Favorite Authors Plugin for Nmaps.net
- Legacy Elite
- MBTI Type: ESTJ
However, I may have just set it up wrong; after all, I followed the most half-arsed set of instructions for adblock installation via Vista, and I'm on XP.
It sounds like the same set of problems posed by older FF, so maybe if you fix that up, it will work on Chrome!
EDIT: Greasemonkeyed up my FF, amazing!
- Raigan and the Horse-Woman
There's now a link next to your unread comments notification that gives you its own notification with you have favorited authors with new maps: "X fav. updates" (Done so because there is such a limited space up there, it's not possible to put "X favorited authors with new maps" without pushing 'Log Out' off the side.)
It only updates once every five minutes, because requesting from the server for each author each time you click a link is way too much for the server. Once you click the link (either of the links) to the favorite authors, it clears the number of fav. updates. Removing an author, and then adding him again will cause him to be shown up as 'new'.
Known problem: AMomentLikeThis does not show up in your favorites authors because he doesn't even show up in the normal listing.(http://www.nmaps.net/browse?q=author:amomentlikethis)
ETA: If you didn't hear it enough already... If you find /any/ bugs, please tell me about them.
Second, when I click on Favourite Authors, it says "NO Favorite Authors" and then loads up the list. Also, after adding some, it has two loading lists.
D:
Sounds like you have two instances of the script running. If you don't know which is the newer one, remove both and install again.MattKestrel wrote:Also, after adding some, it has two loading lists.
And for the names, I did my best to accommodate for ones of varying length. Yours is just too long, sorry ;__;
Yeah, that fixed things. Thanks!sidke wrote:Sounds like you have two instances of the script running. If you don't know which is the newer one, remove both and install again.
Fixed from saying "1 fav. updates" and "2 fav. updatess".
Now says "1 fav. update" and "2 fav. updates".
Sorry.
Rewrote some code, and adjusted some workings... One version works on both Firefox, and now Opera!
Plugin now works on Opera
http://www.opera.com/browser/tutorials/userjs/using/
I haven't done vigorous testing on Opera, there's a problem on mine that requires me to refresh the page after clicking a new link (not related to the plug-in, it's happening everywhere), so if there are any bugs, please tell me about them. Haven't tested on Chrome, but since I'm not using Greasemonkey's functions anymore, it should work. If it works on Chrome, please say so here! :D
Because of the different way of storing data, you may want to 'clear favorited authors' before installing the new version. Regardless of if you do, you will have to redo your favorited authors, except this way you clean up GM's values.
- Phei Phei Pho Phum
It should still work! I just haven't tested it on any earlier versions. D:Pheidippides wrote:D'oh! I had to downgrade Firefox to 3.0.13 to fix some issues I was having. Bye bye, awesome plugin. ;_;
Oh, I thought you said it wouldn't work. I'll have to try it out!sidke wrote:It should still work! I just haven't tested it on any earlier versions. D:Pheidippides wrote:D'oh! I had to downgrade Firefox to 3.0.13 to fix some issues I was having. Bye bye, awesome plugin. ;_;
Edit: Confirmed for Firefox 3.0.13!
Chrome fails to set a margin value with javascript, so no fav updates. You can comment out a couple of the lines that make the top part not push 'Log Out' off the side, and it should work. (PM me for which lines, if you plan on doing this.) Enabling scripts on Chrome is a pain in the balls to do, but you can always use its creator's search engine to find out.
Toggles still show, and you can still visit your favorite authors page.
A cool thing about Chrome is that it conforms to Aero, but I already got Firefox to do that...
Ahahahahha. No one's given me a good reason for this one yet. I'll take my entirely integrated browser and run with it, thank-you-very much. Enjoy your extremely minimalistic nothing-browser.Superpok wrote:very fancy. and no, chrome does not support plug-ins yet, but it is much better than FF
You use IE? Use something else other than that, other than that.bobaga_fett wrote:great! now you just have to make the plugin for IE!
You should have make it more known, I found out now for the first time.sidke wrote:Plugin now works on Opera
Anyway, I've downloaded this, but it's not working. At all.
EdoI wrote:Anyway, I've downloaded this, but it's not working. At all.
Stuff you should read wrote:To enable user JavaScript, use Tools > Preferences > Advanced > Content > JavaScript options, and select the directory where you will put your User JavaScript files. Opera will load all files in the specified directory whose names end with .js and will use them as User JavaScript files.
I wouldn't say that it's not working if I didn't do what I should. Have you tested it on Opera 10?sidke wrote:EdoI wrote:Anyway, I've downloaded this, but it's not working. At all.Stuff you should read wrote:To enable user JavaScript, use Tools > Preferences > Advanced > Content > JavaScript options, and select the directory where you will put your User JavaScript files. Opera will load all files in the specified directory whose names end with .js and will use them as User JavaScript files.
Just don't use it then, or find out if 9's userscript method is even applicable for the new one.
yeah, not gonna happen. I can't convince my parents, who I share this computer with, to use a different browser.Tunco123 wrote:You use IE? Use something else other than that, other than that.bobaga_fett wrote:great! now you just have to make the plugin for IE!
Out of the umpteen people I've told to change from IE, all of them (except maybe yungerkid... I think he still uses IE) have agreed that they were seriously missing out on the awesomeness the nets can be until they switched (be it to Firefox or... Chrome D:).
If you tell your parents that their risk for getting a virus greatly reduces when they download and use Firefox they might change their tune. It's worked for me!bobaga_fett wrote:yeah, not gonna happen. I can't convince my parents, who I share this computer with, to use a different browser.Tunco123 wrote:You use IE? Use something else other than that, other than that.bobaga_fett wrote:great! now you just have to make the plugin for IE!
or was it necromancy
necroposting...
in any case, old thread update!
ironically i switched to chrome. i had a patched up version for myself i've been using, but didn't post, so now it's up.
i've added a small feature to list your favorite authors on your profile page for easy access.
this now works flawlessly in chrome for you fellow chrome converts.
update!
The latest build of chrome crashes tabs for me constantly. I'm thinking about switching back to the fox.maki wrote:necrophilia!
necroposting...
update!
:( are you using the normal release or the beta? and if one or either, try the other.SlappyMcGee wrote:The latest build of chrome crashes tabs for me constantly. I'm thinking about switching back to the fox.
a fox is fine too...
i just went for chrome because ff was hogging my precious rams.
another update as well for the 3 people that use http://www.nmaps.net/userlevels
http://www.nmaps.net/userlevels?q=$favorite_authors
- RoboBarber
pretty please!
