The Weekly Challenge [Contest finished]
- NUMA Profile: http://nmaps.net/user/Chrdrenkmann
This theme is awesome!
- Semimember
- NUMA Profile: http://nmaps.net/user/NachoCheese
But anyway, I have two questions about this round. First, does adding an NReality mod count as a remix? I'll even move a few objects around to boot. And secondly, for theme, are we getting judged on how different it is to the original, how similar it is to the original... or are we simply not supposed to know and just find out?
- NUMA Profile: http://nmaps.net/user/sayko
- NUMA Profile: http://www.nmaps.net/user/da_guru
1st: The rules say you have to change either tiles or gameplay, so if you do add a mod, you surely do change gameplay. Nevertheless keep in mind, that your remix should be clearly better than one of your first three maps (which shouldn't be hard to achieve, now you're more experienced).
2nd: It doesn't need to be similar to the original - we don't give any points for that. Actually in most cases the more you change, the more you improve.
@all: Please also post a link to the map you retiled/re-objected, so we can check.
Results for round 2 will be posted at the end of this week.
- Gross
Also, to The Black Lion, you've titled yourself as 'TBC' instead of 'TBL' in a few of the map results for round 1. I know you've done it in mine, and a few others. Just thought I'd let you know ^^
~By me
~By UniverseZero
~By Slick265
I don't want to calculate. D:
BTW: Round 4 should be announced in the thread title.
I suppose you meant "only D-tiles count as empty tiles".da_guru wrote:Only E-tiles count as empty tiles.
Or only E-tiles are full? Sorry, i didn't get it.
- NUMA Profile: http://nmaps.net/user/lukesv
It is not my submission. I am just using it for reference.
Damn, i've just figured out i did count them false! There is 306 E and 407 D Tiles!sayko wrote: Used 306 E-Tiles and 307 D-Tiles.
Shall i change it by adding 50 E - Tiles, or is it valid like this?
- NUMA Profile: http://nmaps.net/user/lsudny
- MBTI Type: ISFP
That is why I decline the title of Iron Cook and accept only the lesser title of Zinc Saucier, which I just made up. Also, it comes with double prize money!
Sorry for all this confusion, it was a typo. It was supposed to say "only D-tiles (light grey tiles, those you can pass, which aren't filled with anything, etc.) count as empty-tiles". Updated announcement post.sayko wrote:I suppose you meant "only D-tiles count as empty tiles".da_guru wrote:Only E-tiles count as empty tiles.
Approximately means +- 10 tiles, so I think you should change it. This time you get the permission to do so, but usually submitted maps mustn't be changed.sayko wrote:Damn, i've just figured out i did count them false! There is 306 E and 407 D Tiles!
Yeah, it perfectly would.lukesv wrote:Would this map follow all the rules.
I've added 50 E - Tiles to my entry, now it has got perfect 356 - 357 balance.]
- Gross
~By me
~By UniverseZero
~By Slick265
- Member
Users browsing this forum: Majestic-12 [Bot] and 19 guests
