaps.net/138146
Riobe's Races
http://nmaps.net/138238
BE_nSPIRED Tilesets
http://nmaps.net/140268
Make sure you have open spaces in your maps for the player to breathe and always make sure the first map of a map pack is the best you can give. First impressions are very important
If you have tried starting a map pack tand have not seen much success then speak up on this topic. I'm sure I, or someone else browsing this forum can help you.
If you want me to check out your new (or old) map packs and want me too give you some advice then just say so. I'll probably check out your pack directly on NUMA on my second account (Brendan123). So don't be shy and add a link to your map packs!!
Good Luck!
RAN - rikaninja - Brendan123
Thanks Hope to Hear From You
- Wizard Dentist
Rikaninja wrote:Make something with a simple tileset stlye that you should try and maintain in the pack.
I disagree with both of the above. :/ This strategy is only useful if you are setting out to make a really boring pack.Rikaninja wrote:Keep every map in the pack the same type of style but if possible add something new into every level.
Perhaps in a small pack it would be okay for the style to be somewhat continuous, but the larger the pack is, the better it would be to have maps that vary in complexity and style.
Nice idea for a thread though. :)
- Ego Lancer
- NUMA Profile: http://nmaps.net/user/fingersonthefrets
but nice idea for a thread. a major key pointer i think is that easy maps need atmosphere, so if you're doing an episodic pack, yeah, make sure the easy maps have one.
I see your point/s, I'll edit that. I now realise that I may have to do a bit more editing than that.
- Wizard Dentist
Rikaninja wrote:There must be something that binds all the levels together, maybe a particular type. Or a common mod. Don't be afraid to be adventurous with the maps in the pack but they should all hae something in common.
No no no no no. A map pack is a collection of maps. Simple as that.Rikaninka wrote:I know what you mean George. But if the levels are completely different and have really nothing to do with each other I don't see why they should be called a map series or pack. So I can't agree with that. :|
For example, a "Best of Superauthor2000" is a map pack, even though the only connection between the maps is that they were made by the same author.
Also, I think you should talk abit about action maps. I've heard they used to be quite popular :/
For the examples, maybe you could have linked to the packs instead of to individual levels from the pack?
- Mr. Glass
Especially:
The first map doesn't need to be the best you can give, every single map in the pack does. A map pack should be play-tested to death so that every single level is absolutely the best thing you can produce, otherwise what's the point?
Also, a theme that runs throughout a mappack would be very difficult to produce without the entire thing becoming stale. the maps should certainly NOT all share a common idea. What you're looking for instead is a dynamic between the maps and then the episodes themselves. Make sure that dynamic forms into a suitable and enjoyable difficulty curve. This is something that absolutely cannot be taught and it's what separates the better packs from the average.
The packs you've listed as examples aren't the best, call that subjective if you really want, but there are authors out there who've produced much better overall packs - imo - that would benefit new authors a lot more.
*Copies and pastes atob's post again*Rikaninja wrote:I know what you mean George. But if the levels are completely different and have really nothing to do with each other I don't see why they should be called a map series or pack. So I can't agree with that. :|
I couldn't have said it much better. There are different types of map packs. Some of them are sporadic, others may be episodic. If you were referring to make episodic packs (like what Mare and Raigan have done), you would want to have plenty of variety, as well as similarities throughout. If the Metanet levels are to be taken as a standard, you'll see that the difficulty curve is gradually stepped up, and map with similar themes appear quite sparsely.
What's most important is that each level flows into the next. There isn't much you can do to define a 'popular' or 'good' map pack, and you could easily get into the whole subjective argument again.
- Ego Lancer
yeah, series ≠ mappackRikaninja wrote:I know what you mean George. But if the levels are completely different and have really nothing to do with each other I don't see why they should be called a map series or pack. So I can't agree with that. :|
don't get them confused.
whenever I make a mappack I usually think up a cool theme or a cool word and then blow it up with virtual dynamite. All my mappacks have been episodic but they haven't followed each other (like the new epic) with similar tilesets and stuff.
Also, I tired of these guide threads. Some of them are helpful for noobs and all that. But this is pretty much a list of do's and dont's, entirely written in your own convoluted opinion, about what YOUR perfect mappack would be like. If thats what you want, make it yourself.
Maps should be a symbol of self expression, as should mappacks. If we all followed the same guidelines then we might as well be in school writing essay by a rubric.
thumbs down.
This is very true. Every author should read it. Don't let anyone say that there's only one way to make a good map, because there's a trillion and a half.handofgod wrote:Maps should be a symbol of self expression, as should mappacks.
- Mr. Glass
A map pack should follow a 'theme' or perhaps a 'concept', but 'same ground' can't be much more than repetitive.BionicCryonic wrote:I honestly think a 'map pack' should follow same ground. A 'level set' can just be some good levels thrown together. My opinions, not provable. Criticize as you want, but uh, whatever.
If this is a case of semantics, then ignore me.
- Wizard Dentist
I reckon even that's going too far. I love variety! :)atob wrote:A map pack should follow a 'theme' or perhaps a 'concept'
it's like asking why a musician arranges his tracks in a certain order. He just...does it.
edit: is my title custom or what? if so, who did it?
- Wizard Dentist
YES, qfe :Ppalemoon wrote:It seems to me you can sum up basically all map packs with the words "a collection of maps the author chose to put together, for whatever reason."
