RAM Detection
Postby Tanner » 2010.11.02 (20:11)
Hey dudeskis.
I don't know if anyone will be able to help me with this but I figured I'd ask. My desktop computer is only detecting half of the RAM installed in it. Turns out it's been like this since I bought it second hand from a friend and I just hadn't noticed. The RAM is installed correctly, the computer detects both of them (there are two sticks), but they are labeled as 1024MB sticks and the computer sees both as 512MB. I've tested them for problems using a variety of tools off the UBCD and they seem to be perfectly healthy. Does anyone have any suggestions? Is it possible that they're just mislabeled? It would be far too late to return them if they are.
Edit: I can get any other information you might need to help me here. Just ask.
Postby smartalco » 2010.11.02 (20:30)
That... is really weird. I can't think of any good explanation for that happening other than them being mislabeled...
Postby Vyacheslav » 2010.11.02 (21:09)
Motherboard?
Postby heatwave » 2010.11.02 (21:28)
oeuvre wrote:Motherboard?
That's the first thing my mind went to.
Postby Tanner » 2010.11.02 (23:58)
It's a Machspeed mk8-939a. The ram is Ultra 333MHz DDR 1024MB, one stick in DIMM 1 and one stick in DIMM 3, just as it should be.
Postby Vyacheslav » 2010.11.03 (00:04)
What happens if you put it in DIMMs 2 and 4?
Postby SlappyMcGee » 2010.11.03 (00:08)
Maybe this is just me... what is the difference they are referring to in the manual between 64 and 128 bit? Because 128 bit is used with the first two slots, as opposed to the first and third, as in 64 bit. Just a thought.
Postby Tanner » 2010.11.03 (01:03)
oeuvre wrote:What happens if you put it in DIMMs 2 and 4?
It's not meant to be used in those slots. Like Slaps pointed out, it's 64-bit ram which, according to the motherboard manual, should be placed in the first and third slots when using two sticks.
Question though, I was looking back through the mobo manual and it explicitly says that it supports dual channel ram. The stuff I have installed right now is single channel. Does dual channel support implicitly support single channel as well or could this be a problem? Does anyone know for sure? I'm not having much luck with google.
Postby Vyacheslav » 2010.11.03 (02:04)
For dual channel to work, your RAM must be exactly the same, eg. same speed, mb/gb, timings, brand, model, etc. and in your case it should be placed either in slots 1 and 3 or 2 and 4... Have you seen anything in the BIOS settings that you can configure or does it have one of those OEM restricted BIOSes?
Postby Tanner » 2010.11.03 (03:05)
oeuvre wrote:For dual channel to work, your RAM must be exactly the same, eg. same speed, mb/gb, timings, brand, model, etc. and in your case it should be placed either in slots 1 and 3 or 2 and 4... Have you seen anything in the BIOS settings that you can configure or does it have one of those OEM restricted BIOSes?
I don't really get the question. What sort of setting would I be looking for that would half the ram detected? Like I've already said, I have single channel ram installed, just in case you misread.
Postby Vyacheslav » 2010.11.03 (03:15)
Single channel doesn't make a difference; it should still see 1GB each instead of 512mb
Postby Tanner » 2010.11.03 (03:55)
oeuvre wrote:Single channel doesn't make a difference; it should still see 1GB each instead of 512mb
Well then this is a real wtf for me.
Postby SlappyMcGee » 2010.11.03 (04:29)
Okay, here's my question; when you run on only one stick, how much?
Postby Tanner » 2010.11.03 (06:23)
=w= wrote:Okay, here's my question; when you run on only one stick, how much?
512MB. I've tried both stick independently and they both gave me 512MB when they were the only one in there.
Postby SlappyMcGee » 2010.11.03 (13:09)
Huhhhhh.
Did you try them on another mobo? That would be the last test to see if they're mislabeled. :)
Postby Tanner » 2010.11.03 (14:27)
Unfortunately I don't have another motherboard that'll fit this ram. I may just buy more ram and see. Worst comes to worst, I can just take it back if the problem isn't resolved. Thanks guys!
Postby Tanner » 2010.11.04 (18:28)
UPDATE
So I went out and, because I don't have another mobo to fit the RAM in question, purchased a gig stick of 400mHz DDR. Went home, pulled out the other RAM, stuck the single stick and bam, 1GB of RAM shows up. So either the RAM in question is mislabeled, damaged, or not compatible with this motherboard in some incredible way. So tomorrow I'mma go out and pick up another one of these gig sticks and I should be where I want to be. Thanks for being the sounding board on this one, guys.
Postby SlappyMcGee » 2010.11.04 (20:28)
hairscapades wrote:UPDATE
Is cool. I hope the new RAM is not GSKILL, and wish you the best of luck.
Postby Vyacheslav » 2010.11.04 (21:11)
Just out of curiosity, how much did you buy that 1GB PC400 RAM?
Postby Tanner » 2010.11.04 (22:50)
35 bucks.
Postby Vyacheslav » 2010.11.04 (22:57)
Ouch. I know you can get 1gb DDR2, maybe even DDR3 RAM for $20... but DDR1 prices are high these days
Postby Tanner » 2010.11.05 (00:46)
It's basically legacy equipment now. You know, like how cassettes cost more than CDs. Still cheaper than buying a new PC.
