Where do I report NReality bugs?
BUG:
- When I replace the image for gold, the image dont disappear when I take the gold.
This is tested with diffrent types of images.
Can we expect a fix for this?
Bug Report?
Can you be more specefic instead of just writing one damn word?
I haven't been following the development of Nreality but I'm pretty sure the creator, Unreality, hasn't been active in quite a while and doesn't look like he's going to update the program again, at least not any time soon.
No no no, I'm sure this has been fixed before. What I expect to work would be to have the background not have gold icons on it, and the forrground to have icons. That way, when the ninja collects the gold, NReality will show the gold-less background.
Hey fuckface, acquaint yourself with the forum rules.ENT474 wrote:No.
Stupid one-word responses won't do you any favors, especially when you give new members a bad first impression of our community.
Modmaster 1.4 -> Images -> IconsUniversezero wrote:Do you mean an image map, or a custom icon?NPLUS wrote:When I replace the image for gold, the image dont disappear when I take the gold.
Speaking about bugs, it should be possible to load images directly from the PC, so the images would get loaded immediately, or having the screen black until everything is loaded so maps like: http://www.nmaps.net/177637 wont be spoiled.
Also, have Unreality completely left or will be be back?
I don't think he's left completely, but he's been pretty inactive the last few months.NPLUS wrote: Also, have Unreality completely left or will be be back?
I am not really following here. Modmaster is not causing the custom gold problem. ModMaster dont make its own code, it just use the NReality code.Universezero wrote:There's your problem. Don't use Modmaster; it screws things up. No offence, kk.
If I write this code by myself or let mod master create it fast is absolutely no diffrence at all:
3,_icon,-10^-10^www.test.com/test.png
Another bug. Its not a major bug but it would be nice to see these get fixedUniversezero wrote:Hmmm... I've done a little bit of experimenting, and it seems that if you set drone pathing on a piece of gold that also a custom icon, then the icon will not follow the piece of gold around. This is most peculiar... I'll see if I can find a remedy to this.
Another bug report(still hoping for fixes): Thwump go/fall thru tile created by tile drone.
More bugs:
- If a alarm drone have custom pathing set, it loses its hitbox(it no longer can kill N)
- If custom pathing is applied to a drone(using the R L D U method), and it is "told to go to negative coordinates, the drone will just go away ignoring its path code
Users browsing this forum: No registered users and 38 guests
