N in a USB?
These Go Up to 11
Postby BBBB » 2010.09.05 (21:54)
so i want to put N in a USB along with my .sol file and actually play it on the USB is that possible? and if so how can you do it?
Postby golf » 2010.09.05 (22:23)
You can do it, I've done it many times before. The only thing is that you will have to transfer your .sol to the proper location on the main drive of the computer that you are playing on before you start (you may have to do a quick suicide on a level to create a .sol in the proper location to replace first, though), and make sure that you retrieve the .sol when you're done so you don't lose any progress you made.
These Go Up to 11
Postby BBBB » 2010.09.06 (00:42)
can you install adobe flash player on your usb? and set local on your usb?
Postby golf » 2010.09.06 (00:54)
That I don't know enough to answer, sorry. But I think that N looks for the .sol only in the C drive. I got a new computer with my old hard drive as a slave drive, still with the old .sol on it, and N didn't recognize the .sol. So maybe there's a way to set the flash drive as the C drive (or local, I'm assuming thats what that is), but if so I have no clue how to do so.
Postby Universezero » 2010.09.06 (05:27)
You could run Linux or something off your pen drive. That way all the data for the programs, .sol, etc. can reside there. (At least I think, anyway. :\ )
http://www.pendrivelinux.com/
EDIT: Also, it means you could play N on someone else's computer, even if it's locked and you don't know the password. :D
These Go Up to 11
Postby BBBB » 2010.09.06 (20:52)
Can you plug it in any computer and have it work?
Postby Universezero » 2010.09.06 (20:59)
BBBB wrote:Can you plug it in any computer and have it work?
The OS? Yes.
