??? weird problem
Postby ENT474 » 2010.06.12 (13:18)
What's up with this map - fine in debug, but in userlevels it looks corrupted. Also problems with oneways. ??? HELP
Note: Originally when I made the map (like 3 years ago, stored away) it had like 208 characters in the tiles. (the NaN is supposed to be there).
Postby Seneschal » 2010.06.12 (15:04)
Could you clarify what the problem is exactly, I don't really understand what you mean by "completely weird", although I can see that your tiles are messed up.
EDIT: A closer look has revealed two problems:
First, you have too many characters for the tiles in your data. Second, you have a NaN in your data, which might be causing you problems; try using this data:
Hopefully this is closer to your original data (not sure about the objects, though):
