Post a Run!
[/apologyForCrushingDreams]
I imagine that ninja heaven is a small section outside the map programmed so that he can bounce outside of the map. And that ninja hell is another small section of the map where the ninja painfully crushed against a tile repeatedly with a launchpad below it, while being reborn and then subjected to a painful death again. (I imagine that ninjas who give up and suicide go to hell.)golf wrote:That would work except that launch pads are non-functional outside of the map boundaries. I have tested this, and you can actually see it in one of my maps if you so choose. The ninja is completely non-interacting outside of the boundaries.
- NUMA Profile: http://nmaps.net/user/OutrightOJ
Thanks to furry for this awesome sig. He likes birds, he does.
Yeah its like the heavens and hells in GTA SA, they're not seen in normal gameplay.mohamedraif wrote:I imagine that ninja heaven is a small section outside the map programmed so that he can bounce outside of the map. And that ninja hell is another small section of the map where the ninja painfully crushed against a tile repeatedly with a launchpad below it, while being reborn and then subjected to a painful death again. (I imagine that ninjas who give up and suicide go to hell.)golf wrote:That would work except that launch pads are non-functional outside of the map boundaries. I have tested this, and you can actually see it in one of my maps if you so choose. The ninja is completely non-interacting outside of the boundaries.
Careful... you're beginning to sound like the catholic church.mohamedraif wrote:I imagine that ninja heaven is a small section outside the map programmed so that he can bounce outside of the map. And that ninja hell is another small section of the map where the ninja painfully crushed against a tile repeatedly with a launchpad below it, while being reborn and then subjected to a painful death again. (I imagine that ninjas who give up and suicide go to hell.)golf wrote:That would work except that launch pads are non-functional outside of the map boundaries. I have tested this, and you can actually see it in one of my maps if you so choose. The ninja is completely non-interacting outside of the boundaries.
The Ninja's Creed wrote:I believe in the holy ninja church
golf wrote:The Ninja's Creed wrote:I believe in the holy ninja church
TheRealOne wrote:golf wrote:The Ninja's Creed wrote:I believe in the holy ninja church
maybe because speedruns 0th saturated easier than highscore? cause there are still quite some speedruns submitted
http://n.infunity.com/latest_lv_score_speedrun.php
- Lords a-Leaping
- NUMA Profile: http://nmaps.net/user/guardian_of_chaos
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/Kool-aid
"sorry"Unreality wrote:maybe because speedruns 0th saturated easier than highscore? cause there are still quite some speedruns submitted
yea Im the sr representative bitches
4104 hs
try my "shortcut method" i posted on numa.. I'd be interested to see what could be made of it.
Edit: beat van's run on 24472; props for the route..
24472 was a really old run, barely remember it
EDIT: i would say my hs route is faster than yours (on 4104)
Yeah, your hs route looks a little faster, but what about implementing the sr route into the hs?vankusss wrote:i was able to do 1042 with it
Userlevels data for the lazies:
took sr and hsska wrote:207378 sr
both are beatable.
- These Go Up to 11
- NUMA Profile: http://nmaps.net/user/-Jol-
sr 233 framesvankusss wrote:took sr and hsska wrote:207378 sr
your record is good ._.
Edoit: add 74060 sr to that.
- NUMA Profile: http://nmaps.net/user/Ferox%20
