Your Flash player Might be running with an abnormel speed!
I was making a Race map in N-reality when all of the sudden a red text flashed (text: Your Flash player Might be running with an abnormel speed!)
What the hell!
what happend, I just lost my racemap!!! it was pefect! OMG! why!
lawl ofcourse I was too fast in my race map llol.
how can I fix this or remove this?
This fact alone has made me start using N 1.4 more often nowadays. There are solutions I can think of though:George wrote:I don't think much can be done about it. It's just one of those random bugs that N Reality gets. I've had the unfortunate mishap of running into that as well, so all you can do is regularly save your data.
1) Save your data regularly. Sometimes, the player just crashes randomly, so this is a good solution.
2) This may not apply to everybody, but I notice that the longer the player is open, the more likely it is to crash all of a sudden. If NReality has been open for hours, and it hasn't crashed yet, close that one, and re-open it, then start your level again.
3) Start using Nv1.4c much more often when making non-Nreality levels if you'd like to completely avoid this problem. The normal N doesn't crash due to the flash player, and if it does crash, it's not the flash player that caused it.
4) This may also not apply to everybody, but keep as much things closed as you can. With my computer, the more things I have open, the more NReality laggs, and the rate at which it crashes increases.
Well, thats my four cents.
When Nreality does start lagging though, it means you are likely heading for that "abnormal speed". It's only ever happened to me once, and I wasn't annoyed, because I had a load of save files each with a different step.
Normally, it helps if you do it in steps. Make a part, save it, then restart Nreality.
If the problem persists, PM unreality or start using Nv1.4.
